[postgis-tickets] [PostGIS] #5309: ST_ClusterKMeans not working on PostGIS 3.23
PostGIS trac at osgeo.org
Tue Jan 10 03:42:31 PST 2023
  Reporter:  jbtw     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Changes (by jbtw):
 * status:  closed => reopened
 * resolution:  worksforme =>
Comment:
 Hello,
 I confirmed on my local machine that upgrading PostGIS fixes the problem.
 Originally I encountered the problem on a managed Postgres Instance (and
 still see it there) on the Azure Cloud. I don't have the ability to
 manually upgrade there however.
 The postgis_full_version on that instance is
 POSTGIS="3.2.3 0" [EXTENSION] PGSQL="130" GEOS="3.9.2-CAPI-1.14.3"
 PROJ="9.0.1" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1"
 WAGYU="0.5.0 (Internal)" (core procs from "3.1.1 aaf4c79" need upgrade)
 If doesn't have the conflicting versions my local installation had but if
 it's still a configuration problem, then I can take it up with someone
 from Azure (and point them to this ticket).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5309#comment:2>
