[postgis-tickets] [PostGIS] #5315: ST_Buffer causes segfault
PostGIS trac at osgeo.org
Fri Jan 13 16:48:24 PST 2023
 Reporter:  ewie     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:
Component:  postgis  |    Version:  3.2.x
 Keywords:           |
 The following query causes a segfault that puts Postgres in recovery mode:
 SELECT
   ST_Buffer(
     ST_Transform(
       ST_SetSRID(
         ST_GeomFromText(
           'MULTIPOLYGON(((0 0, 1 0, 1 1, 0 1, 0 0)))',
           4326
         4647
       25832
     1
 Postgres log:
 2023-01-14 01:21:54.455 CET [4520] LOG:  server process (PID 5016) was
 terminated by exception 0xC0000005
 2023-01-14 01:21:54.455 CET [4520] DETAIL:  Failed process was running:
 SELECT
           ST_Buffer(
             ST_Transform(
               ST_SetSRID(
                 ST_GeomFromText(
                   4326
                 4647
               25832
             1
 2023-01-14 01:21:54.455 CET [4520] HINT:  See C include file "ntstatus.h"
 for a description of the hexadecimal value.
 2023-01-14 01:21:54.455 CET [4520] LOG:  terminating any other active
 server processes
 2023-01-14 01:21:54.462 CET [8804] WARNING:  terminating connection
 because of crash of another server process
 2023-01-14 01:21:54.462 CET [8804] DETAIL:  The postmaster has commanded
 this server process to roll back the current transaction and exit, because
 another server process exited abnormally and possibly corrupted shared
 memory.
 2023-01-14 01:21:54.462 CET [8804] HINT:  In a moment you should be able
 to reconnect to the database and repeat your command.
 2023-01-14 01:21:54.476 CET [4520] LOG:  all server processes terminated;
 reinitializing
 2023-01-14 01:21:54.665 CET [5368] LOG:  database system was interrupted;
 last known up at 2023-01-14 01:01:08 CET
 2023-01-14 01:22:29.148 CET [4480] FATAL:  the database system is in
 recovery mode
 2023-01-14 01:22:50.260 CET [5368] LOG:  database system was not properly
 shut down; automatic recovery in progress
 2023-01-14 01:22:50.440 CET [5368] LOG:  redo starts at 157/4F24D0F8
 2023-01-14 01:22:50.441 CET [5368] LOG:  invalid record length at
 157/4F24D1E0: wanted 24, got 0
 2023-01-14 01:22:50.441 CET [5368] LOG:  redo done at 157/4F24D1A8
 2023-01-14 01:22:50.891 CET [4520] LOG:  database system is ready to
 accept connections
 The segfault is caused by ST_Buffer. Omitting ST_Buffer or calling it with
 `buffer_or_radius=0` causes no segfault.
 Calling ST_SetSRID with `srid=4647` before ST_Transform is nonsense but it
 should not return a geometry that causes ST_Buffer to segfault. The origin
 of this query is a database user who erroneously set incorrect SRID 4647
 before transforming geometries.
 I '''cannot reproduce''' it with Docker images `postgis/postgis:12-3.2` or
 `postgis/postgis:14-3.3`.
 === Postgres & PostGIS versions
 PostgreSQL 12.13, compiled by Visual C++ build 1914, 64-bit
 POSTGIS="3.2.2 3.2.2" [EXTENSION] PGSQL="120" GEOS="3.10.3-CAPI-1.16.1"
 SFCGAL="1.4.1" PROJ="7.2.1" GDAL="GDAL 3.4.2, released 2022/03/08
 GDAL_DATA not found" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
 WAGYU="0.5.0 (Internal)" RASTER
 PostgreSQL 14.6, compiled by Visual C++ build 1914, 64-bit
 POSTGIS="3.3.2 3.3.2" [EXTENSION] PGSQL="140" GEOS="3.11.1-CAPI-1.17.1"
 PROJ="7.2.1" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5315>
