[postgis-tickets] [PostGIS] #5315: ST_Buffer causes segfault
PostGIS trac at osgeo.org
Sun Jan 15 03:18:13 PST 2023
  Reporter:  ewie     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Description changed by ewie:
Old description:
> The following query causes a segfault that puts Postgres in recovery
> mode:
> SELECT
>   ST_Buffer(
>     ST_Transform(
>       ST_SetSRID(
>         ST_GeomFromText(
>           'MULTIPOLYGON(((0 0, 1 0, 1 1, 0 1, 0 0)))',
>           4326
>         4647
>       25832
>     1
> Postgres log:
> 2023-01-14 01:21:54.455 CET [4520] LOG:  server process (PID 5016) was
> terminated by exception 0xC0000005
> 2023-01-14 01:21:54.455 CET [4520] DETAIL:  Failed process was running:
> SELECT
>           ST_Buffer(
>             ST_Transform(
>               ST_SetSRID(
>                 ST_GeomFromText(
>                   4326
>                 4647
>               25832
>             1
> 2023-01-14 01:21:54.455 CET [4520] HINT:  See C include file "ntstatus.h"
> for a description of the hexadecimal value.
> 2023-01-14 01:21:54.455 CET [4520] LOG:  terminating any other active
> server processes
> 2023-01-14 01:21:54.462 CET [8804] WARNING:  terminating connection
> because of crash of another server process
> 2023-01-14 01:21:54.462 CET [8804] DETAIL:  The postmaster has commanded
> this server process to roll back the current transaction and exit,
> because another server process exited abnormally and possibly corrupted
> shared memory.
> 2023-01-14 01:21:54.462 CET [8804] HINT:  In a moment you should be able
> to reconnect to the database and repeat your command.
> 2023-01-14 01:21:54.476 CET [4520] LOG:  all server processes terminated;
> reinitializing
> 2023-01-14 01:21:54.665 CET [5368] LOG:  database system was interrupted;
> last known up at 2023-01-14 01:01:08 CET
> 2023-01-14 01:22:29.148 CET [4480] FATAL:  the database system is in
> recovery mode
> 2023-01-14 01:22:50.260 CET [5368] LOG:  database system was not properly
> shut down; automatic recovery in progress
> 2023-01-14 01:22:50.440 CET [5368] LOG:  redo starts at 157/4F24D0F8
> 2023-01-14 01:22:50.441 CET [5368] LOG:  invalid record length at
> 157/4F24D1E0: wanted 24, got 0
> 2023-01-14 01:22:50.441 CET [5368] LOG:  redo done at 157/4F24D1A8
> 2023-01-14 01:22:50.891 CET [4520] LOG:  database system is ready to
> accept connections
> The segfault is caused by ST_Buffer. Omitting ST_Buffer or calling it
> with `buffer_or_radius=0` causes no segfault.
> Calling ST_SetSRID with `srid=4647` before ST_Transform is nonsense but
> it should not return a geometry that causes ST_Buffer to segfault. The
> origin of this query is a database user who erroneously set incorrect
> SRID 4647 before transforming geometries.
> I '''cannot reproduce''' it with Docker images `postgis/postgis:12-3.2`
> or `postgis/postgis:14-3.3`.
> === Postgres & PostGIS versions
> PostgreSQL 12.13, compiled by Visual C++ build 1914, 64-bit
> POSTGIS="3.2.2 3.2.2" [EXTENSION] PGSQL="120" GEOS="3.10.3-CAPI-1.16.1"
> SFCGAL="1.4.1" PROJ="7.2.1" GDAL="GDAL 3.4.2, released 2022/03/08
> GDAL_DATA not found" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
> WAGYU="0.5.0 (Internal)" RASTER
> PostgreSQL 14.6, compiled by Visual C++ build 1914, 64-bit
> POSTGIS="3.3.2 3.3.2" [EXTENSION] PGSQL="140" GEOS="3.11.1-CAPI-1.17.1"
> PROJ="7.2.1" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
New description:
 The following query causes a segfault that puts Postgres in recovery mode:
 SELECT
   ST_Buffer(
     ST_Transform(
       ST_SetSRID(
         ST_GeomFromText(
           4326
         4647
       25832
     1
 Postgres log:
 SELECT
           ST_Buffer(
             ST_Transform(
               ST_SetSRID(
                 ST_GeomFromText(
                   4326
                 4647
               25832
             1
 server processes
 this server process to roll back the current transaction and exit, because
 another server process exited abnormally and possibly corrupted shared
 memory.
 reinitializing
 recovery mode
 accept connections
 The segfault is caused by ST_Buffer. Omitting ST_Buffer or calling it with
 ST_Buffer should not segfault on the resulting geometry. The origin of
 this query is a database user who erroneously set incorrect SRID 4647
 I '''cannot reproduce''' it with Docker images `postgis/postgis:12-3.2` or
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5315#comment:1>
