[postgis-tickets] [PostGIS] #5317: ST_Union(rast, uniontype) treat bands with different classes as the same as first band
PostGIS trac at osgeo.org
Fri Jan 20 08:09:14 PST 2023
first band
  Reporter:  shenzhuxi  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 3.3.3
 Component:  postgis    |    Version:  3.3.x
Resolution:             |   Keywords:
Description changed by shenzhuxi:
Old description:
> POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 "
> PROJ="6.3.1" GDAL="GDAL 3.0.4
> Related to https://trac.osgeo.org/postgis/ticket/2200 ST_Union support
> multiple bands issue
> If the $RASTER has multiple bands like ARRAY['8BUI', '16BUI'], the result
> of
>             ST_Union(
>               $RASTER,
>               ARRAY[
>                 ROW(1, 'SUM'),
>                 ROW(2, 'MAX')
>               ]::unionarg[]
> will be like ARRAY['8BUI', ' 8BUI'].
> ST_Union always uses the first band class to process the 2nd band and
> ignore the original class.
> The same problem also can be triggered with ST_Union(setof raster rast,
> 2, text uniontype), if the first band is different from the second one.
New description:
 of
             ST_Union(
               $RASTER,
               ARRAY[
                 ROW(1, 'SUM'),
                 ROW(2, 'MAX')
               ]::unionarg[]
 will be treated like ARRAY['8BUI', ' 8BUI'] and the max value will be 254
 even the real value is a higher number in 16BUI.
 The same problem also can be triggered with ST_Union(setof raster rast, 2,
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5317#comment:1>
