[postgis-tickets] [PostGIS] #5317: ST_Union(rast, uniontype) treat bands with different classes as the same as first band
PostGIS trac at osgeo.org
Fri Jan 20 07:43:12 PST 2023
first band
 Reporter:  shenzhuxi  |      Owner:  pramsey
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 3.3.3
Component:  postgis    |    Version:  3.3.x
 Keywords:             |
 POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 "
 PROJ="6.3.1" GDAL="GDAL 3.0.4
 Related to https://trac.osgeo.org/postgis/ticket/2200 ST_Union support
 multiple bands issue
 If the $RASTER has multiple bands like ARRAY['8BUI', '16BUI'], the result
 of
             ST_Union(
               $RASTER,
               ARRAY[
                 ROW(1, 'SUM'),
                 ROW(2, 'MAX')
               ]::unionarg[]
 will be like ARRAY['8BUI', ' 8BUI'].
 ST_Union always uses the first band class to process the 2nd band and
 ignore the original class.
 The same problem also can be triggered with ST_Union(setof raster rast, 2,
 text uniontype), if the first band is different from the second one.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5317>
