[postgis-tickets] [PostGIS] #5316: Regress failure with in-develop proj
PostGIS trac at osgeo.org
Fri Jan 27 05:29:16 PST 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by ImreSamu):
 > issue of the extra size.
 My latest solution only adds +1 MB to the docker image size.
 I think this is an acceptable compromise.
 And it might avoid the removal of these tests.
 I think it would also make sense to include it in the postgis installation
 steps ? ( or the regression testing steps ?? ) And then I don't have to
 issue these commands separately in the Dockerfile.
 # refresh proj data - workarounds:
 https://trac.osgeo.org/postgis/ticket/5316
     && projsync --system-directory --file ch_swisstopo_CHENyx06_ETRS \
     && projsync --system-directory --file us_noaa_eshpgn \
     && projsync --system-directory --file us_noaa_prvi \
     && projsync --system-directory --file us_noaa_wmhpgn \
 https://github.com/postgis/docker-
 postgis/pull/337/commits/0309004b39514b5ba9e8ff116998248782de0fd6
 And the test is OK : https://github.com/postgis/docker-postgis/pull/337
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5316#comment:6>
