[postgis-tickets] [PostGIS] #5316: Regress failure with in-develop proj
PostGIS trac at osgeo.org
Thu Jan 26 18:34:03 PST 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 Okay I switched our buildenv docker to use projsync and that fixed the
 issue but as you said there is still the issue of the extra size.
 @pramsey suggested we just get rid of those tests.  I'm willing to do
 that, but I guess I'll need to compile 9.2 proj branch now that our bots
 are all fixed to make sure I remove the right amount.
 I'd hate to completely remove the regress_proj_cache_overflow
 The other failing one regress_proj_4890 was designed to test #4890
 I think that wone we can maybe replace with a different srid.  I assume
 there is nothing special about the 3005 that was picked for that test.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5316#comment:5>
