[postgis-tickets] [PostGIS] #5320: ST_SimplifyPreserveTopology crashes with infinity coordinates
PostGIS trac at osgeo.org
Fri Jan 20 22:27:09 PST 2023
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 3.0.9
Component:  postgis  |    Version:  master
 Keywords:           |
 Same issue as #5318, #5317, #5315
 SELECT ST_SimplifyPreserveTopology(foo1.the_geom, 20.1)  As result
                                                         FROM ((SELECT
 '0106000020E61000000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry
 AS the_geom ) ) As foo1 ;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5320>
