[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-554-g8b1363ac4
Mon Jan 23 08:06:33 PST 2023
the project "PostGIS".
       via  8b1363ac4365a96715ecef67df51eff40980dcd8 (commit)
      from  d03aa1b80f8c0cb04cf37ee8186e29a94feb2abe (commit)
revisions in full, below.
commit 8b1363ac4365a96715ecef67df51eff40980dcd8
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 23 17:06:20 2023 +0100
    Make test for selectivity estimation more readable
diff --git a/regress/core/regress_index.sql b/regress/core/regress_index.sql
index 30e7617e2..494ef9ec5 100644
--- a/regress/core/regress_index.sql
+++ b/regress/core/regress_index.sql
@@ -53,6 +53,8 @@ DECLARE
   act INT; -- actual count
   mat TEXT[];
 BEGIN
+  -- TODO: rewrite using json output ?
   EXECUTE 'EXPLAIN ANALYZE ' || qry INTO anl;
   SELECT regexp_matches(anl, ' rows=([0-9]*) .* rows=([0-9]*) ')
@@ -63,7 +65,7 @@ BEGIN
   err = abs(est-act);
-  RETURN act || '+=' || tol || ':' || coalesce(
+  RETURN act || '+-' || tol || ':' || coalesce(
     nullif((err < tol)::text,'false'),
     'false:'||err::text
@@ -88,7 +90,7 @@ ALTER TABLE test ALTER COLUMN the_geom SET STATISTICS 10000;
 ANALYZE test;
-SELECT estimate_error(
+SELECT '&&', id, estimate_error(
   'select num from test where the_geom && ' || box, tol )
   FROM sample_queries ORDER BY id;
@@ -97,7 +99,7 @@ SELECT estimate_error(
 CREATE INDEX expressional_gist on test using gist ( st_centroid(the_geom) );
 ANALYZE test;
-SELECT 'expr', estimate_error(
+SELECT 'expr &&', id, estimate_error(
   'select num from test where st_centroid(the_geom) && ' || box, tol )
diff --git a/regress/core/regress_index_expected b/regress/core/regress_index_expected
index 41cfbb2ff..8872c19ef 100644
--- a/regress/core/regress_index_expected
+++ b/regress/core/regress_index_expected
@@ -10,12 +10,12 @@ scan_seq|Index Scan
 27373|POINT(129.481991 125.755641)
 33863|POINT(127.143785 131.932614)
 45851|POINT(130.986464 132.890625)
-5+=5:true
-907+=60:true
-12505+=500:true
-50000+=600:true
-expr|5+=5:true
-expr|907+=60:true
-expr|12505+=500:true
-expr|50000+=600:true
+&&|1|5+-5:true
+&&|2|907+-60:true
+&&|3|12505+-500:true
+&&|4|50000+-600:true
+expr &&|1|5+-5:true
+expr &&|2|907+-60:true
+expr &&|3|12505+-500:true
+expr &&|4|50000+-600:true
 _st_sortablehash|0|768602608280535040|768602608280535040
Summary of changes:
 regress/core/regress_index.sql      |  8 +++++---
 regress/core/regress_index_expected | 16 ++++++++--------
 2 files changed, 13 insertions(+), 11 deletions(-)
hooks/post-receive
