[postgis-tickets] [PostGIS] #5424: Use of remark tag preventing Z, M, curved support, SQL-MM attributes from showing in PDF
PostGIS trac at osgeo.org
Sun Jul 2 07:21:19 PDT 2023
#5424: Use of remark tag preventing Z,M, curved support, SQL-MM attributes from
showing in PDF
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by strk):
 The yellow color can be tweaked in html/style.css file. It looks like our
 new tag-files are the only ones using that tag so tweaking that color
 should not produce other unwanted changes.
 As per the PDF, I've tried passing -P show.comments=1 as specified in
 https://dblatex.sourceforge.net/doc/manual/show.comments.html but it
 didn't seem to work.
 The reason why I'm using <remark> is because we need tag to contain
 everything found in the tag_*.xml files for xml2pot to extract that
 content. Such tag ideally would have no other effect than grouping both
 the inlineimage and the paragraph to be translated, and produce no newline
 at its end. The remark tag seems to work for this. I've tried <para> (but
 introduces a neline) and I've tried <markup> (is not understood by
 xml2pot).
 Tags that are supposedly supported by xlm2pot can be read here:
 https://github.com/KDE/poxml/blob/master/parser.cpp#L34
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5424#comment:2>
