[postgis-tickets] [PostGIS] #5424: Use of remark tag preventing Z, M, curved support, SQL-MM attributes from showing in PDF
PostGIS trac at osgeo.org
Sun Jul 2 12:25:01 PDT 2023
#5424: Use of remark tag preventing Z,M, curved support, SQL-MM attributes from
showing in PDF
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by strk):
 Another option would be using the <tip> tag, which is currently unused,
 and reques using the check.png file instead of the tip.png file to render
 that
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5424#comment:3>
