[postgis-tickets] [PostGIS] #5424: Use of remark tag preventing Z, M, curved support, SQL-MM attributes from showing in PDF
PostGIS trac at osgeo.org
Tue Jul 4 10:41:16 PDT 2023
#5424: Use of remark tag preventing Z,M, curved support, SQL-MM attributes from
showing in PDF
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by strk):
 I tried the <tip> idea, but it introduces a newline, which we don't want.
 Another option I've been thinking about is now that we have xsl-config.xml
 we could put all the text to be translated in that file and have a
 generator for each of those tag files that would use the xsl config text
 to generate them
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5424#comment:4>
