[postgis-tickets] [PostGIS] #5424: Use of remark tag preventing Z, M, curved support, SQL-MM attributes from showing in PDF
PostGIS trac at osgeo.org
Tue Jul 4 15:24:08 PDT 2023
#5424: Use of remark tag preventing Z,M, curved support, SQL-MM attributes from
showing in PDF
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  medium         |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:  fixed          |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"81e0db7ea387cc3228b3a6a136d883afff6e0d94/git" 81e0db7/git]:
 {{{#!CommitTicketReference repository="git"
 revision="81e0db7ea387cc3228b3a6a136d883afff6e0d94"
 Generate tag files from xsl-config.xml, fixing PDF output
 Closes #5424
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5424#comment:5>
