[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1107-g193f2c4ca
Mon Jul 3 11:19:46 PDT 2023
the project "PostGIS".
       via  193f2c4caa2db823c6e2f4210d6d9d3ef54be80d (commit)
      from  ec9803be04ea513b3ee96a9e201182a1d3ee53ca (commit)
revisions in full, below.
commit 193f2c4caa2db823c6e2f4210d6d9d3ef54be80d
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 3 14:17:24 2023 -0400
    DOC FIXES
     - Put geography_transform content back in body of remarks
       otherwise not translatable
     - Add a remark style to override yellow coloring of remark
       coming from docbook
     - Fix entities, broken by french translation
       Fix using fix_xml_entitites.sh
diff --git a/doc/html/style.css b/doc/html/style.css
index 110e0500f..fb08c048e 100644
--- a/doc/html/style.css
+++ b/doc/html/style.css
@@ -31,7 +31,9 @@ div.navfooter {
     color: white;
+.remark {
+    background: white;
 /* Phone width */
 @media (max-width: 40em) {
diff --git a/doc/po/de/tag_geography_transform.xml.po b/doc/po/de/tag_geography_transform.xml.po
index 447040a5d..ebd3b131e 100644
--- a/doc/po/de/tag_geography_transform.xml.po
+++ b/doc/po/de/tag_geography_transform.xml.po
@@ -5,7 +5,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: ming 64gcc81\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-07-01 21:38+0000\n"
+"POT-Creation-Date: 2023-07-03 18:08+0000\n"
 "PO-Revision-Date: 2023-06-28 00:36+0000\n"
 "Last-Translator: Automatically generated\n"
 "Language-Team: none\n"
@@ -14,3 +14,10 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
+#. Tag: remark
+#: tag_geography_transform.xml:3
+#, no-c-format
+msgid ""
+"For geography this is a thin wrapper around the geometry implementation."
+msgstr ""
diff --git a/doc/po/es/tag_geography_transform.xml.po b/doc/po/es/tag_geography_transform.xml.po
index 2b86b7f2f..8c364caaa 100644
--- a/doc/po/es/tag_geography_transform.xml.po
+++ b/doc/po/es/tag_geography_transform.xml.po
 msgstr ""
+#. Tag: remark
+#, no-c-format
+msgid ""
+msgstr ""
diff --git a/doc/po/fr/reference_measure.xml.po b/doc/po/fr/reference_measure.xml.po
index f7864275d..1bd6869c0 100644
--- a/doc/po/fr/reference_measure.xml.po
+++ b/doc/po/fr/reference_measure.xml.po
@@ -3742,7 +3742,7 @@ msgstr "L'Est est l'azimut &#x03C0;/2 (90 degrés)"
 #: reference_measure.xml:1508
 #, no-c-format
 msgid "South is azimuth &#x03C0; (180 degrees)"
-msgstr "Le sud est l'azimut &#x03C0 ; (180 degrés)"
+msgstr "Le sud est l'azimut &#x03C0; (180 degrés)"
 #. Tag: para
 #: reference_measure.xml:1509
@@ -3757,7 +3757,7 @@ msgid ""
 "Negative azimuth values and values greater than 2&#x03C0; (360 degrees) are "
 "supported."
 msgstr ""
-"Les valeurs d'azimut négatives et les valeurs supérieures à 2&#x03C0 ; (360 "
+"Les valeurs d'azimut négatives et les valeurs supérieures à 2&#x03C0; (360 "
 "degrés) sont prises en charge."
 #. Tag: para
diff --git a/doc/po/fr/reference_overlay.xml.po b/doc/po/fr/reference_overlay.xml.po
index cf8206374..7e3a99c49 100644
--- a/doc/po/fr/reference_overlay.xml.po
+++ b/doc/po/fr/reference_overlay.xml.po
@@ -410,7 +410,7 @@ msgid ""
 "mercator in worst case scenario) and then intersection in that best fit "
 "planar spatial ref and retransforms back to WGS84 geography."
 msgstr ""
-"&geography_transform ; Il détermine d'abord le meilleur SRID qui correspond "
+"&geography_transform; Il détermine d'abord le meilleur SRID qui correspond "
 "à la boîte de délimitation des 2 objets géographiques (si les objets "
 "géographiques sont dans une demi-zone UTM mais pas le même UTM choisira l'un "
 "d'eux) (en favorisant UTM ou Lambert Azimuthal Equal Area (LAEA) pôle nord/"
diff --git a/doc/po/fr/reference_processing.xml.po b/doc/po/fr/reference_processing.xml.po
index 2f24d117e..d2d6f7e7e 100644
--- a/doc/po/fr/reference_processing.xml.po
+++ b/doc/po/fr/reference_processing.xml.po
@@ -236,7 +236,7 @@ msgid ""
 "This may not produce the desired behavior if the input object is much larger "
 "than a UTM zone or crosses the dateline"
 msgstr ""
-"&geography_transform ; Il détermine un système de référence spatiale "
+"&geography_transform; Il détermine un système de référence spatiale "
 "planaire qui correspond le mieux à la boîte de délimitation de l'objet "
 "géographique (en essayant UTM, le pôle Nord/Sud de Lambert Azimuthal Equal "
 "Area (LAEA), et enfin Mercator). Le tampon est calculé dans l'espace "
diff --git a/doc/po/fr/tag_geography_transform.xml.po b/doc/po/fr/tag_geography_transform.xml.po
index ccb0ce799..e3615a2f3 100644
--- a/doc/po/fr/tag_geography_transform.xml.po
+++ b/doc/po/fr/tag_geography_transform.xml.po
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: 2023-06-28 08:08+0000\n"
 "Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
@@ -18,6 +18,13 @@ msgstr ""
 "Plural-Forms: nplurals=2; plural=n > 1;\n"
 "X-Generator: Weblate 4.16.4\n"
+#. Tag: remark
+#, no-c-format
+msgid ""
+msgstr ""
 #, no-c-format
 #~ msgid ""
 #~ "This method is not a native method for geography and relies on geometry "
diff --git a/doc/po/it_IT/tag_geography_transform.xml.po b/doc/po/it_IT/tag_geography_transform.xml.po
index 79d4a77da..14262f33b 100644
--- a/doc/po/it_IT/tag_geography_transform.xml.po
+++ b/doc/po/it_IT/tag_geography_transform.xml.po
 msgstr ""
+#. Tag: remark
+#, no-c-format
+msgid ""
+msgstr ""
diff --git a/doc/po/ja/tag_geography_transform.xml.po b/doc/po/ja/tag_geography_transform.xml.po
index 01d0d6303..38b42679d 100644
--- a/doc/po/ja/tag_geography_transform.xml.po
+++ b/doc/po/ja/tag_geography_transform.xml.po
 msgstr ""
 "PO-Revision-Date: 2023-06-29 09:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "Plural-Forms: nplurals=1; plural=0;\n"
+#. Tag: remark
+#, no-c-format
+msgid ""
+msgstr ""
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/ko_KR/tag_geography_transform.xml.po b/doc/po/ko_KR/tag_geography_transform.xml.po
index e84b304d6..7f3dd40d7 100644
--- a/doc/po/ko_KR/tag_geography_transform.xml.po
+++ b/doc/po/ko_KR/tag_geography_transform.xml.po
 msgstr ""
+#. Tag: remark
+#, no-c-format
+msgid ""
+msgstr ""
diff --git a/doc/po/pl/tag_geography_transform.xml.po b/doc/po/pl/tag_geography_transform.xml.po
index be48a53ef..0b119d906 100644
--- a/doc/po/pl/tag_geography_transform.xml.po
+++ b/doc/po/pl/tag_geography_transform.xml.po
 msgstr ""
@@ -15,3 +15,10 @@ msgstr ""
 "Plural-Forms: nplurals=3; plural=(n==1 ? 0 : n%10>=2 && n%10<=4 && (n%100<10 "
 "|| n%100>=20) ? 1 : 2);\n"
+#. Tag: remark
+#, no-c-format
+msgid ""
+msgstr ""
diff --git a/doc/po/pt_BR/tag_geography_transform.xml.po b/doc/po/pt_BR/tag_geography_transform.xml.po
index fe111cb3e..de691c1b1 100644
--- a/doc/po/pt_BR/tag_geography_transform.xml.po
+++ b/doc/po/pt_BR/tag_geography_transform.xml.po
 msgstr ""
 "Plural-Forms: nplurals=2; plural=(n > 1);\n"
+#. Tag: remark
+#, no-c-format
+msgid ""
+msgstr ""
diff --git a/doc/po/ru/tag_geography_transform.xml.po b/doc/po/ru/tag_geography_transform.xml.po
index d8f7959a1..259c18edb 100644
--- a/doc/po/ru/tag_geography_transform.xml.po
+++ b/doc/po/ru/tag_geography_transform.xml.po
 msgstr ""
 "Plural-Forms: nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n%10>=2 && "
 "n%10<=4 && (n%100<10 || n%100>=20) ? 1 : 2);\n"
+#. Tag: remark
+#, no-c-format
+msgid ""
+msgstr ""
diff --git a/doc/po/templates/tag_geography_transform.xml.pot b/doc/po/templates/tag_geography_transform.xml.pot
index 84e203173..b133288a1 100644
--- a/doc/po/templates/tag_geography_transform.xml.pot
+++ b/doc/po/templates/tag_geography_transform.xml.pot
@@ -6,10 +6,17 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
 "MIME-Version: 1.0\n"
+#. Tag: remark
+#, no-c-format
+msgid ""
+msgstr ""
diff --git a/doc/tag_geography_transform.xml b/doc/tag_geography_transform.xml
index f4a62eb57..547ca930a 100644
--- a/doc/tag_geography_transform.xml
+++ b/doc/tag_geography_transform.xml
@@ -1,6 +1,5 @@
 <remark conformance="geography_transform">
 <inlinemediaobject>
    <imageobject><imagedata fileref='images/matrix_transform.png' /></imageobject>
-</inlinemediaobject>
+</inlinemediaobject> For geography this is a thin wrapper around the geometry implementation.
 </remark>
-For geography this is a thin wrapper around the geometry implementation.
Summary of changes:
 doc/html/style.css                               | 4 +++-
 doc/po/de/tag_geography_transform.xml.po         | 9 ++++++++-
 doc/po/es/tag_geography_transform.xml.po         | 9 ++++++++-
 doc/po/fr/reference_measure.xml.po               | 4 ++--
 doc/po/fr/reference_overlay.xml.po               | 2 +-
 doc/po/fr/reference_processing.xml.po            | 2 +-
 doc/po/fr/tag_geography_transform.xml.po         | 9 ++++++++-
 doc/po/it_IT/tag_geography_transform.xml.po      | 9 ++++++++-
 doc/po/ja/tag_geography_transform.xml.po         | 9 ++++++++-
 doc/po/ko_KR/tag_geography_transform.xml.po      | 9 ++++++++-
 doc/po/pl/tag_geography_transform.xml.po         | 9 ++++++++-
 doc/po/pt_BR/tag_geography_transform.xml.po      | 9 ++++++++-
 doc/po/ru/tag_geography_transform.xml.po         | 9 ++++++++-
 doc/po/templates/tag_geography_transform.xml.pot | 9 ++++++++-
 doc/tag_geography_transform.xml                  | 3 +--
 15 files changed, 88 insertions(+), 17 deletions(-)
hooks/post-receive
