[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1125-g578f3f959
Wed Jul 5 03:23:05 PDT 2023
the project "PostGIS".
       via  578f3f959dd2ffc38727a15d2ca2ef02226839c1 (commit)
      from  54f15306959a8274a2e33c9b8232282675845dd5 (commit)
revisions in full, below.
commit 578f3f959dd2ffc38727a15d2ca2ef02226839c1
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 5 01:34:15 2023 +0200
    Reorganize html targets
      - Non-chunked will be html/postgis-<lang>.html
      - Chunked will be under html/postgis-<lang>/
      - Chunked web will be under html/postgis-web-<lang>/
      - Chunked web mobile will be under html/postgis-web-mobile-<lang>/
      - Images (all shared) will be under html/images
      - HTML install will honour --htmldir configure switch
      - Add html-assets-install and html-assets-uninstall targets
    References #5429
    References #5430
diff --git a/doc/Makefile.in b/doc/Makefile.in
index eac85d649..bfd78fbb5 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -32,11 +32,15 @@ top_builddir = @top_builddir@
 mandir = @mandir@
 abs_srcdir = @abs_srcdir@
 abs_builddir = @abs_builddir@
+docdir = @docdir@
+htmldir = @htmldir@
 POSTGIS_MAJOR_VERSION=@POSTGIS_MAJOR_VERSION@
 POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
 POSTGIS_MICRO_VERSION=@POSTGIS_MICRO_VERSION@
+DOCSUFFIX=-en
 ifneq (,$(findstring dev,$(POSTGIS_MICRO_VERSION)))
   POSTGIS_DOWNLOAD_URL=http://postgis.net/stuff
 else
@@ -91,6 +95,9 @@ XSLTPROC_COMMONOPTS= \
 	--stringparam html.stylesheet style.css \
 	$(XSLTPROCFLAGS)
+XSLTPROC_CHUNKED_HTML_OPTS = \
+	--stringparam img.src.path ../
 HTML_DOCBOOK_XSL=$(XSLBASE)/html/docbook.xsl
 CHUNK_HTML_DOCBOOK_XSL=$(XSLBASE)/html/chunk.xsl
@@ -110,7 +117,6 @@ DBTOEPUB=@DBTOEPUB@
 # Directories for postgresql subdirectories
 PGSQL_DOCDIR=@PGSQL_DOCDIR@
-PGSQL_SHAREDIR=@PGSQL_SHAREDIR@
 BUILD_TARGET =
@@ -297,24 +303,26 @@ $(GENERATED_CHEATSHEET_FILES): html/%.html: xsl/%.html.xsl $(XML_INPUTS) postgis
 postgis-out.xml: postgis.xml Makefile
 	$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@
-chunked-html: postgis-out.xml Makefile images $(XML_INPUTS)
+chunked-html: postgis-out.xml Makefile $(XML_INPUTS)
 	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
-		--output html$(DOCSUFFIX)/ \
+		$(XSLTPROC_CHUNKED_HTML_OPTS) \
+		--output html/postgis$(DOCSUFFIX)/ \
 		$(CHUNK_HTML_DOCBOOK_XSL) \
-chunked-html-web: postgis-out.xml Makefile images $(XML_INPUTS)
+chunked-html-web: postgis-out.xml Makefile $(XML_INPUTS)
-		--output html/ \
+		--output html/postgis-web$(DOCSUFFIX)/ \
 		--stringparam html.script ga.js \
 HTML_BITS = $(wildcard html/*.html)
-chunked-html-web-mobile: postgis-out.xml Makefile images $(XML_INPUTS)
+chunked-html-web-mobile: postgis-out.xml Makefile $(XML_INPUTS)
-		--output html/ \
+		--output html/postgis-web-mobile$(DOCSUFFIX)/ \
@@ -329,7 +337,7 @@ html-localized chunked-html-localized:
     $(MAKE) -C po/$$lang local-$$rule || exit 1; \
   done
-html/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile images $(XML_INPUTS)
+html/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile $(XML_INPUTS)
 		--output html/postgis$(DOCSUFFIX).html \
 		$(HTML_DOCBOOK_XSL) \
@@ -389,15 +397,12 @@ doxygen.cfg: doxygen.cfg.in
 doxygen: doxygen.cfg
 	doxygen $<
-images:
-	$(MAKE) -C html/images images
-images-clean:
-	$(MAKE) -C html/images images-clean
+images images-install images-uninstall images-clean:
+	$(MAKE) -C html/images $@
 clean:
-	rm -f html/*.html
-	rm -f postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.pdf
+	rm -rf html/postgis-*
+	rm -f *.pdf
 	rm -f *.epub
 	rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
 	rm -f $(XML_GENERATED_SOURCES)
@@ -454,17 +459,23 @@ man-uninstall:
 	rm -f $(DESTDIR)$(mandir)/man1/pgtopo_export.1
 	rm -f $(DESTDIR)$(mandir)/man1/pgtopo_import.1
-docs-install: html/postgis.html html/style.css
-	mkdir -p $(DESTDIR)$(PGSQL_DOCDIR)/postgis/images
-	$(INSTALL_DATA) html/postgis.html $(DESTDIR)$(PGSQL_DOCDIR)/postgis/
-	$(INSTALL_DATA) html/style.css $(DESTDIR)$(PGSQL_DOCDIR)/postgis/
-	$(INSTALL_DATA) html/images/*.png $(DESTDIR)$(PGSQL_DOCDIR)/postgis/images/
+html-install: html/postgis$(DOCSUFFIX).html
+	mkdir -p $(DESTDIR)$(htmldir)/postgis
+	$(INSTALL_DATA) html/postgis$(DOCSUFFIX).html $(DESTDIR)$(htmldir)/postgis/
+html-uninstall:
+	rm -f $(DESTDIR)$(htmldir)/postgis/postgis$(DOCSUFFIX).html
+html-assets-install: images-install
+	$(INSTALL_DATA) html/style.css $(DESTDIR)$(htmldir)/postgis/
+html-assets-uninstall: images-install
+	rm -f $(DESTDIR)$(htmldir)/postgis/style.css
+docs-install: html-install html-assets-install
 	$(INSTALL_DATA) ../README.postgis $(DESTDIR)$(PGSQL_DOCDIR)/postgis/README.postgis
-docs-uninstall:
-	rm -f $(DESTDIR)$(PGSQL_DOCDIR)/postgis/postgis.html
-	rm -f $(DESTDIR)$(PGSQL_DOCDIR)/postgis/style.css
-	rm -rf $(DESTDIR)$(PGSQL_DOCDIR)/postgis/images
+docs-uninstall: html-uninstall html-assets-uninstall
 	rm -f $(DESTDIR)$(PGSQL_DOCDIR)/postgis/README.postgis
 install: comments-install
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index c258318d7..89580bbdb 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -14,6 +14,10 @@
 top_srcdir = @top_srcdir@
 srcdir = @srcdir@
+INSTALL=@INSTALL@
+INSTALL_DATA=@INSTALL_DATA@
 CC=@CC@
 CFLAGS=@CFLAGS@ @PROJ_CPPFLAGS@
@@ -214,13 +218,25 @@ GENERATED_IMAGES_RESIZED= \
 	de9im12.png \
+ALL_IMAGES = \
+	$(GENERATED_IMAGES) \
+	$(GENERATED_IMAGES_RESIZED) \
+	$(STATIC_IMAGES)
 OBJS=styles.o generator.o
 # Build the generator
 all: generator
 # generate the images
-images: $(GENERATED_IMAGES) $(GENERATED_IMAGES_RESIZED) $(STATIC_IMAGES)
+images: $(ALL_IMAGES)
+images-install: $(ALL_IMAGES)
+	mkdir -p $(DESTDIR)$(htmldir)/postgis/images
+	$(INSTALL_DATA) $(ALL_IMAGES) $(DESTDIR)$(htmldir)/postgis/images
+images-uninstall:
+	rm -f $(ALL_IMAGES:%=$(DESTDIR)$(htmldir)/postgis/images/%)
 # Command to build each of the .o files
 $(OBJS): %.o: %.c
@@ -258,6 +274,6 @@ distclean: clean
 	rm -f Makefile
 images-clean:
-	rm -f $(GENERATED_IMAGES) $(GENERATED_IMAGES_RESIZED) $(STATIC_IMAGES)
+	rm -f $(ALL_IMAGES)
 .NOTPARALLEL:
diff --git a/doc/po/de/Makefile.in b/doc/po/de/Makefile.in
index 31b255023..45674c100 100644
--- a/doc/po/de/Makefile.in
+++ b/doc/po/de/Makefile.in
@@ -1,3 +1,3 @@
-DOCSUFFIX=-de
 include @srcdir@/../Makefile.local
+DOCSUFFIX=-de
 srcdir=@srcdir@
diff --git a/doc/po/es/Makefile.in b/doc/po/es/Makefile.in
index 8aeaeb7ca..a2bbbc088 100644
--- a/doc/po/es/Makefile.in
+++ b/doc/po/es/Makefile.in
@@ -1,3 +1,3 @@
-DOCSUFFIX=-es
+DOCSUFFIX=-es
 srcdir=@srcdir@
diff --git a/doc/po/fr/Makefile.in b/doc/po/fr/Makefile.in
index 71cba94cf..a9f01f7e7 100644
--- a/doc/po/fr/Makefile.in
+++ b/doc/po/fr/Makefile.in
@@ -1,3 +1,3 @@
-DOCSUFFIX=-fr
+DOCSUFFIX=-fr
 srcdir=@srcdir@
diff --git a/doc/po/it_IT/Makefile.in b/doc/po/it_IT/Makefile.in
index 39baedf11..6d533871b 100644
--- a/doc/po/it_IT/Makefile.in
+++ b/doc/po/it_IT/Makefile.in
@@ -1,3 +1,3 @@
-DOCSUFFIX=-it
+DOCSUFFIX=-it
 srcdir=@srcdir@
diff --git a/doc/po/ja/Makefile.in b/doc/po/ja/Makefile.in
index 7d732fb41..ed5866283 100644
--- a/doc/po/ja/Makefile.in
+++ b/doc/po/ja/Makefile.in
@@ -1,3 +1,3 @@
-DOCSUFFIX=-ja
+DOCSUFFIX=-ja
 srcdir=@srcdir@
diff --git a/doc/po/ko_KR/Makefile.in b/doc/po/ko_KR/Makefile.in
index aedfe8c8e..d1cee468a 100644
--- a/doc/po/ko_KR/Makefile.in
+++ b/doc/po/ko_KR/Makefile.in
@@ -1,3 +1,3 @@
-DOCSUFFIX=-ko_KR
+DOCSUFFIX=-ko_KR
 srcdir=@srcdir@
diff --git a/doc/po/pl/Makefile.in b/doc/po/pl/Makefile.in
index 82370f7e3..e0ef7f45b 100644
--- a/doc/po/pl/Makefile.in
+++ b/doc/po/pl/Makefile.in
@@ -1,3 +1,3 @@
-DOCSUFFIX=-pl
+DOCSUFFIX=-pl
 srcdir=@srcdir@
diff --git a/doc/po/pt_BR/Makefile.in b/doc/po/pt_BR/Makefile.in
index 078a0c4f7..0dc6cd1cb 100644
--- a/doc/po/pt_BR/Makefile.in
+++ b/doc/po/pt_BR/Makefile.in
@@ -1,3 +1,3 @@
-DOCSUFFIX=-br
+DOCSUFFIX=-br
 srcdir=@srcdir@
diff --git a/doc/po/ru/Makefile.in b/doc/po/ru/Makefile.in
index f771bc430..64f0eaf9f 100644
--- a/doc/po/ru/Makefile.in
+++ b/doc/po/ru/Makefile.in
@@ -1,3 +1,3 @@
-DOCSUFFIX=-ru
+DOCSUFFIX=-ru
 srcdir=@srcdir@
Summary of changes:
 doc/Makefile.in             | 61 ++++++++++++++++++++++++++-------------------
 doc/html/images/Makefile.in | 20 +++++++++++++--
 doc/po/de/Makefile.in       |  2 +-
 doc/po/es/Makefile.in       |  2 +-
 doc/po/fr/Makefile.in       |  2 +-
 doc/po/it_IT/Makefile.in    |  2 +-
 doc/po/ja/Makefile.in       |  2 +-
 doc/po/ko_KR/Makefile.in    |  2 +-
 doc/po/pl/Makefile.in       |  2 +-
 doc/po/pt_BR/Makefile.in    |  2 +-
 doc/po/ru/Makefile.in       |  2 +-
 11 files changed, 63 insertions(+), 36 deletions(-)
hooks/post-receive
