[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1126-gffe3b4b74
Wed Jul 5 03:50:52 PDT 2023
the project "PostGIS".
       via  ffe3b4b749c8639c2b9d8dc139f5992248e833c1 (commit)
      from  578f3f959dd2ffc38727a15d2ca2ef02226839c1 (commit)
revisions in full, below.
commit ffe3b4b749c8639c2b9d8dc139f5992248e833c1
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 5 12:26:40 2023 +0200
    Don't rebuild chunked html if no sources change
    Uses docbook.css as a target, meaning chunked html will only be
    rebuilt if docbook.css is missing from target dir or any real
    dependency (xml, Makefile) is newer
    Add an html-clean rule to help clean builds
diff --git a/doc/Makefile.in b/doc/Makefile.in
index bfd78fbb5..fb4405f65 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -303,26 +303,29 @@ $(GENERATED_CHEATSHEET_FILES): html/%.html: xsl/%.html.xsl $(XML_INPUTS) postgis
 postgis-out.xml: postgis.xml Makefile
 	$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@
-chunked-html: postgis-out.xml Makefile $(XML_INPUTS)
+chunked-html: html/postgis$(DOCSUFFIX)/docbook.css
+html/postgis$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
 	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
 		$(XSLTPROC_CHUNKED_HTML_OPTS) \
-		--output html/postgis$(DOCSUFFIX)/ \
+		--output $(dir $@) \
 		$(CHUNK_HTML_DOCBOOK_XSL) \
-chunked-html-web: postgis-out.xml Makefile $(XML_INPUTS)
+chunked-html-web: html/postgis-web$(DOCSUFFIX)/docbook.css
+html/postgis-web$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
-		--output html/postgis-web$(DOCSUFFIX)/ \
 		--stringparam html.script ga.js \
 HTML_BITS = $(wildcard html/*.html)
-chunked-html-web-mobile: postgis-out.xml Makefile $(XML_INPUTS)
+chunked-html-web-mobile: html/postgis-web-mobile$(DOCSUFFIX)/docbook.css
+html/postgis-web-mobile$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
-		--output html/postgis-web-mobile$(DOCSUFFIX)/ \
@@ -400,8 +403,13 @@ doxygen: doxygen.cfg
 images images-install images-uninstall images-clean:
 	$(MAKE) -C html/images $@
-clean:
-	rm -rf html/postgis-*
+html-clean:
+	rm -f html/postgis$(DOCSUFFIX).html
+	rm -rf html/postgis$(DOCSUFFIX)/
+	rm -rf html/postgis-web$(DOCSUFFIX)/
+	rm -rf html/postgis-web-mobile$(DOCSUFFIX)/
+clean: html-clean
 	rm -f *.pdf
 	rm -f *.epub
 	rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
Summary of changes:
 doc/Makefile.in | 24 ++++++++++++++++--------
 1 file changed, 16 insertions(+), 8 deletions(-)
hooks/post-receive
