[postgis-tickets] [PostGIS] #5434: Doc build fails on first run when using Unicode symbol entities
PostGIS trac at osgeo.org
Wed Jul 5 12:54:05 PDT 2023
 Reporter:  mdavis         |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  medium         |  Milestone:  PostGIS 3.3.4
Component:  documentation  |    Version:  3.3.x
 Keywords:                 |
 The goal is to use Unicode symbols (specifically, in
 `reference_relationship.xml':
 ST_Crosses(A, B) ⇔ (dim( I(A) ∩ I(B) ) < max( dim(I(A), I(B)
 ))) ∧ (a ∩ b ≠ a) ∧ (a ∩ b ≠ b)
 On a clean install (running) `autogen` and then `configure`) the doc build
 fails:
 make chunked-html
 reference_relationship.xml:624: parser error : Entity 'hArr' not defined
 If I remove the symbols, `make chunked-html` again, add the symbols back,
 and make again - it works.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5434>
