[postgis-tickets] [PostGIS] #5434: Doc build fails on first run when using Unicode symbol entities
PostGIS trac at osgeo.org
Wed Jul 5 13:03:48 PDT 2023
  Reporter:  mdavis         |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.3.4
 Component:  documentation  |    Version:  3.3.x
Resolution:                 |   Keywords:
Comment (by strk):
 The failing command is:
 grep -v '\&postgis_special;' postgis-out.xml | /usr/bin/xsltproc --novalid
 --path /usr/src/postgis/postgis/doc:/usr/src/postgis/postgis/doc -o
 list_3d_functions.xsl.xml xsl/list_3d_functions.xml.xsl -
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5434#comment:1>
