[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1156-g4997d11b8
Wed Jul 5 15:14:15 PDT 2023
the project "PostGIS".
       via  4997d11b8291aacee7ce683539b61641252b5508 (commit)
       via  205cd178aaa07471eae515c6d63e076d4aaa2156 (commit)
       via  d48e41e3c684fb1333b8fd074f572e0b92e3728e (commit)
      from  491e945ab36fd76bc6b178e7c8f466466d5e284a (commit)
revisions in full, below.
commit 4997d11b8291aacee7ce683539b61641252b5508
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 6 00:13:46 2023 +0200
    Remove cheatsheet files on make clean
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 31be401c3..01b93c551 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -417,21 +417,22 @@ pdf-clean:
 epub-clean:
 	rm -f postgis*$(DOCSUFFIX).epub
-clean: html-clean html-clean-localized pdf-clean pdf-clean-localized epub-clean epub-clean-localized
+clean: images-clean html-clean html-clean-localized pdf-clean pdf-clean-localized epub-clean epub-clean-localized
 	rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
 	rm -f $(XML_GENERATED_SOURCES)
 	rm -f $(TAG_GENERATED_SOURCES)
 	$(MAKE) -C html/images clean
 	rm -f postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
 	rm -f raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
+	rm -f $(GENERATED_CHEATSHEET_FILES)
 	rm -f *.tmp
 	$(MAKE) clean-localized
 distclean: clean distclean-localized
 	$(MAKE) -C html/images distclean
-	rm -f Makefile Makefile.comments html/image_src/Makefile
+	rm -f Makefile Makefile.comments
-maintainer-clean: clean images-clean
+maintainer-clean: distclean
 	rm -f postgis_comments.sql raster_comments.sql topology_comments.sql tiger_geocoder_comments.sql sfcgal_comments.sql
 ifneq ($(CAN_BUILD_COMMENTS),yes)
commit 205cd178aaa07471eae515c6d63e076d4aaa2156
Date:   Thu Jul 6 00:08:38 2023 +0200
    Clean image symlink in localized dirs
diff --git a/doc/po/Makefile.local b/doc/po/Makefile.local
index 7936696d2..10807bd8b 100644
--- a/doc/po/Makefile.local
+++ b/doc/po/Makefile.local
@@ -5,6 +5,7 @@ local-all: local-html comments
 # We do not want to recurse in parent dir here
 local-clean:
+	rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
 	rm -f $(XML_INPUTS)
 	rm -f html
 	rm -f xsl
commit d48e41e3c684fb1333b8fd074f572e0b92e3728e
Date:   Thu Jul 6 00:07:17 2023 +0200
    Remove localized epub and pdf on make clean
    Closes #5431 again
index e4ecce37d..31be401c3 100644
@@ -411,9 +411,13 @@ html-clean:
 	rm -rf html/postgis-web$(DOCSUFFIX)/
 	rm -rf html/postgis-web-mobile$(DOCSUFFIX)/
-	rm -f *.pdf
-	rm -f *.epub
+pdf-clean:
+	rm -f postgis*$(DOCSUFFIX).pdf
+epub-clean:
+	rm -f postgis*$(DOCSUFFIX).epub
+clean: html-clean html-clean-localized pdf-clean pdf-clean-localized epub-clean epub-clean-localized
Summary of changes:
 doc/Makefile.in       | 15 ++++++++++-----
 doc/po/Makefile.local |  1 +
 2 files changed, 11 insertions(+), 5 deletions(-)
hooks/post-receive
