[postgis-tickets] [PostGIS] #5435: localize cheatsheets
PostGIS trac at osgeo.org
Wed Jul 5 15:24:15 PDT 2023
 Reporter:  robe           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  medium         |  Milestone:  PostGIS 3.5.0
Component:  documentation  |    Version:  master
 Keywords:                 |
 Pushing this for 3.5.0 no rush on it.
 The cheatsheets are generated using xls style sheets.
 https://postgis.net/docs//manual-3.4/postgis_cheatsheet.html
 https://postgis.net/docs//manual-3.4/topology_cheatsheet.html
 https://postgis.net/docs//manual-3.4/raster_cheatsheet.html
 https://postgis.net/docs//manual-3.4/sfcgal_cheatsheet.html
 https://postgis.net/docs//manual-3.4/tiger_geocoder_cheatsheet.html
 Since all of it except the top footnote detail part (which can be moved
 into maybe the xls-conf.xml) or refactored to use existing text.
 It should be doable.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5435>
