[postgis-tickets] [PostGIS] #5436: Can't compile master, getting docbook error on address standardizer
PostGIS trac at osgeo.org
Wed Jul 5 17:31:20 PDT 2023
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  3.3.x
 Keywords:                         |
 make[1]: Entering directory '/projects/postgis/postgis-git/doc'
 tag=tag_address_standardizer_required; \
 /projects/xsltproc/xmllint --xpath
 "/config/tags/para[@role='$tag']/node()" xsl-config.xml >
 address_standardizer_required.tag.tmp && \
 mv address_standardizer_required.tag.tmp address_standardizer_required.tag
 XPath error : Invalid expression
 C:/ming64gcc81/msys/config/tags/para[@role='tag_address_standardizer_required']/node()
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5436>
