[postgis-tickets] [PostGIS] #5436: Can't compile master, getting docbook error on address standardizer
PostGIS trac at osgeo.org
Thu Jul 6 05:46:18 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Old description:
> make[1]: Entering directory '/projects/postgis/postgis-git/doc'
> tag=tag_address_standardizer_required; \
> /projects/xsltproc/xmllint --xpath
> "/config/tags/para[@role='$tag']/node()" xsl-config.xml >
> address_standardizer_required.tag.tmp && \
> mv address_standardizer_required.tag.tmp
> XPath error : Invalid expression
> C:/ming64gcc81/msys/config/tags/para[@role='tag_address_standardizer_required']/node()
New description:
 mv address_standardizer_required.tag.tmp address_standardizer_required.tag
Comment (by strk):
 What version of xmllint do you have ?
 This works for me, from the top source dir with libxml version 20913
 (xmllint --version):
 xmllint --xpath "/config/tags/para[@role='tag_Z_support']" doc/xsl-
 config.xml
 It returns:
 <para role="tag_Z_support">
             <inlinemediaobject conformance="3d">
                <imageobject>
                  <imagedata fileref="images/check.png"/>
                </imageobject>
             </inlinemediaobject>
             This function supports 3d and will not drop the z-index.
         </para>
 Maybe we can implement what we need (extracting a tag by an XPath
 expression) via xsltproc, given we are already using that for other things
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5436#comment:1>
