[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1168-gd59c3c547
Thu Jul 6 07:53:26 PDT 2023
the project "PostGIS".
       via  d59c3c547b1eb074741fdd2af69c4388dfacb220 (commit)
      from  5b710eed2289d54af09b918343a4585d3ba7f18a (commit)
revisions in full, below.
commit d59c3c547b1eb074741fdd2af69c4388dfacb220
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 6 16:52:32 2023 +0200
    Move the common globalReplace template in a common file
    This is a first step toward cleanup of xsl, more common
    templates could be put in common files to include (I'm thinking
    mostly cheatsheets)
diff --git a/doc/xsl/common_utils.xsl b/doc/xsl/common_utils.xsl
new file mode 100644
index 000000000..03b4e5146
--- /dev/null
+++ b/doc/xsl/common_utils.xsl
@@ -0,0 +1,29 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
+<!--General replace macro hack to make up for the fact xsl 1.0 does not have a built in one.
+	Not needed for xsl 2.0 lifted from http://www.xml.com/pub/a/2002/06/05/transforming.html -->
+<xsl:template name="globalReplace">
+	<xsl:param name="outputString"/>
+	<xsl:param name="target"/>
+	<xsl:param name="replacement"/>
+	<xsl:choose>
+	<xsl:when test="contains($outputString,$target)">
+		<xsl:value-of select=
+		"concat(substring-before($outputString,$target),
+				 $replacement)"/>
+		<xsl:call-template name="globalReplace">
+		<xsl:with-param name="outputString"
+			 select="substring-after($outputString,$target)"/>
+		<xsl:with-param name="target" select="$target"/>
+		<xsl:with-param name="replacement"
+			 select="$replacement"/>
+		</xsl:call-template>
+	</xsl:when>
+	<xsl:otherwise>
+		<xsl:value-of select="$outputString"/>
+	</xsl:otherwise>
+	</xsl:choose>
+</xsl:template>
+</xsl:stylesheet>
diff --git a/doc/xsl/post_gis_day_cards.html.xsl b/doc/xsl/post_gis_day_cards.html.xsl
index 289219d21..27422d7e4 100644
--- a/doc/xsl/post_gis_day_cards.html.xsl
+++ b/doc/xsl/post_gis_day_cards.html.xsl
@@ -6,6 +6,7 @@
      License: BSD
 	 Purpose: This is an xsl transform that generates PostGIS flash cards
+	<xsl:include href="common_utils.xsl" />
 	<xsl:output method="text" />
 	<xsl:variable name='new_tag'>Availability: <xsl:value-of select="$postgis_version" /></xsl:variable>
 	<xsl:variable name='enhanced_tag'>Enhanced: <xsl:value-of select="$postgis_version" /></xsl:variable>
@@ -110,31 +111,6 @@ h1 {
 	<div class="card_separator"> </div>]]>
 </xsl:template>
-<!--General replace macro hack to make up for the fact xsl 1.0 does not have a built in one.
-	Not needed for xsl 2.0 lifted from http://www.xml.com/pub/a/2002/06/05/transforming.html -->
-	<xsl:template name="globalReplace">
-	  <xsl:param name="outputString"/>
-	  <xsl:param name="target"/>
-	  <xsl:param name="replacement"/>
-	  <xsl:choose>
-		<xsl:when test="contains($outputString,$target)">
-		  <xsl:value-of select=
-			"concat(substring-before($outputString,$target),
-				   $replacement)"/>
-		  <xsl:call-template name="globalReplace">
-			<xsl:with-param name="outputString"
-				 select="substring-after($outputString,$target)"/>
-			<xsl:with-param name="target" select="$target"/>
-			<xsl:with-param name="replacement"
-				 select="$replacement"/>
-		  </xsl:call-template>
-		</xsl:when>
-		<xsl:otherwise>
-		  <xsl:value-of select="$outputString"/>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
 <xsl:template name="break">
   <xsl:param name="text" select="."/>
   <xsl:choose>
diff --git a/doc/xsl/postgis_cheatsheet.html.xsl b/doc/xsl/postgis_cheatsheet.html.xsl
index d2ba4c239..2847a04bb 100644
--- a/doc/xsl/postgis_cheatsheet.html.xsl
+++ b/doc/xsl/postgis_cheatsheet.html.xsl
@@ -7,6 +7,9 @@
 	 Purpose: This is an xsl transform that generates PostgreSQL COMMENT ON FUNCTION ddl
 	 statements from postgis xml doc reference
@@ -223,30 +226,6 @@ code {font-size: 8pt}
 	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
diff --git a/doc/xsl/postgis_comments.sql.xsl b/doc/xsl/postgis_comments.sql.xsl
index 56ca5eb1c..a07319475 100644
--- a/doc/xsl/postgis_comments.sql.xsl
+++ b/doc/xsl/postgis_comments.sql.xsl
@@ -7,6 +7,8 @@
 	<!-- We deal only with the reference chapter -->
@@ -48,31 +50,6 @@ COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,' set')">AGGREGATE
 		</xsl:for-each>
 	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
 	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function.  -->
 	<xsl:template name="listparams">
 		<xsl:param name="func" />
diff --git a/doc/xsl/raster_cheatsheet.html.xsl b/doc/xsl/raster_cheatsheet.html.xsl
index f5f260f1d..84855c42c 100644
--- a/doc/xsl/raster_cheatsheet.html.xsl
+++ b/doc/xsl/raster_cheatsheet.html.xsl
@@ -7,6 +7,9 @@
@@ -195,31 +198,6 @@ code {font-size: 8pt}
 	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
   <xsl:choose>
diff --git a/doc/xsl/raster_comments.sql.xsl b/doc/xsl/raster_comments.sql.xsl
index bf9753e2d..9980cb88c 100644
--- a/doc/xsl/raster_comments.sql.xsl
+++ b/doc/xsl/raster_comments.sql.xsl
@@ -1,124 +1,102 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
-	 Copyright 2008, Regina Obe
-     License: BSD
-	 Purpose: This is an xsl transform that generates PostgreSQL COMMENT ON FUNCTION ddl
-	 statements from postgis xml doc reference for WKT Raster section
-	<xsl:output method="text" />
-	<!-- We deal only with the reference chapter -->
-        <xsl:template match="/">
-                <xsl:apply-templates select="/book/chapter[@id='RT_reference']" />
-                <xsl:apply-templates select="/book/chapter[@id='RT_reference']/sect1[contains(@id, 'Type')]" />
-        </xsl:template>
-        <xsl:template match="chapter">
-		<xsl:variable name="ap"><xsl:text>'</xsl:text></xsl:variable>
-<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
-		<xsl:for-each select="sect1[not(contains(@id,'Operator'))]/refentry">
-		  <xsl:variable name='plaincomment'>
-		  	<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
-		  </xsl:variable>
-<!-- Replace apostrophes with 2 apostrophes needed for escaping in SQL -->
-		<xsl:variable name='comment'>
-				<xsl:with-param name="outputString" select="$plaincomment"/>
-				<xsl:with-param name="target" select="$ap"/>
-				<xsl:with-param name="replacement" select="''"/>
-		</xsl:variable>
-<!-- For each function prototype generate the DDL comment statement
-	If its input is a geometry set - we know it is an aggregate function rather than a regular function.
-	Do not output OUT params since they define output rather than act as input and do not put a comma after argument just before an OUT parameter -->
-		<xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
-COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,'geometry set') or contains(paramdef/type,'raster set')">AGGREGATE</xsl:when><xsl:otherwise>FUNCTION</xsl:otherwise></xsl:choose><xsl:text> </xsl:text> <xsl:value-of select="funcdef/function" />(<xsl:for-each select="paramdef"><xsl:choose><xsl:when test="count(parameter) > 0">
-<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'geometry set')">geometry</xsl:when><xsl:when test="contains(type,'raster set')">raster</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
-</xsl:choose></xsl:for-each>) IS '<xsl:call-template name="listparams"><xsl:with-param name="func" select="." /></xsl:call-template> <xsl:value-of select='$comment' />';
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-	<xsl:template match="sect1[contains(@id, 'Type')]">
-        <xsl:for-each select="refentry">
-    <!-- If this is a raster type grab the ref entry summary and refname to make type comment -->
-            </xsl:variable>
-            <!-- Replace apostrophes with 2 apostrophes needed for escaping in SQL -->
-            </xsl:variable>
-    COMMENT ON TYPE <xsl:value-of select="refnamediv/refname" /> IS 'postgis raster type: <xsl:value-of select='$comment' />';
-        </xsl:for-each>
-	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
-       <xsl:template name="escapesinglequotes">
-        <xsl:param name="arg1"/>
-        <xsl:variable name="apostrophe">'</xsl:variable>
-        <xsl:choose>
-         <!-- this string has at least on single quote -->
-         <xsl:when test="contains($arg1, $apostrophe)">
-         <xsl:if test="string-length(normalize-space(substring-before($arg1, $apostrophe))) > 0"><xsl:value-of select="substring-before($arg1, $apostrophe)" disable-output-escaping="yes"/>''</xsl:if>
-          <xsl:call-template name="escapesinglequotes">
-           <xsl:with-param name="arg1"><xsl:value-of select="substring-after($arg1, $apostrophe)" disable-output-escaping="yes"/></xsl:with-param>
-         </xsl:when>
-         <!-- no quotes found in string, just print it -->
-         <xsl:when test="string-length(normalize-space($arg1)) > 0"><xsl:value-of select="normalize-space($arg1)"/></xsl:when>
-        </xsl:choose>
-       </xsl:template>
-	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function -->
-	<xsl:template name="listparams">
-		<xsl:param name="func" />
-		<xsl:for-each select="$func">
-			<xsl:if test="count(paramdef/parameter) > 0">args: </xsl:if>
-			<xsl:for-each select="paramdef">
-				<xsl:choose>
-				<xsl:when test="count(parameter) > 0">
-						<xsl:with-param name="arg1" select="parameter"/>
-				</xsl:when>
-				</xsl:choose>
-				<xsl:if test="position()<last()"><xsl:text>, </xsl:text></xsl:if>
-			</xsl:for-each>
-			<xsl:if test="count(paramdef/parameter) > 0"> - </xsl:if>
-		</xsl:for-each>
-	</xsl:template>
-</xsl:stylesheet>
+	 Copyright 2008, Regina Obe
+     License: BSD
+	 Purpose: This is an xsl transform that generates PostgreSQL COMMENT ON FUNCTION ddl
+	 statements from postgis xml doc reference for WKT Raster section
+	<xsl:output method="text" />
+	<!-- We deal only with the reference chapter -->
+        <xsl:template match="/">
+                <xsl:apply-templates select="/book/chapter[@id='RT_reference']" />
+                <xsl:apply-templates select="/book/chapter[@id='RT_reference']/sect1[contains(@id, 'Type')]" />
+        </xsl:template>
+        <xsl:template match="chapter">
+		<xsl:variable name="ap"><xsl:text>'</xsl:text></xsl:variable>
+<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
+		<xsl:for-each select="sect1[not(contains(@id,'Operator'))]/refentry">
+		  <xsl:variable name='plaincomment'>
+		  	<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
+		  </xsl:variable>
+<!-- Replace apostrophes with 2 apostrophes needed for escaping in SQL -->
+		<xsl:variable name='comment'>
+				<xsl:with-param name="outputString" select="$plaincomment"/>
+				<xsl:with-param name="target" select="$ap"/>
+				<xsl:with-param name="replacement" select="''"/>
+		</xsl:variable>
+<!-- For each function prototype generate the DDL comment statement
+	If its input is a geometry set - we know it is an aggregate function rather than a regular function.
+	Do not output OUT params since they define output rather than act as input and do not put a comma after argument just before an OUT parameter -->
+		<xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
+COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,'geometry set') or contains(paramdef/type,'raster set')">AGGREGATE</xsl:when><xsl:otherwise>FUNCTION</xsl:otherwise></xsl:choose><xsl:text> </xsl:text> <xsl:value-of select="funcdef/function" />(<xsl:for-each select="paramdef"><xsl:choose><xsl:when test="count(parameter) > 0">
+<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'geometry set')">geometry</xsl:when><xsl:when test="contains(type,'raster set')">raster</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
+</xsl:choose></xsl:for-each>) IS '<xsl:call-template name="listparams"><xsl:with-param name="func" select="." /></xsl:call-template> <xsl:value-of select='$comment' />';
+			</xsl:for-each>
+		</xsl:for-each>
+	</xsl:template>
+	<xsl:template match="sect1[contains(@id, 'Type')]">
+        <xsl:for-each select="refentry">
+    <!-- If this is a raster type grab the ref entry summary and refname to make type comment -->
+            </xsl:variable>
+            <!-- Replace apostrophes with 2 apostrophes needed for escaping in SQL -->
+            </xsl:variable>
+    COMMENT ON TYPE <xsl:value-of select="refnamediv/refname" /> IS 'postgis raster type: <xsl:value-of select='$comment' />';
+        </xsl:for-each>
+	</xsl:template>
+       <xsl:template name="escapesinglequotes">
+        <xsl:param name="arg1"/>
+        <xsl:variable name="apostrophe">'</xsl:variable>
+        <xsl:choose>
+         <!-- this string has at least on single quote -->
+         <xsl:when test="contains($arg1, $apostrophe)">
+         <xsl:if test="string-length(normalize-space(substring-before($arg1, $apostrophe))) > 0"><xsl:value-of select="substring-before($arg1, $apostrophe)" disable-output-escaping="yes"/>''</xsl:if>
+          <xsl:call-template name="escapesinglequotes">
+           <xsl:with-param name="arg1"><xsl:value-of select="substring-after($arg1, $apostrophe)" disable-output-escaping="yes"/></xsl:with-param>
+         </xsl:when>
+         <!-- no quotes found in string, just print it -->
+         <xsl:when test="string-length(normalize-space($arg1)) > 0"><xsl:value-of select="normalize-space($arg1)"/></xsl:when>
+        </xsl:choose>
+       </xsl:template>
+	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function -->
+	<xsl:template name="listparams">
+		<xsl:param name="func" />
+		<xsl:for-each select="$func">
+			<xsl:if test="count(paramdef/parameter) > 0">args: </xsl:if>
+			<xsl:for-each select="paramdef">
+				<xsl:choose>
+				<xsl:when test="count(parameter) > 0">
+						<xsl:with-param name="arg1" select="parameter"/>
+				</xsl:when>
+				</xsl:choose>
+				<xsl:if test="position()<last()"><xsl:text>, </xsl:text></xsl:if>
+			</xsl:for-each>
+			<xsl:if test="count(paramdef/parameter) > 0"> - </xsl:if>
+		</xsl:for-each>
+	</xsl:template>
+</xsl:stylesheet>
diff --git a/doc/xsl/sfcgal_cheatsheet.html.xsl b/doc/xsl/sfcgal_cheatsheet.html.xsl
index 4db22cadb..f29b3674f 100644
--- a/doc/xsl/sfcgal_cheatsheet.html.xsl
+++ b/doc/xsl/sfcgal_cheatsheet.html.xsl
@@ -7,6 +7,9 @@
@@ -172,31 +175,6 @@ h1 {
 	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
   <xsl:choose>
diff --git a/doc/xsl/sfcgal_comments.sql.xsl b/doc/xsl/sfcgal_comments.sql.xsl
index e08342cd6..db0046a47 100644
--- a/doc/xsl/sfcgal_comments.sql.xsl
+++ b/doc/xsl/sfcgal_comments.sql.xsl
@@ -1,85 +1,63 @@
-     License: BSD
-                <xsl:apply-templates select="/book/chapter[@id='reference']" />
-        </xsl:template>
-		<xsl:for-each select="sect1[@id='reference_sfcgal']/refentry">
-		  </xsl:variable>
-		</xsl:variable>
-COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,'geometry set')">AGGREGATE</xsl:when><xsl:otherwise>FUNCTION</xsl:otherwise></xsl:choose><xsl:text> </xsl:text> <xsl:value-of select="funcdef/function" />(<xsl:for-each select="paramdef"><xsl:choose><xsl:when test="count(parameter) > 0">
-<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'geometry set')">geometry</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
-	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function.  -->
-				<xsl:choose>
-						<xsl:value-of select="parameter" />
-					</xsl:when>
-				</xsl:choose>
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-</xsl:stylesheet>
+     License: BSD
+                <xsl:apply-templates select="/book/chapter[@id='reference']" />
+        </xsl:template>
+		<xsl:for-each select="sect1[@id='reference_sfcgal']/refentry">
+		  </xsl:variable>
+		</xsl:variable>
+COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,'geometry set')">AGGREGATE</xsl:when><xsl:otherwise>FUNCTION</xsl:otherwise></xsl:choose><xsl:text> </xsl:text> <xsl:value-of select="funcdef/function" />(<xsl:for-each select="paramdef"><xsl:choose><xsl:when test="count(parameter) > 0">
+<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'geometry set')">geometry</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
+			</xsl:for-each>
+		</xsl:for-each>
+	</xsl:template>
+	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function.  -->
+				<xsl:choose>
+						<xsl:value-of select="parameter" />
+					</xsl:when>
+				</xsl:choose>
+			</xsl:for-each>
+		</xsl:for-each>
+	</xsl:template>
+</xsl:stylesheet>
diff --git a/doc/xsl/tiger_geocoder_cheatsheet.html.xsl b/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
index 5e89afa95..29f7cd3e7 100644
--- a/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
+++ b/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
@@ -7,6 +7,9 @@
@@ -170,31 +173,6 @@ h1 {
 	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
   <xsl:choose>
diff --git a/doc/xsl/tiger_geocoder_comments.sql.xsl b/doc/xsl/tiger_geocoder_comments.sql.xsl
index d48d624a5..39468a0af 100644
--- a/doc/xsl/tiger_geocoder_comments.sql.xsl
+++ b/doc/xsl/tiger_geocoder_comments.sql.xsl
@@ -1,85 +1,63 @@
-     License: BSD
-                <xsl:apply-templates select="/book/chapter[@id='Extras']" />
-        </xsl:template>
-		<xsl:for-each select="sect1[@id='Tiger_Geocoder']/refentry">
-		  </xsl:variable>
-		</xsl:variable>
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
-				<xsl:choose>
-					</xsl:when>
-				</xsl:choose>
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-</xsl:stylesheet>
+     License: BSD
+                <xsl:apply-templates select="/book/chapter[@id='Extras']" />
+        </xsl:template>
+		<xsl:for-each select="sect1[@id='Tiger_Geocoder']/refentry">
+		  </xsl:variable>
+		</xsl:variable>
+			</xsl:for-each>
+		</xsl:for-each>
+	</xsl:template>
+				<xsl:choose>
+					</xsl:when>
+				</xsl:choose>
+			</xsl:for-each>
+		</xsl:for-each>
+	</xsl:template>
+</xsl:stylesheet>
diff --git a/doc/xsl/topology_cheatsheet.html.xsl b/doc/xsl/topology_cheatsheet.html.xsl
index b6a9c5abd..adf5eb36a 100644
--- a/doc/xsl/topology_cheatsheet.html.xsl
+++ b/doc/xsl/topology_cheatsheet.html.xsl
@@ -7,6 +7,9 @@
@@ -176,31 +179,6 @@ h1 {
 	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
   <xsl:choose>
diff --git a/doc/xsl/topology_comments.sql.xsl b/doc/xsl/topology_comments.sql.xsl
index d89fbc273..4c3092fb6 100644
--- a/doc/xsl/topology_comments.sql.xsl
+++ b/doc/xsl/topology_comments.sql.xsl
@@ -1,94 +1,72 @@
-     License: BSD
-                <xsl:apply-templates select="/book/chapter[@id='Topology']" />
-        </xsl:template>
-		  </xsl:variable>
-		</xsl:variable>
-		<xsl:choose>
-<!-- If this is a postgis type grab the ref entry summary and refname to make type comment -->
-<xsl:when test="parent::sect1[contains(@id,'Types')]">
-COMMENT ON TYPE topology.<xsl:value-of select="refnamediv/refname" /> IS 'postgis type: <xsl:value-of select='$comment' />';
-</xsl:when>
-<xsl:when test="parent::sect1[contains(@id,'Domain')]">
-COMMENT ON DOMAIN topology.<xsl:value-of select="refnamediv/refname" /> IS 'postgis domain: <xsl:value-of select='$comment' />';
-</xsl:when>
-		</xsl:choose>
-COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,' set')">AGGREGATE</xsl:when><xsl:otherwise>FUNCTION</xsl:otherwise></xsl:choose><xsl:text></xsl:text> topology.<xsl:value-of select="funcdef/function" />(<xsl:for-each select="paramdef"><xsl:choose><xsl:when test="count(parameter) > 0">
-<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'topoelement set')">topoelement</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-	  <xsl:choose>
-				   $replacement)"/>
-		</xsl:when>
-		<xsl:otherwise>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
-				<xsl:choose>
-					</xsl:when>
-				</xsl:choose>
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-</xsl:stylesheet>
+     License: BSD
+                <xsl:apply-templates select="/book/chapter[@id='Topology']" />
+        </xsl:template>
+		  </xsl:variable>
+		</xsl:variable>
+		<xsl:choose>
+<!-- If this is a postgis type grab the ref entry summary and refname to make type comment -->
+<xsl:when test="parent::sect1[contains(@id,'Types')]">
+COMMENT ON TYPE topology.<xsl:value-of select="refnamediv/refname" /> IS 'postgis type: <xsl:value-of select='$comment' />';
+</xsl:when>
+<xsl:when test="parent::sect1[contains(@id,'Domain')]">
+COMMENT ON DOMAIN topology.<xsl:value-of select="refnamediv/refname" /> IS 'postgis domain: <xsl:value-of select='$comment' />';
+</xsl:when>
+		</xsl:choose>
+COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,' set')">AGGREGATE</xsl:when><xsl:otherwise>FUNCTION</xsl:otherwise></xsl:choose><xsl:text></xsl:text> topology.<xsl:value-of select="funcdef/function" />(<xsl:for-each select="paramdef"><xsl:choose><xsl:when test="count(parameter) > 0">
+<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'topoelement set')">topoelement</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
+			</xsl:for-each>
+		</xsl:for-each>
+	</xsl:template>
+				<xsl:choose>
+					</xsl:when>
+				</xsl:choose>
+			</xsl:for-each>
+		</xsl:for-each>
+	</xsl:template>
+</xsl:stylesheet>
Summary of changes:
 doc/xsl/common_utils.xsl                   |  29 ++++
 doc/xsl/post_gis_day_cards.html.xsl        |  26 +---
 doc/xsl/postgis_cheatsheet.html.xsl        |  27 +---
 doc/xsl/postgis_comments.sql.xsl           |  27 +---
 doc/xsl/raster_cheatsheet.html.xsl         |  28 +---
 doc/xsl/raster_comments.sql.xsl            | 226 +++++++++++++----------------
 doc/xsl/sfcgal_cheatsheet.html.xsl         |  28 +---
 doc/xsl/sfcgal_comments.sql.xsl            | 148 ++++++++-----------
 doc/xsl/tiger_geocoder_cheatsheet.html.xsl |  28 +---
 doc/xsl/tiger_geocoder_comments.sql.xsl    | 148 ++++++++-----------
 doc/xsl/topology_cheatsheet.html.xsl       |  28 +---
 doc/xsl/topology_comments.sql.xsl          | 166 +++++++++------------
 12 files changed, 347 insertions(+), 562 deletions(-)
 create mode 100644 doc/xsl/common_utils.xsl
hooks/post-receive
