[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1169-gfa2b39876
Thu Jul 6 08:06:34 PDT 2023
the project "PostGIS".
       via  fa2b39876fd0a5e54b7fed0ce97dcd63d73afb03 (commit)
      from  d59c3c547b1eb074741fdd2af69c4388dfacb220 (commit)
revisions in full, below.
commit fa2b39876fd0a5e54b7fed0ce97dcd63d73afb03
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 6 17:02:05 2023 +0200
    Share common cheatsheet templates in a common file
    Templates list_in_param and break put there, there are
    probably more to move
diff --git a/doc/xsl/common_cheatsheet.xsl b/doc/xsl/common_cheatsheet.xsl
new file mode 100644
index 000000000..eaa0d3510
--- /dev/null
+++ b/doc/xsl/common_cheatsheet.xsl
@@ -0,0 +1,40 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
+<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function -->
+<xsl:template name="list_in_params">
+	<xsl:param name="func" />
+	<xsl:for-each select="$func">
+		<xsl:if test="count(paramdef/parameter)  > 0"> </xsl:if>
+		<xsl:for-each select="paramdef">
+			<xsl:choose>
+				<xsl:when test="not( contains(parameter, 'OUT') )">
+					<xsl:value-of select="parameter" />
+					<xsl:if test="position()<last()"><xsl:text>, </xsl:text></xsl:if>
+				</xsl:when>
+			</xsl:choose>
+		</xsl:for-each>
+	</xsl:for-each>
+</xsl:template>
+<xsl:template name="break">
+	<xsl:param name="text" select="."/>
+	<xsl:choose>
+		<xsl:when test="contains($text, '&#xa;')">
+			<xsl:value-of select="substring-before($text, '&#xa;')"/>
+			<![CDATA[<br/>]]>
+			<xsl:call-template name="break">
+				<xsl:with-param
+					name="text"
+					select="substring-after($text, '&#xa;')"
+			</xsl:call-template>
+		</xsl:when>
+		<xsl:otherwise>
+			<xsl:value-of select="$text"/>
+		</xsl:otherwise>
+	</xsl:choose>
+</xsl:template>
+</xsl:stylesheet>
diff --git a/doc/xsl/post_gis_day_cards.html.xsl b/doc/xsl/post_gis_day_cards.html.xsl
index 27422d7e4..6d369e65d 100644
--- a/doc/xsl/post_gis_day_cards.html.xsl
+++ b/doc/xsl/post_gis_day_cards.html.xsl
@@ -111,24 +111,4 @@ h1 {
 	<div class="card_separator"> </div>]]>
 </xsl:template>
-<xsl:template name="break">
-  <xsl:param name="text" select="."/>
-  <xsl:choose>
-    <xsl:when test="contains($text, '&#xa;')">
-      <xsl:value-of select="substring-before($text, '&#xa;')"/>
-      <![CDATA[<br/>]]>
-      <xsl:call-template name="break">
-        <xsl:with-param
-          name="text"
-          select="substring-after($text, '&#xa;')"
-      </xsl:call-template>
-    </xsl:when>
-    <xsl:otherwise>
-      <xsl:value-of select="$text"/>
-    </xsl:otherwise>
-  </xsl:choose>
-</xsl:template>
 </xsl:stylesheet>
diff --git a/doc/xsl/postgis_cheatsheet.html.xsl b/doc/xsl/postgis_cheatsheet.html.xsl
index 2847a04bb..01aa0952e 100644
--- a/doc/xsl/postgis_cheatsheet.html.xsl
+++ b/doc/xsl/postgis_cheatsheet.html.xsl
@@ -9,6 +9,7 @@
 	<xsl:include href="common_utils.xsl" />
+	<xsl:include href="common_cheatsheet.xsl" />
 	<xsl:output method="text" />
 	<xsl:variable name='new_tag'>Availability: <xsl:value-of select="$postgis_version" /></xsl:variable>
@@ -226,40 +227,4 @@ code {font-size: 8pt}
 	</xsl:template>
-  <xsl:choose>
-      <![CDATA[<br/>]]>
-        <xsl:with-param
-          name="text"
-    </xsl:when>
-    <xsl:otherwise>
-    </xsl:otherwise>
-  </xsl:choose>
-</xsl:template>
-<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function -->
-<xsl:template name="list_in_params">
-	<xsl:param name="func" />
-	<xsl:for-each select="$func">
-		<xsl:if test="count(paramdef/parameter)  > 0"> </xsl:if>
-		<xsl:for-each select="paramdef">
-			<xsl:choose>
-				<xsl:when test="not( contains(parameter, 'OUT') )">
-					<xsl:value-of select="parameter" />
-					<xsl:if test="position()<last()"><xsl:text>, </xsl:text></xsl:if>
-				</xsl:when>
-			</xsl:choose>
-		</xsl:for-each>
-	</xsl:for-each>
-</xsl:template>
 </xsl:stylesheet>
diff --git a/doc/xsl/raster_cheatsheet.html.xsl b/doc/xsl/raster_cheatsheet.html.xsl
index 84855c42c..f3a97ad0b 100644
--- a/doc/xsl/raster_cheatsheet.html.xsl
+++ b/doc/xsl/raster_cheatsheet.html.xsl
@@ -9,6 +9,7 @@
@@ -198,40 +199,4 @@ code {font-size: 8pt}
 	</xsl:template>
-  <xsl:choose>
-      <![CDATA[<br/>]]>
-        <xsl:with-param
-          name="text"
-    </xsl:when>
-    <xsl:otherwise>
-    </xsl:otherwise>
-  </xsl:choose>
-</xsl:template>
-			<xsl:choose>
-				</xsl:when>
-			</xsl:choose>
-		</xsl:for-each>
-	</xsl:for-each>
-</xsl:template>
 </xsl:stylesheet>
diff --git a/doc/xsl/sfcgal_cheatsheet.html.xsl b/doc/xsl/sfcgal_cheatsheet.html.xsl
index f29b3674f..ec3178861 100644
--- a/doc/xsl/sfcgal_cheatsheet.html.xsl
+++ b/doc/xsl/sfcgal_cheatsheet.html.xsl
@@ -9,6 +9,7 @@
@@ -175,39 +176,4 @@ h1 {
 	</xsl:template>
-  <xsl:choose>
-      <![CDATA[<br/>]]>
-        <xsl:with-param
-          name="text"
-    </xsl:when>
-    <xsl:otherwise>
-    </xsl:otherwise>
-  </xsl:choose>
-</xsl:template>
-			<xsl:choose>
-				</xsl:when>
-			</xsl:choose>
-		</xsl:for-each>
-	</xsl:for-each>
-</xsl:template>
 </xsl:stylesheet>
diff --git a/doc/xsl/tiger_geocoder_cheatsheet.html.xsl b/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
index 29f7cd3e7..43e8c8874 100644
--- a/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
+++ b/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
@@ -9,6 +9,7 @@
@@ -173,39 +174,4 @@ h1 {
 	</xsl:template>
-  <xsl:choose>
-      <![CDATA[<br/>]]>
-        <xsl:with-param
-          name="text"
-    </xsl:when>
-    <xsl:otherwise>
-    </xsl:otherwise>
-  </xsl:choose>
-</xsl:template>
-			<xsl:choose>
-				</xsl:when>
-			</xsl:choose>
-		</xsl:for-each>
-	</xsl:for-each>
-</xsl:template>
 </xsl:stylesheet>
diff --git a/doc/xsl/topology_cheatsheet.html.xsl b/doc/xsl/topology_cheatsheet.html.xsl
index adf5eb36a..8b4f42620 100644
--- a/doc/xsl/topology_cheatsheet.html.xsl
+++ b/doc/xsl/topology_cheatsheet.html.xsl
@@ -9,6 +9,7 @@
@@ -176,42 +177,6 @@ h1 {
 		 	</xsl:if>
 		 	<!--close section -->
 	</xsl:template>
-  <xsl:choose>
-      <![CDATA[<br/>]]>
-        <xsl:with-param
-          name="text"
-    </xsl:when>
-    <xsl:otherwise>
-    </xsl:otherwise>
-  </xsl:choose>
-</xsl:template>
-			<xsl:choose>
-				</xsl:when>
-			</xsl:choose>
-		</xsl:for-each>
-	</xsl:for-each>
-</xsl:template>
 </xsl:stylesheet>
Summary of changes:
 doc/xsl/common_cheatsheet.xsl              | 40 ++++++++++++++++++++++++++++++
 doc/xsl/post_gis_day_cards.html.xsl        | 20 ---------------
 doc/xsl/postgis_cheatsheet.html.xsl        | 37 +--------------------------
 doc/xsl/raster_cheatsheet.html.xsl         | 37 +--------------------------
 doc/xsl/sfcgal_cheatsheet.html.xsl         | 36 +--------------------------
 doc/xsl/tiger_geocoder_cheatsheet.html.xsl | 36 +--------------------------
 doc/xsl/topology_cheatsheet.html.xsl       | 37 +--------------------------
 7 files changed, 45 insertions(+), 198 deletions(-)
 create mode 100644 doc/xsl/common_cheatsheet.xsl
hooks/post-receive
