[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1170-gdbabd773b
Thu Jul 6 09:02:08 PDT 2023
the project "PostGIS".
       via  dbabd773bf56c6cb26e40d93638ea23ae82d1723 (commit)
      from  fa2b39876fd0a5e54b7fed0ce97dcd63d73afb03 (commit)
revisions in full, below.
commit dbabd773bf56c6cb26e40d93638ea23ae82d1723
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 6 18:01:38 2023 +0200
    Localize cheatsheet links to online manual
diff --git a/doc/Makefile.in b/doc/Makefile.in
index b48b8acdf..62bcc8433 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -75,7 +75,8 @@ XSLTPROC_PATH_OPT= \
 	--path $(XSLT_PATH)
 XSLTPROC_CUSTOM_VARS = \
-	--stringparam postgis_version $(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION)
+	--stringparam postgis_version $(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION) \
+	--stringparam postgis_language $(patsubst -%,%,$(DOCSUFFIX))/
 XSLTPROC_COMMONOPTS= \
 	$(XSLTPROC_PATH_OPT) \
diff --git a/doc/xsl/common_cheatsheet.xsl b/doc/xsl/common_cheatsheet.xsl
index eaa0d3510..acb56a102 100644
--- a/doc/xsl/common_cheatsheet.xsl
+++ b/doc/xsl/common_cheatsheet.xsl
@@ -1,6 +1,13 @@
 <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
+<xsl:variable name='new_tag'>Availability: <xsl:value-of select="$postgis_version" /></xsl:variable>
+<xsl:variable name='enhanced_tag'>Enhanced: <xsl:value-of select="$postgis_version" /></xsl:variable>
+<xsl:variable name='include_examples'>false</xsl:variable>
+<xsl:variable name='output_purpose'>true</xsl:variable>
+<xsl:variable name='linkstub'>https://postgis.net/docs/manual-<xsl:value-of select="$postgis_version" />/<xsl:value-of select="$postgis_language" /></xsl:variable>
 <!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function -->
 <xsl:template name="list_in_params">
 	<xsl:param name="func" />
diff --git a/doc/xsl/postgis_cheatsheet.html.xsl b/doc/xsl/postgis_cheatsheet.html.xsl
index 01aa0952e..a37d1c5ce 100644
--- a/doc/xsl/postgis_cheatsheet.html.xsl
+++ b/doc/xsl/postgis_cheatsheet.html.xsl
@@ -12,11 +12,6 @@
 	<xsl:include href="common_cheatsheet.xsl" />
 	<xsl:output method="text" />
-	<xsl:variable name='new_tag'>Availability: <xsl:value-of select="$postgis_version" /></xsl:variable>
-	<xsl:variable name='enhanced_tag'>Enhanced: <xsl:value-of select="$postgis_version" /></xsl:variable>
-	<xsl:variable name='include_examples'>false</xsl:variable>
-	<xsl:variable name='output_purpose'>true</xsl:variable>
-	<xsl:variable name='linkstub'>https://postgis.net/docs/manual-<xsl:value-of select="$postgis_version" />/</xsl:variable>
 <xsl:template match="/">
 	<xsl:text><![CDATA[<html>
diff --git a/doc/xsl/raster_cheatsheet.html.xsl b/doc/xsl/raster_cheatsheet.html.xsl
index f3a97ad0b..38ce371ba 100644
--- a/doc/xsl/raster_cheatsheet.html.xsl
+++ b/doc/xsl/raster_cheatsheet.html.xsl
@@ -12,11 +12,7 @@
 <head>
diff --git a/doc/xsl/sfcgal_cheatsheet.html.xsl b/doc/xsl/sfcgal_cheatsheet.html.xsl
index ec3178861..929347f90 100644
--- a/doc/xsl/sfcgal_cheatsheet.html.xsl
+++ b/doc/xsl/sfcgal_cheatsheet.html.xsl
@@ -12,11 +12,7 @@
 <head>
diff --git a/doc/xsl/tiger_geocoder_cheatsheet.html.xsl b/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
index 43e8c8874..44695479d 100644
--- a/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
+++ b/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
@@ -12,11 +12,7 @@
-	<xsl:variable name='include_examples'>true</xsl:variable>
-	<xsl:variable name='linkstub'>http://postgis.net/docs/manual-<xsl:value-of select="$postgis_version" />/</xsl:variable>
 <head>
diff --git a/doc/xsl/topology_cheatsheet.html.xsl b/doc/xsl/topology_cheatsheet.html.xsl
index 8b4f42620..fd9255de2 100644
--- a/doc/xsl/topology_cheatsheet.html.xsl
+++ b/doc/xsl/topology_cheatsheet.html.xsl
@@ -12,11 +12,6 @@
 <head>
Summary of changes:
 doc/Makefile.in                            | 3 ++-
 doc/xsl/common_cheatsheet.xsl              | 7 +++++++
 doc/xsl/postgis_cheatsheet.html.xsl        | 5 -----
 doc/xsl/raster_cheatsheet.html.xsl         | 6 +-----
 doc/xsl/sfcgal_cheatsheet.html.xsl         | 6 +-----
 doc/xsl/tiger_geocoder_cheatsheet.html.xsl | 6 +-----
 doc/xsl/topology_cheatsheet.html.xsl       | 5 -----
 7 files changed, 12 insertions(+), 26 deletions(-)
hooks/post-receive
