[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1172-g37b3c90b5
Thu Jul 6 14:52:34 PDT 2023
the project "PostGIS".
       via  37b3c90b52ae06ca94204ed1cb0e75f675eaa830 (commit)
      from  6770b653e62789c56053b575f27d5eeca6bced44 (commit)
revisions in full, below.
commit 37b3c90b52ae06ca94204ed1cb0e75f675eaa830
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Jul 6 14:52:33 2023 -0700
    Add doc math definitions for relations
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index b496161da..d26c9ad3d 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -431,6 +431,9 @@ ST_Point      | t          | t              | f           | f
         Equivalently, tests that no point of A lies outside (in the exterior of) B.
         </para>
+    <para>In mathematical terms:
+    <emphasis>ST_CoveredBy(A, B) ⇔ A ⋂ B = A </emphasis></para>
     <para>ST_CoveredBy is the converse of <xref linkend="ST_Covers"/>.
     So, <code>ST_CoveredBy(A,B) = ST_Covers(B,A)</code>.</para>
@@ -519,6 +522,9 @@ FROM (SELECT ST_Buffer(ST_GeomFromText('POINT(1 2)'), 10) As smallc,
             Equivalently, tests that no point of B lies outside (in the exterior of) A.
             </para>
+    <emphasis>ST_Covers(A, B) ⇔ A ⋂ B = B </emphasis></para>
     <para>ST_Covers is the converse of <xref linkend="ST_CoveredBy"/>.
     So, <code>ST_Covers(A,B) = ST_CoveredBy(B,A)</code>.</para>
@@ -615,10 +621,11 @@ SELECT ST_Covers(geog_poly, geog_pt) As poly_covers_pt,
     and must have dimension less than the maximum dimension
     of the two input geometries, and the intersection of the two
     geometries must not equal either geometry. Otherwise, it
-    returns <varname>false</varname>.</para>
+    returns <varname>false</varname>.
+    The crosses relation is symmetric and irreflexive.</para>
-    <emphasis>ST_Crosses(A, B) ⇔ (dim( Int(A) ⋂ Int(B) ) < max( dim( Int(A) ), dim( Int(B) ) )) ∧ (a ⋂ b ≠ a) ∧ (a ⋂ b ≠ b) </emphasis></para>
+    <emphasis>ST_Crosses(A, B) ⇔ (dim( Int(A) ⋂ Int(B) ) < max( dim( Int(A) ), dim( Int(B) ) )) ∧ (A ⋂ B ≠ A) ∧ (A ⋂ B ≠ B) </emphasis></para>
     <para>Geometries cross if their DE-9IM Intersection Matrix matches:</para>
@@ -776,9 +783,17 @@ WHERE ST_Crosses(roads.geom, highways.geom);</programlisting>
     </refsynopsisdiv>
     <refsection>
       <title>Description</title>
-      <para>Overlaps, Touches, Within all imply geometries are not spatially disjoint.  If any of the aforementioned
-        returns true, then the geometries are not spatially disjoint.
-        Disjoint implies false for spatial intersection.</para>
+      <para>Returns <varname>true</varname> if two geometries are disjoint.
+      Geometries are disjoint if they have no point in common.
+      </para>
+      <para>If any other spatial relationship is true for a pair of geometries, they are not disjoint.
+      Disjoint implies that <xref linkend="ST_Intersects"/> is false.
+      </para>
+    <emphasis>ST_Disjoint(A, B) ⇔ A ⋂ B = ∅ </emphasis></para>
     <important>
       <para role="enhanced" conformance="3.0.0">Enhanced: 3.0.0 enabled support for <varname>GEOMETRYCOLLECTION</varname></para>
@@ -841,14 +856,21 @@ SELECT ST_Disjoint('POINT(0 0)'::geometry, 'LINESTRING ( 0 0, 0 2 )'::geometry);
     <refsection>
-    <para>Returns <varname>true</varname> if the given geometries are "spatially
-      equal". Use this for a 'better' answer than '='.
-      Note by spatially equal we mean ST_Within(A,B) = true and ST_Within(B,A) = true and
-      also mean ordering of points can be different but
-      represent the same geometry structure.  To verify the order of points is consistent, use
-      ST_OrderingEquals (it must be noted ST_OrderingEquals is a little more stringent than simply verifying order of
+    <para>Returns <varname>true</varname> if the given geometries are "topologically equal".
+    Use this for a 'better' answer than '='.
+      Topological equality means that the geometries have the same dimension,
+      and their point-sets occupy the same space.
+      This means that the order of vertices may be different in topologically equal geometries.
+      To verify the order of points is consistent use
+      <xref linkend="ST_OrderingEquals"/> (it must be noted ST_OrderingEquals is a little more stringent than simply verifying order of
       points are the same).</para>
+    <emphasis>ST_Equals(A, B) ⇔ A = B </emphasis></para>
+    <para>The following relation holds:
+    <emphasis>ST_Equals(A, B) ⇔ ST_Within(A,B) ∧ ST_Within(B,A) </emphasis></para>
     <important>
     </important>
@@ -920,7 +942,7 @@ SELECT ST_Equals(ST_Reverse(ST_GeomFromText('LINESTRING(0 0, 10 10)')),
     </refsynopsisdiv>
     <refsection>
-      <para>Compares two geometries and returns <varname>true</varname> if they intersect.
+      <para>Returns <varname>true</varname> if two geometries intersect.
       Geometries intersect if they have any point in common.
       </para>
@@ -928,6 +950,9 @@ SELECT ST_Equals(ST_Reverse(ST_GeomFromText('LINESTRING(0 0, 10 10)')),
       For geography, a distance tolerance of 0.00001 meters is used
       (so points that are very close are considered to intersect).</para>
+    <emphasis>ST_Intersects(A, B) ⇔ A ⋂ B ≠ ∅ </emphasis></para>
     <para>Geometries intersect if their DE-9IM Intersection Matrix matches one of:
     </para>
@@ -1236,9 +1261,12 @@ SELECT ST_OrderingEquals(ST_Reverse(ST_GeomFromText('LINESTRING(0 0, 10 10)')),
     their interiors intersect in that dimension.
     and each has at least one point inside the other
     (or equivalently, neither one covers the other).
-    The overlaps relationship is symmetric and irreflexive.
+    The overlaps relation is symmetric and irreflexive.
     </para>
+    <emphasis>ST_Overlaps(A, B) ⇔ ( dim(A) = dim(B) = dim( Int(A) ⋂ Int(B) )) ∧ (A ⋂ B ≠ A) ∧ (A ⋂ B ≠ B) </emphasis></para>
     <note><para>&index_aware;
         To avoid index use, use the function <function>_ST_Overlaps</function>.</para></note>
@@ -1686,7 +1714,7 @@ SELECT pat.name AS relationship, pat.val AS pattern,
     since points do not have a boundary.</para>
-    <emphasis>ST_Touches(A, B) ⇔ (Int(A) ⋂ Int(B) ≠ ∅) ∧ (a ⋂ b ≠ ∅) </emphasis></para>
+    <emphasis>ST_Touches(A, B) ⇔ (Int(A) ⋂ Int(B) ≠ ∅) ∧ (A ⋂ B ≠ ∅) </emphasis></para>
     <para>This relationship holds if the DE-9IM Intersection Matrix for the two geometries matches one of:</para>
@@ -1836,8 +1864,12 @@ SELECT ST_Touches('LINESTRING(0 0, 1 1, 0 2)'::geometry, 'POINT(0 2)'::geometry)
     sense, the source geometries must both be of the same coordinate projection,
     having the same SRID.
     </para>
-    <para>The within relationship is reflexive: every geometry is within itself.
-    The relationship is antisymmetric: if <code>ST_Within(A,B) = true</code> and <code>ST_Within(B,A) = true</code>, then
+    <emphasis>ST_Within(A, B) ⇔ (A ⋂ B = A) ∧ (Int(A) ⋂ Int(B) ≠ ∅) </emphasis></para>
+    <para>The within relation is reflexive: every geometry is within itself.
+    The relation is antisymmetric: if <code>ST_Within(A,B) = true</code> and <code>ST_Within(B,A) = true</code>, then
     the two geometries must be topologically equal (<code>ST_Equals(A,B) = true</code>).</para>
     <para>ST_Within is the converse of <xref linkend="ST_Contains"/>.
Summary of changes:
 doc/reference_relationship.xml | 64 +++++++++++++++++++++++++++++++-----------
 1 file changed, 48 insertions(+), 16 deletions(-)
hooks/post-receive
