[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1173-g39c69beb3
Thu Jul 6 19:59:10 PDT 2023
the project "PostGIS".
       via  39c69beb3143c0e1ce10bec7d61a9d87b985d0fa (commit)
      from  37b3c90b52ae06ca94204ed1cb0e75f675eaa830 (commit)
revisions in full, below.
commit 39c69beb3143c0e1ce10bec7d61a9d87b985d0fa
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Jun 28 13:26:09 2023 -0400
    ST_AsSVG support for curves
     - Support circularstring,
       compoundcurve, multicurve,
       curvepolygon, multisurface
       in svg (absolute)
     - Relative work in progress
     - Update cu_out_svg.c moving curve examples from unsupported to
       test mode
     - Update docs to reflect curves now supported
     Closes #4913
     Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/130
diff --git a/NEWS b/NEWS
index 547948fde..5caf9df73 100644
--- a/NEWS
+++ b/NEWS
@@ -40,6 +40,8 @@ PostGIS 3.4.0dev
   - GH734, Additional metadata on Proj installation in postgis_proj_version (Paul Ramsey)
   - #5177, allow building tools without PostgreSQL server headers (Sandro Santilli)
   - ST_Project signature for geometry, and two-point signature (Paul Ramsey)
+  - #4913, ST_AsSVG support for curve types CircularString, CompoundCurve, MultiCurve,
+           and MultiSurface (Regina Obe)
 * Bug Fix *
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index 57e2dadd1..60389bbd1 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -1521,20 +1521,53 @@ FROM mvtgeom;
 			geometries are delimited by commas (","), GeometryCollection
 			geometries are delimited by semicolons (";").</para>
+        <para>For working with PostGIS SVG graphics, checkout <ulink url="https://github.com/dr-jts/pg_svg">pg_svg</ulink> library which
+        provides plpgsql functions for working with outputs from ST_AsSVG.</para>
+        <para role="enhanced" conformance="3.4.0">Enhanced: Support for curves added</para>
+		<para role="changed" conformance="2.0.0">Changed: 2.0.0 to use default args and support named args</para>
 		<note>
 		  <para role="availability" conformance="1.2.2.">Availability: 1.2.2. Availability: 1.4.0  Changed in PostGIS 1.4.0 to include L command in absolute path to conform to <ulink
 			url="http://www.w3.org/TR/SVG/paths.html#PathDataBNF">http://www.w3.org/TR/SVG/paths.html#PathDataBNF</ulink></para>
 		</note>
-		<para role="changed" conformance="2.0.0">Changed: 2.0.0 to use default args and support named args</para>
+        <para>&curve_support;</para>
 	  </refsection>
 	  <refsection>
 		<title>Examples</title>
-		<programlisting>SELECT ST_AsSVG('POLYGON((0 0,0 1,1 1,1 0,0 0))');
+		<programlisting>SELECT ST_AsSVG('POLYGON((0 0,0 1,1 1,1 0,0 0))'::geometry);
-		st_assvg
-		M 0 0 L 0 -1 1 -1 1 0 Z</programlisting>
+st_assvg
+M 0 0 L 0 -1 1 -1 1 0 Z</programlisting>
+        <para>Circular string</para>
+		<programlisting>SELECT ST_AsSVG( ST_GeomFromText('CIRCULARSTRING(-2 0,0 2,2 0,0 2,2 4)') );
+st_assvg
+M -2 0 A 2 2 0 0 1 2 0 A 2 2 0 0 1 2 -4</programlisting>
+        <para>Multi-curve</para>
+        <programlisting>SELECT ST_AsSVG('MULTICURVE((5 5,3 5,3 3,0 3),
+ CIRCULARSTRING(0 0,2 1,2 2))'::geometry, 0, 0);
+ st_assvg
+ M 5 -5 L 3 -5 3 -3 0 -3 M 0 0 A 2 2 0 0 0 2 -2
+ </programlisting>
+        <para>Multi-surface</para>
+        <programlisting>SELECT ST_AsSVG('MULTISURFACE(
+CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),
+    (-1 0,0 0.5,1 0,0 1,-1 0)),
+((7 8,10 10,6 14,4 11,7 8)))'::geometry, 0, 2);
+st_assvg
+M -2 0 A 1 1 0 0 0 0 0 A 1 1 0 0 0 2 0 A 2 2 0 0 0 -2 0 Z
+M -1 0 L 0 -0.5 1 0 0 -1 -1 0 Z
+M 7 -8 L 10 -10 6 -14 4 -11 Z
+ </programlisting>
 	  </refsection>
 	</refentry>
 		<refentry id="ST_AsTWKB">
diff --git a/liblwgeom/cunit/cu_out_svg.c b/liblwgeom/cunit/cu_out_svg.c
index 0d15dca43..2c2a945f3 100644
--- a/liblwgeom/cunit/cu_out_svg.c
+++ b/liblwgeom/cunit/cu_out_svg.c
@@ -189,41 +189,49 @@ static void out_svg_test_geoms(void)
 	    "cx=\"0\" cy=\"-1\";M 2 -3 L 4 -5",
 	    0, 0);
-	/* Empty GeometryCollection */
-	do_svg_test(
-	    "GEOMETRYCOLLECTION EMPTY",
-	    0, 0);
-	/* Nested GeometryCollection */
-	do_svg_unsupported(
-	    "GEOMETRYCOLLECTION(POINT(0 1),GEOMETRYCOLLECTION(LINESTRING(2 3,4 5)))",
-	    "assvg_geom_buf: 'GeometryCollection' geometry type not supported.");
 	/* CircularString */
+	do_svg_test(
 	    "CIRCULARSTRING(-2 0,0 2,2 0,0 2,2 4)",
-	    "lwgeom_to_svg: 'CircularString' geometry type not supported");
+	    "M -2 0 A 2 2 0 0 1 2 0 A 2 2 0 0 1 2 -4",
+			0, 0);
+	/* : Circle */
+	do_svg_test(
+	    "CIRCULARSTRING(4 2,-2 2,4 2)",
+	    "M 1 -2 m 3 0 a 3 3 0 1 0 -6 0 a 3 3 0 1 0 6 0",
+			0, 0);
 	/* CompoundCurve */
+	do_svg_test(
 	    "COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,0 1))",
-	    "lwgeom_to_svg: 'CompoundCurve' geometry type not supported");
-	/* CurvePolygon */
-	    "CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0))",
-	    "lwgeom_to_svg: 'CurvePolygon' geometry type not supported");
+	    "M 0 0 A 1 1 0 1 1 1 0 L 0 -1", 0, 0);
 	/* MultiCurve */
+	do_svg_test(
 	    "MULTICURVE((5 5,3 5,3 3,0 3),CIRCULARSTRING(0 0,2 1,2 2))",
-	    "lwgeom_to_svg: 'MultiCurve' geometry type not supported");
+	    "M 5 -5 L 3 -5 3 -3 0 -3 M 0 0 A 2 2 0 0 0 2 -2", 0, 0);
+	/* CurvePolygon */
+	do_svg_test(
+	    "CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0))",
+	    "M -2 0 A 1 1 0 0 0 0 0 A 1 1 0 0 0 2 0 A 2 2 0 0 0 -2 0 Z M -1 0 L 0 0 1 0 0 -1 -1 0 Z", 0, 0);
 	/* MultiSurface */
+	do_svg_test(
 	    "MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))",
-	    "lwgeom_to_svg: 'MultiSurface' geometry type not supported");
+	    "M -2 0 A 1 1 0 0 0 0 0 A 1 1 0 0 0 2 0 A 2 2 0 0 0 -2 0 Z M -1 0 L 0 0 1 0 0 -1 -1 0 Z M 7 -8 L 10 -10 6 -14 4 -11 Z", 0, 0);
+	/* Empty GeometryCollection */
+	do_svg_test(
+	    "GEOMETRYCOLLECTION EMPTY",
+	    0, 0);
+	/* Nested GeometryCollection */
+	do_svg_unsupported(
+	    "GEOMETRYCOLLECTION(POINT(0 1),GEOMETRYCOLLECTION(LINESTRING(2 3,4 5)))",
+	    "assvg_geom_buf: 'GeometryCollection' geometry type not supported.");
 static void out_svg_test_relative(void)
diff --git a/liblwgeom/lwout_svg.c b/liblwgeom/lwout_svg.c
index fc96c1634..c05efc355 100644
--- a/liblwgeom/lwout_svg.c
+++ b/liblwgeom/lwout_svg.c
@@ -41,7 +41,7 @@ assvg_geom(stringbuffer_t* sb, const LWGEOM *geom, int relative, int precision);
 static void
-pointArray_svg_rel(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int precision)
+pointArray_svg_rel(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int precision, int start_at_index)
 	int i, end;
 	const POINT2D *pt;
@@ -60,7 +60,7 @@ pointArray_svg_rel(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int
 	end = close_ring ? pa->npoints : pa->npoints - 1;
 	/* Starting point */
-	pt = getPoint2d_cp(pa, 0);
+	pt = getPoint2d_cp(pa, start_at_index);
 	x = round(pt->x*f)/f;
 	y = round(pt->y*f)/f;
@@ -75,7 +75,7 @@ pointArray_svg_rel(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int
 	accum_y = y;
 	/* All the following ones */
-	for (i = 1; i < end; i++)
+	for (i = (start_at_index + 1); i < end; i++)
 		pt = getPoint2d_cp(pa, i);
@@ -99,7 +99,7 @@ pointArray_svg_rel(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int
  * Returns maximum size of rendered pointarray in bytes.
 static void
-pointArray_svg_abs(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int precision)
+pointArray_svg_abs(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int precision, int start_at_index)
 	int i, end;
 	const POINT2D* pt;
@@ -108,11 +108,19 @@ pointArray_svg_abs(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int
-	for (i = 0; i < end; i++)
+	for (i = start_at_index; i < end; i++)
-		if (i == 1) stringbuffer_append(sb, " L ");
+		if (i == 1)
+			if (start_at_index > 0 ){
+					stringbuffer_append(sb, "L ");
+			else {
+					stringbuffer_append(sb, " L ");
 		else if (i) stringbuffer_append(sb, " ");
 		lwprint_double(pt->x, precision, sx);
@@ -146,11 +154,156 @@ assvg_line(stringbuffer_t* sb, const LWLINE *line, int relative, int precision)
 	/* Start path with SVG MoveTo */
 	stringbuffer_append(sb, "M ");
 	if (relative)
-		pointArray_svg_rel(sb, line->points, 1, precision);
+		pointArray_svg_rel(sb, line->points, 1, precision, 0);
 	else
-		pointArray_svg_abs(sb, line->points, 1, precision);
+		pointArray_svg_abs(sb, line->points, 1, precision, 0);
+static void pointArray_svg_arc(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int relative,  int precision)
+	uint32_t i; //, end;
+	char sx[OUT_DOUBLE_BUFFER_SIZE];
+	char sy[OUT_DOUBLE_BUFFER_SIZE];
+	LWDEBUG(2, "pointArray_svg_arc called.");
+	for (i = 2; i < pa->npoints; i+=2)
+		LWDEBUGF(3, "assvg_circstring: arc ending at point %d", i);
+		int largeArcFlag, sweepFlag, clockwise;
+		int is_circle = LW_FALSE;
+		double a1, a3;/**angles**/
+		double radius; /* Arc radius */
+		double total_angle;
+		POINT2D center;
+		const POINT2D *t1;
+		const POINT2D *t2;
+		const POINT2D *t3;
+		int p2_side = 0;
+		t1 = getPoint2d_cp(pa, i - 2);
+		t2 = getPoint2d_cp(pa, i - 1);
+		t3 = getPoint2d_cp(pa, i);
+		radius = lw_arc_center(t1, t2, t3, &center);
+		if ( t1->x == t3->x && t1->y == t3->y ){
+			is_circle = LW_TRUE;
+		p2_side = lw_segment_side(t1, t3, t2);
+		if ( p2_side == -1 )
+			clockwise = LW_TRUE;
+		else
+			clockwise = LW_FALSE;
+		/* Angles of each point that defines the arc section */
+		a1 = atan2(t1->y - center.y, t1->x - center.x)*180/M_PI;
+		//a2 = atan2(t2->y - center.y, t2->x - center.x)*180/M_PI;
+		a3 = atan2(t3->y - center.y, t3->x - center.x)*180/M_PI;
+		LWDEBUGF(2, " center is POINT(%.15g %.15g) - radius:%g", center.x, center.y, radius);
+		total_angle = clockwise ? a1 - a3 : a3 - a1;
+		if (total_angle < 0 ){
+			total_angle += 360;
+		//stringbuffer_aprintf(sb, "angles (a1 a2 a3): %g %g %g is_circle: %d, total_angle: %g, t1.x: %f, t3.x: %f, t1.y: %f, t3.y: %f ", a1, a2, a3, is_circle, total_angle, t1->x, t3->x, t1->y, t3->y);
+		/** endAngle - startAngle <= 180 ? "0" : "1" **/
+		largeArcFlag = (total_angle <= 180)? 0 : 1;
+		/* The side of the t1/t3 line that t2 falls on dictates the sweep
+		direction from t1 to t3. */
+		sweepFlag = (p2_side == -1) ? 1 : 0;
+		if ( (i == 2) && !is_circle ){
+			/** add MoveTo first point **/
+			lwprint_double(t1->x, precision, sx);
+			lwprint_double(-(t1->y), precision, sy);
+			stringbuffer_aprintf(sb, "%s %s", sx, sy);
+		/** is circle: need to start at center of circle **/
+		if ( (i == 2) && is_circle){
+			/** add MoveTo center of circle **/
+			lwprint_double(center.x, precision, sx);
+			lwprint_double(-(center.y), precision, sy);
+		lwprint_double(radius, precision, sx);
+		lwprint_double(0, precision, sy);
+		/** is circle need to handle differently **/
+		if (is_circle){
+			//https://stackoverflow.com/questions/5737975/circle-drawing-with-svgs-arc-path
+			lwprint_double(radius*2, precision, sy);
+			stringbuffer_aprintf(sb, " m %s 0 a %s %s 0 1 0 -%s 0", sx, sx, sx, sy);
+			stringbuffer_aprintf(sb, " a %s %s 0 1 0 %s 0", sx, sx, sy);
+		else {
+			/* Arc radius radius 0 arcflag swipeflag */
+			if (relative){
+				stringbuffer_aprintf(sb, " a %s %s 0 %d %d ", sx, sx, largeArcFlag, sweepFlag);
+			else {
+				stringbuffer_aprintf(sb, " A %s %s 0 %d %d ", sx, sx, largeArcFlag, sweepFlag);
+			lwprint_double(t3->x, precision, sx);
+			lwprint_double(-(t3->y), precision, sy);
+			/* end point */
+static void
+assvg_circstring(stringbuffer_t* sb, const LWCIRCSTRING *icurve, int relative, int precision)
+	/* Start path with SVG MoveTo */
+	stringbuffer_append(sb, "M ");
+	pointArray_svg_arc(sb, icurve->points, 1, relative, precision);
+static void
+assvg_compound(stringbuffer_t* sb, const LWCOMPOUND *icompound, int relative, int precision)
+	uint32_t i;
+	LWGEOM *geom;
+	LWCIRCSTRING *tmpc = NULL;
+	LWLINE *tmpl = NULL;
+	for (i = 0; i < icompound->ngeoms; i++)
+		if (i) stringbuffer_append(sb, " ");  /* SVG whitespace Separator */
+		geom = icompound->geoms[i];
+		switch (geom->type)
+			case CIRCSTRINGTYPE:
+				tmpc = (LWCIRCSTRING *)geom;
+				pointArray_svg_arc(sb, tmpc->points, 1, relative, precision);
+				break;
+			case LINETYPE:
+				tmpl = (LWLINE *)geom;
+				if (i){
+					/** if the compound curve does not start with a line,
+					 * we need to skip the first point since it is the same as previous
+					 * point of previous curve **/
+					if (relative)
+						pointArray_svg_rel(sb, tmpl->points, 1, precision, 1);
+					else
+						pointArray_svg_abs(sb, tmpl->points, 1, precision, 1);
+				else {
+					if (relative)
+						pointArray_svg_rel(sb, tmpl->points, 1, precision, 0);
+					else
+						pointArray_svg_abs(sb, tmpl->points, 1, precision, 0);
+				break;
+			default:
+				break; /** in theory this should never happen **/
 static void
 assvg_polygon(stringbuffer_t* sb, const LWPOLY *poly, int relative, int precision)
@@ -164,18 +317,17 @@ assvg_polygon(stringbuffer_t* sb, const LWPOLY *poly, int relative, int precisio
 		if (relative)
-			pointArray_svg_rel(sb, poly->rings[i], 0, precision);
+			pointArray_svg_rel(sb, poly->rings[i], 0, precision, 0);
 			stringbuffer_append(sb, " z");	/* SVG closepath */
 		else
-			pointArray_svg_abs(sb, poly->rings[i], 0, precision);
+			pointArray_svg_abs(sb, poly->rings[i], 0, precision, 0);
 			stringbuffer_append(sb, " Z");	/* SVG closepath */
 static void
 assvg_multipoint(stringbuffer_t* sb, const LWMPOINT *mpoint, int relative, int precision)
@@ -205,7 +357,6 @@ assvg_multiline(stringbuffer_t* sb, const LWMLINE *mline, int relative, int prec
 static void
 assvg_multipolygon(stringbuffer_t* sb, const LWMPOLY *mpoly, int relative, int precision)
@@ -218,9 +369,104 @@ assvg_multipolygon(stringbuffer_t* sb, const LWMPOLY *mpoly, int relative, int p
 		poly = mpoly->geoms[i];
 		assvg_polygon(sb, poly, relative, precision);
+static void
+assvg_multicurve(stringbuffer_t* sb, const LWMCURVE *mcurve, int relative, int precision)
+	uint32_t i;
+	LWGEOM *geom;
+	const LWCIRCSTRING *tmpc = NULL;
+	const LWLINE *tmpl = NULL;
+	for (i = 0; i < mcurve->ngeoms; i++)
+		geom = mcurve->geoms[i];
+				assvg_circstring(sb, tmpc, relative, precision);
+				break;
+			case LINETYPE:
+				assvg_line(sb, tmpl, relative, precision);
+				break;
+			default:
+static void
+assvg_curvepoly(stringbuffer_t* sb, const LWCURVEPOLY *curvepoly, int relative, int precision)
+	uint32_t i;
+	LWGEOM *tmp;
+	for (i = 0; i < curvepoly->nrings; i++)
+		if (i) stringbuffer_append(sb, " ");	/* Space between each ring */
+		tmp = curvepoly->rings[i];
+		switch (tmp->type)
+				assvg_circstring(sb, (LWCIRCSTRING *)tmp, relative, precision);
+				break;
+			case LINETYPE:
+				assvg_line(sb, (LWLINE *)tmp, relative, precision);
+				break;
+			case COMPOUNDTYPE:
+				assvg_compound(sb, (LWCOMPOUND *)tmp, relative, precision);
+				break;
+			default:
+		if (relative)
+			stringbuffer_append(sb, " z");	/* SVG closepath */
+		else
+			stringbuffer_append(sb, " Z");	/* SVG closepath */
+static void
+assvg_multisurface(stringbuffer_t* sb, const LWMSURFACE *msurface, int relative, int precision)
+	LWGEOM *geom;
+	uint32_t i;
+	const LWPOLY *poly;
+	const LWCURVEPOLY *curvepoly;
+	for (i = 0; i < msurface->ngeoms; i++)
+		geom = msurface->geoms[i];
+			case CURVEPOLYTYPE:
+				curvepoly = (LWCURVEPOLY *) geom;
+				assvg_curvepoly(sb, curvepoly, relative, precision);
+				break;
+			case POLYGONTYPE:
+				poly = (LWPOLY *) geom;
+				assvg_polygon(sb, poly, relative, precision);
+				break;
+			default:
 static void
 assvg_collection(stringbuffer_t* sb, const LWCOLLECTION *col, int relative, int precision)
@@ -279,6 +525,26 @@ assvg_geom(stringbuffer_t* sb, const LWGEOM *geom, int relative, int precision)
 		assvg_multipolygon(sb, (LWMPOLY*)geom, relative, precision);
 		break;
+		assvg_circstring(sb, (LWCIRCSTRING*)geom, relative, precision);
+		break;
+		assvg_compound(sb, (LWCOMPOUND*)geom, relative, precision);
+		break;
+		assvg_curvepoly(sb, (LWCURVEPOLY*)geom, relative, precision);
+		break;
+	case MULTICURVETYPE:
+		assvg_multicurve(sb, (LWMCURVE*)geom, relative, precision);
+		break;
+	case MULTISURFACETYPE:
+		assvg_multisurface(sb, (LWMSURFACE*)geom, relative, precision);
+		break;
 	default:
 		lwerror("assvg_geom_buf: '%s' geometry type not supported.",
 		        lwtype_name(type));
@@ -286,9 +552,6 @@ assvg_geom(stringbuffer_t* sb, const LWGEOM *geom, int relative, int precision)
  * Takes a GEOMETRY and returns a SVG representation
@@ -319,15 +582,30 @@ lwgeom_to_svg(const LWGEOM *geom, int precision, int relative)
 	case POLYGONTYPE:
 		assvg_polygon(&sb, (LWPOLY*)geom, relative, precision);
 		break;
+		assvg_circstring(&sb, (LWCIRCSTRING*)geom, relative, precision);
+		break;
+		assvg_compound(&sb, (LWCOMPOUND*)geom, relative, precision);
+		break;
+		assvg_curvepoly(&sb, (LWCURVEPOLY*)geom, relative, precision);
+		break;
 	case MULTIPOINTTYPE:
 		assvg_multipoint(&sb, (LWMPOINT*)geom, relative, precision);
 		break;
 	case MULTILINETYPE:
 		assvg_multiline(&sb, (LWMLINE*)geom, relative, precision);
 		break;
+		assvg_multicurve(&sb, (LWMCURVE*)geom, relative, precision);
+		break;
 	case MULTIPOLYGONTYPE:
 		assvg_multipolygon(&sb, (LWMPOLY*)geom, relative, precision);
 		break;
+		assvg_multisurface(&sb, (LWMSURFACE*)geom, relative, precision);
+		break;
 	case COLLECTIONTYPE:
 		assvg_collection(&sb, (LWCOLLECTION*)geom, relative, precision);
 		break;
Summary of changes:
 NEWS                         |   2 +
 doc/reference_output.xml     |  43 +++++-
 liblwgeom/cunit/cu_out_svg.c |  56 ++++----
 liblwgeom/lwout_svg.c        | 308 ++++++++++++++++++++++++++++++++++++++++---
 4 files changed, 365 insertions(+), 44 deletions(-)
hooks/post-receive
