[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1177-g43880f9ab
Fri Jul 7 08:10:18 PDT 2023
the project "PostGIS".
       via  43880f9abf66d9d5c17f8374a4c6de781fe76a72 (commit)
      from  c2542df35da0fb088dff14b629823e9a793d9f58 (commit)
revisions in full, below.
commit 43880f9abf66d9d5c17f8374a4c6de781fe76a72
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Jul 7 08:09:29 2023 -0700
    Upgrade ST_Contour to respect the polygonize parameter,
    passing it on to the GDAL contouring routine. Add support
    for user interruption of contouring, since with polygonization
    the process can run quite a long time.
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index c5f3f94d9..6912089ee 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -1353,11 +1353,6 @@ WHERE short_name = 'GTiff') As g;
             When the <varname>fixed_levels</varname> parameter is a non-empty
             array, the <varname>level_interval</varname> and <varname>level_base</varname> parameters are ignored.
         </para>
-        <para>
-            The <varname>polygonize</varname> parameter currently has no effect.
-            Use the <link linkend="ST_Polygonize">ST_Polygonize</link> function
-            to convert contours into polygons.
-        </para>
         <para>
             Return values are a set of records with the following attributes:
         </para>
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index 353c107c1..e9dc77bb5 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -1201,8 +1201,6 @@ GSERIALIZED* gserialized2_from_lwgeom(LWGEOM *geom, size_t *size)
 	return g;
-// xxxx continue reviewing extended flags content from here
 * De-serialize GSERIALIZED into an LWGEOM.
diff --git a/raster/rt_core/librtcore.h b/raster/rt_core/librtcore.h
index 7014e4f53..8f4cd82b1 100644
--- a/raster/rt_core/librtcore.h
+++ b/raster/rt_core/librtcore.h
@@ -121,7 +121,7 @@
 #include <float.h> /* for FLT_EPSILON, DBL_EPSILON and float type limits */
 #include <limits.h> /* for integer type limits */
-#include "liblwgeom.h"
+#include "liblwgeom_internal.h"
 #include "gdal.h"
 #include "gdalgrid.h" /* for ParseAlgorithmAndOptions */
@@ -2335,6 +2335,13 @@ GDALDatasetH
 rt_util_gdal_open(const char *fn, GDALAccess fn_access, int shared);
+    Callback for GDAL functions to hook into interrupt system
+int
+rt_util_gdal_progress_func(double dfComplete, const char *pszMessage, void *pProgressArg);
 void
 rt_util_from_ogr_envelope(
 	OGREnvelope	env,
diff --git a/raster/rt_core/rt_gdal.c b/raster/rt_core/rt_gdal.c
index 2b5fbe9c3..1d12d7dcc 100644
--- a/raster/rt_core/rt_gdal.c
+++ b/raster/rt_core/rt_gdal.c
@@ -26,9 +26,10 @@
 #include "librtcore.h"
 #include "librtcore_internal.h"
+#include "stringbuffer.h"
-* rt_raster_gdal_warp()
+* rt_raster_gdal_contour()
 typedef struct
@@ -50,6 +51,28 @@ typedef struct
 } _rti_contour_arg;
+/*  GDAL progress callback for interrupt handling */
+int rt_util_gdal_progress_func(
+	double dfComplete,
+	const char *pszMessage,
+	void *pProgressArg)
+	(void)dfComplete;
+	(void)pszMessage;
+	if (_lwgeom_interrupt_requested)
+		// rtwarn("%s interrupted at %g", (const char*)pProgressArg, dfComplete);
+		_lwgeom_interrupt_requested = 0;
+		return FALSE;
+	else
+		return TRUE;
 static void
 _rti_contour_arg_init(_rti_contour_arg* arg)
@@ -80,9 +103,11 @@ _rti_contour_arg_destroy(_rti_contour_arg* arg)
  * Return palloc'ed list of contours.
  * @param src_raster : raster to generate contour from
+ * @param src_band : band to use as input
+ * @param src_srid : srid of raster
+ * @param src_srs : Coordinate reference system string for raster
  * @param options : CSList of OPTION=VALUE strings for the
  *   contour routine, see https://gdal.org/api/gdal_alg.html?highlight=contour#_CPPv419GDALContourGenerate15GDALRasterBandHddiPdidPvii16GDALProgressFuncPv
- * @param src_srs : Coordinate reference system string for raster
  * @param ncontours : Output parameter for length of contour list
  * @param contours : Output palloc'ed list of contours, caller to free
@@ -108,6 +133,10 @@ int rt_raster_gdal_contour(
 	int nfeatures = 0, i = 0;
 	OGRFeatureH hFeat;
+	/* For building out options list */
+	stringbuffer_t sb;
+	char **papszOptList = NULL;
 	_rti_contour_arg arg;
 	_rti_contour_arg_init(&arg);
@@ -150,29 +179,80 @@ int rt_raster_gdal_contour(
 	if (ogrerr != OGRERR_NONE)
 		return _rti_contour_arg_destroy(&arg);
-	// GDALContourGenerate( GDALRasterBandH hBand,
-	//   double dfContourInterval, double dfContourBase,
-	//   int nFixedLevelCount, double *padfFixedLevels,
-	//   int bUseNoData, double dfNoDataValue,
-	//   void *hLayer, int iIDField, int iElevField,
-	//   GDALProgressFunc pfnProgress, void *pProgressArg );
 	int use_no_data = 0;
-	double no_data_value = GDALGetRasterNoDataValue(hBand, &use_no_data);;
+	double no_data_value = GDALGetRasterNoDataValue(hBand, &use_no_data);
+	// LEVEL_INTERVAL=f
+	//   The elevation interval between contours generated.
+	// LEVEL_BASE=f
+	//   The "base" relative to which contour intervals are applied. This is normally zero, but could be different. To generate 10m contours at 5, 15, 25, ... the LEVEL_BASE would be 5.
+	// LEVEL_EXP_BASE=f
+	//   If greater than 0, contour levels are generated on an exponential scale. Levels will then be generated by LEVEL_EXP_BASE^k where k is a positive integer.
+	// FIXED_LEVELS=f[,f]*
+	//   The list of fixed contour levels at which contours should be generated. This option has precedence on LEVEL_INTERVAL
+	// NODATA=f
+	//   The value to use as a "nodata" value. That is, a pixel value which should be ignored in generating contours as if the value of the pixel were not known.
+	// ID_FIELD=d
+	//   This will be used as a field index to indicate where a unique id should be written for each feature (contour) written.
+	// ELEV_FIELD=d
+	//   This will be used as a field index to indicate where the elevation value of the contour should be written. Only used in line contouring mode.
+	// ELEV_FIELD_MIN=d
+	//   This will be used as a field index to indicate where the minimum elevation value of the polygon contour should be written. Only used in polygonal contouring mode.
+	// ELEV_FIELD_MAX=d
+	//   This will be used as a field index to indicate where the maximum elevation value of the polygon contour should be written. Only used in polygonal contouring mode.
+	// POLYGONIZE=YES|NO
+	/* Options strings list */
+	stringbuffer_init(&sb);
+	if (use_no_data)
+		stringbuffer_aprintf(&sb, "NODATA=%g ", no_data_value);
+	if (fixed_level_count > 0) {
+		int i = 0;
+		stringbuffer_append(&sb, "FIXED_LEVELS=");
+		for (i = 0; i < fixed_level_count; i++) {
+			if (i) stringbuffer_append_char(&sb, ',');
+			stringbuffer_aprintf(&sb, "%g", fixed_levels[i]);
+		stringbuffer_append_char(&sb, ' ');
+	else {
+		stringbuffer_aprintf(&sb, "LEVEL_INTERVAL=%g ", contour_interval);
+		stringbuffer_aprintf(&sb, "LEVEL_BASE=%g ", contour_base);
+	stringbuffer_aprintf(&sb, "ID_FIELD=%d ", 0);
+	stringbuffer_aprintf(&sb, "ELEV_FIELD=%d ", 1);
+	stringbuffer_aprintf(&sb, "POLYGONIZE=%s ", polygonize ? "YES" : "NO");
+	papszOptList = CSLTokenizeString(stringbuffer_getstring(&sb));
+	// CPLSetConfigOption("OGR_GEOMETRY_ACCEPT_UNCLOSED_RING", "NO");
 	/* Run the contouring routine, filling up the OGR layer */
-	cplerr = GDALContourGenerate(
+	cplerr = GDALContourGenerateEx(
 		hBand,
-		contour_interval, contour_base,
-		fixed_level_count, fixed_levels,
-		use_no_data, no_data_value,
-		arg.dst.lyr, 0, 1, // OGRLayer, idFieldNum, elevFieldNum
-		NULL,              // GDALProgressFunc pfnProgress
-		NULL               // void *pProgressArg
+		arg.dst.lyr,
+		papszOptList,      // Options
+		rt_util_gdal_progress_func,  // GDALProgressFunc pfnProgress
+		(void*)"GDALContourGenerateEx" // void *pProgressArg
-	if (cplerr != CE_None)
-		return _rti_contour_arg_destroy(&arg);
+	// /* Run the contouring routine, filling up the OGR layer */
+	// cplerr = GDALContourGenerate(
+	// 	hBand,
+	// 	contour_interval, contour_base,
+	// 	fixed_level_count, fixed_levels,
+	// 	use_no_data, no_data_value,
+	// 	arg.dst.lyr, 0, 1, // OGRLayer, idFieldNum, elevFieldNum
+	// 	NULL,              // GDALProgressFunc pfnProgress
+	// 	NULL               // void *pProgressArg
+	if (cplerr >= CE_Failure) {
+		return _rti_contour_arg_destroy(&arg); // FALSE
 	/* Convert the OGR layer into PostGIS geometries */
 	nfeatures = OGR_L_GetFeatureCount(arg.dst.lyr, TRUE);
@@ -214,6 +294,7 @@ int rt_raster_gdal_contour(
 	/* Free all the non-database allocated structures */
+	stringbuffer_release(&sb);
 	/* Done */
 	return TRUE;
diff --git a/raster/rt_pg/rtpg_gdal.c b/raster/rt_pg/rtpg_gdal.c
index 9a982f36e..039ea61d5 100644
--- a/raster/rt_pg/rtpg_gdal.c
+++ b/raster/rt_pg/rtpg_gdal.c
@@ -582,8 +582,7 @@ Datum RASTER_Contour(PG_FUNCTION_ARGS)
 		/* No-op on bad return */
 		if (rv == FALSE) {
-			funcctx = SRF_PERCALL_SETUP();
-			SRF_RETURN_DONE(funcctx);
+			PG_RETURN_NULL();
 		funcctx->user_fctx = result;
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index d591f2c7d..7ae30b93e 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -129,18 +129,26 @@
  *   datum is copied for use.
-#include <postgres.h> /* for palloc */
-#include <fmgr.h> /* for PG_MODULE_MAGIC */
+/* PostgreSQL */
+#include "postgres.h" /* for palloc */
+#include "fmgr.h" /* for PG_MODULE_MAGIC */
+#include "libpq/pqsignal.h"
 #include "utils/guc.h"
+#include "utils/builtins.h"
 #include "utils/memutils.h"
+#include "utils/elog.h"
-#include "../../postgis_config.h"
+/* PostGIS */
+#include "postgis_config.h"
+#include "liblwgeom.h"
 #include "lwgeom_pg.h"
+#include "stringlist.h"
+#include "optionlist.h"
+/* PostGIS Raster */
 #include "rtpostgis.h"
 #include "rtpg_internal.h"
-#include "stringlist.h"
-#include "optionlist.h"
 #ifndef __GNUC__
 # define __attribute__ (x)
@@ -638,6 +646,48 @@ rtpg_assignHookEnableOutDBRasters(bool enable, void *extra) {
+* Machinery for intercepting the system SIGINT
+* handler so we can cancel long-running GDAL operations
+* via the progress handlers.
+static pqsigfunc coreIntHandler = 0;
+#ifdef WIN32
+static void interruptCallback() {
+  if (UNBLOCKED_SIGNAL_QUEUE())
+    pgwin32_dispatch_queued_signals();
+#endif
+* This is the interrupt capture for this module.
+* Before handing off the signal to the core, it
+* sets the interrupt flag for currently running
+* functions.
+static void
+handleInterrupt(int sig)
+	* NOTE: printf here would be dangerous, see
+	* https://trac.osgeo.org/postgis/ticket/3644
+	// printf("postgis_raster interrupt requested\n"); fflush(stdout);
+	/* Request interruption of liblwgeom as well */
+	lwgeom_request_interrupt();
+	/* Pass control into the usual core handler */
+	if (coreIntHandler) {
+		(*coreIntHandler)(sig);
 /* Module load callback */
 void
 _PG_init(void) {
@@ -645,6 +695,15 @@ _PG_init(void) {
 	bool boot_postgis_enable_outdb_rasters = false;
 	MemoryContext old_context;
+	/* Set up interrupt capture */
+	coreIntHandler = pqsignal(SIGINT, handleInterrupt);
+#ifdef WIN32
+ 	GEOS_interruptRegisterCallback(interruptCallback);
+ 	lwgeom_register_interrupt_callback(interruptCallback);
+#endif
 	 * Change to context for memory allocation calls like palloc() in the
 	 * extension initialization routine
@@ -804,9 +863,12 @@ _PG_init(void) {
 void
 _PG_fini(void) {
-	MemoryContext old_context;
+	MemoryContext old_context = MemoryContextSwitchTo(TopMemoryContext);
-	old_context = MemoryContextSwitchTo(TopMemoryContext);
+	elog(NOTICE, "Goodbye from PostGIS Raster %s", POSTGIS_VERSION);
+	/* Return SIGINT handling to core */
+	pqsignal(SIGINT, coreIntHandler);
 	/* Clean up */
 	pfree(env_postgis_gdal_enabled_drivers);
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index 041f9d034..e85e7ee9a 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -21,18 +21,19 @@
  * Copyright 2012-2020 Oslandia <infos at oslandia.com>
 #include "SFCGAL/capi/sfcgal_c.h"
 #include "fmgr.h"
+#include "utils/guc.h"
 #include "lwgeom_sfcgal.h"
 #include "../postgis_config.h"
-#include "utils/elog.h"
-#include "utils/guc.h"
-#include "libpq/pqsignal.h"
 #include "../liblwgeom/liblwgeom.h"
Summary of changes:
 doc/reference_raster.xml   |   5 --
 liblwgeom/gserialized2.c   |   2 -
 raster/rt_core/librtcore.h |   9 +++-
 raster/rt_core/rt_gdal.c   | 119 +++++++++++++++++++++++++++++++++++++--------
 raster/rt_pg/rtpg_gdal.c   |   3 +-
 raster/rt_pg/rtpostgis.c   |  76 ++++++++++++++++++++++++++---
 sfcgal/lwgeom_sfcgal.c     |  11 +++--
 7 files changed, 184 insertions(+), 41 deletions(-)
hooks/post-receive
