[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1178-g646781e12
Fri Jul 7 15:22:36 PDT 2023
the project "PostGIS".
       via  646781e1260a164f8eedbf201100c0f9d24742f4 (commit)
      from  43880f9abf66d9d5c17f8374a4c6de781fe76a72 (commit)
revisions in full, below.
commit 646781e1260a164f8eedbf201100c0f9d24742f4
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Jul 7 15:22:35 2023 -0700
    Add doc spatial predicate math definitions
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index d26c9ad3d..852535ed4 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -103,6 +103,9 @@
     and the interiors of A and B have at least one point in common.
     </para>
+    <para>In mathematical terms:
+    <emphasis>ST_Contains(A, B) ⇔ (A ⋂ B = B) ∧ (Int(A) ⋂ Int(B) ≠ ∅) </emphasis></para>
     <para>The contains relationship is reflexive: every geometry contains itself.
     (In contrast, in the <xref linkend="ST_ContainsProperly" />
     predicate a geometry does <emphasis>not</emphasis> properly contain itself.)
@@ -320,12 +323,16 @@ ST_Point      | t          | t              | f           | f
     <refsection>
     <title>Description</title>
-    <para>Returns <varname>true</varname> if every point of B lies inside A
+    <para>Returns <varname>true</varname> if every point of B lies in the interior of A
     (or equivalently, no point of B lies in the the boundary or exterior of A).</para>
+    <emphasis>ST_ContainsProperly(A, B) ⇔ Int(A) ⋂ B = B </emphasis></para>
+    <para>A contains B properly if the DE-9IM Intersection Matrix for the two geometries matches
+   [T**FF*FF*]</para>
     <para>A does not properly contain itself, but does contain itself.</para>
-    <para>Every point of the other geometry is a point of this geometry's interior. The DE-9IM Intersection Matrix for the two geometries matches
-   [T**FF*FF*] used in <xref linkend="ST_Relate" /></para>
     <para>
     A use for this predicate is computing the intersections of a set of geometries with a large polygonal geometry. Since intersection is a fairly slow operation, it can be more efficient to use containsProperly to filter out test geometries which lie
Summary of changes:
 doc/reference_relationship.xml | 13 ++++++++++---
 1 file changed, 10 insertions(+), 3 deletions(-)
hooks/post-receive
