[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1184-g65028c31c
Sat Jul 8 10:36:43 PDT 2023
the project "PostGIS".
       via  65028c31c4a5604f17814171904251c9d35e9a34 (commit)
       via  ff0ef6c291b2769e8725d9110b4fa313df7167f7 (commit)
      from  55292073765c81e7c529522c13626ca3c636542a (commit)
revisions in full, below.
commit 65028c31c4a5604f17814171904251c9d35e9a34
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jul 8 15:41:05 2023 +0200
    Split localized docs from main docs
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs-localized.yml
similarity index 50%
copy from .woodpecker/docs.yml
copy to .woodpecker/docs-localized.yml
index f9af0a8ef..be80cd880 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs-localized.yml
@@ -1,3 +1,15 @@
+matrix:
+  LANG:
+    - it_IT
+    - pt_BR
+    - fr
+    - es
+    - pl
+    - ko_KR
+    - de
+    - ja
+    - ru
 pipeline:
   prepare:
     image: docker.osgeo.org/postgis/build-test:trisquel3
@@ -10,30 +22,16 @@ pipeline:
   check-xml:
     commands:
-      - cd build-docs
-      - make -C doc check
-      - make -C doc/ check-localized
+      - make -C build-docs/doc/po/${LANG} local-check
   build-html:
     commands:
-      - cd build-docs
-      - make -C doc html
-      - make -C doc/ html-localized
-      - make -C doc/ html-clean
-      - make -C doc/ html-clean-localized
+      - make -C build-docs/doc/po/${LANG} local-html
   build-pdf:
     commands:
-      - cd build-docs
-      - make -C doc/ pdf
-      - make -C doc/ pdf-localized
-      - make -C doc/ pdf-clean
-      - make -C doc/ pdf-clean-localized
+      - make -C build-docs/doc/po/${LANG} local-pdf
   build-cheatsheets:
     commands:
-      - cd build-docs
-      - make -C doc/ cheatsheets
-      - make -C doc/ cheatsheets-localized
-      - make -C doc/ cheatsheet-clean
-      - make -C doc/ cheatsheet-clean-localized
+      - make -C build-docs/doc/po/${LANG} local-cheatsheets
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index f9af0a8ef..c003f7d33 100644
+++ b/.woodpecker/docs.yml
@@ -10,30 +10,20 @@ pipeline:
   check-xml:
     commands:
-      - cd build-docs
+      - make -C build-docs/doc check
   build-html:
     commands:
-      - cd build-docs
-  build-pdf:
+      - make -C build-docs/doc html
+  build-cheatsheets:
     commands:
-      - cd build-docs
-  build-cheatsheets:
+      - make -C build-docs/doc/ cheatsheets
+  build-chunked-html:
+    image: docker.osgeo.org/postgis/build-test:trisquel3
+    commands:
+  build-pdf:
     commands:
-      - cd build-docs
+      - make -C build-docs/doc/ pdf
commit ff0ef6c291b2769e8725d9110b4fa313df7167f7
Date:   Sat Jul 8 19:35:11 2023 +0200
    Encode dependency of translated .xml on the english .xml
diff --git a/doc/po/Makefile.local b/doc/po/Makefile.local
index 3ae8810c4..d7968f635 100644
--- a/doc/po/Makefile.local
+++ b/doc/po/Makefile.local
@@ -27,6 +27,6 @@ include ../../Makefile
 # XML gettext tools
 PO2XML=po2xml
-$(XML_SOURCES): %.xml: %.xml.po
+$(XML_SOURCES): %.xml: %.xml.po $(srcdir)/../../%.xml
 	$(PO2XML) $(srcdir)/../../$@ $< > $@
Summary of changes:
 .woodpecker/{docs.yml => docs-localized.yml} | 34 +++++++++++++---------------
 .woodpecker/docs.yml                         | 30 ++++++++----------------
 doc/po/Makefile.local                        |  2 +-
 3 files changed, 27 insertions(+), 39 deletions(-)
 copy .woodpecker/{docs.yml => docs-localized.yml} (50%)
hooks/post-receive
