[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1186-g92dd3257a
Sat Jul 8 11:01:28 PDT 2023
the project "PostGIS".
       via  92dd3257a02d227c392113298360e4244c273463 (commit)
       via  eaa0f3900f86683711fab9022766a8c0273bcee2 (commit)
      from  65028c31c4a5604f17814171904251c9d35e9a34 (commit)
revisions in full, below.
commit 92dd3257a02d227c392113298360e4244c273463
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jul 8 20:01:10 2023 +0200
    Fix dependency of translated .xml on the english .xml (off-tree build)
diff --git a/doc/po/Makefile.local b/doc/po/Makefile.local
index d7968f635..aa58ba7ba 100644
--- a/doc/po/Makefile.local
+++ b/doc/po/Makefile.local
@@ -27,6 +27,6 @@ include ../../Makefile
 # XML gettext tools
 PO2XML=po2xml
-$(XML_SOURCES): %.xml: %.xml.po $(srcdir)/../../%.xml
-	$(PO2XML) $(srcdir)/../../$@ $< > $@
+$(XML_SOURCES): %.xml: %.xml.po $(abs_srcdir)/%.xml
+	$(PO2XML) $(abs_srcdir)/$@ $< > $@
commit eaa0f3900f86683711fab9022766a8c0273bcee2
Date:   Sat Jul 8 18:34:12 2023 +0200
    Skip generation of docs whose .po files didn't change
diff --git a/.woodpecker/docs-localized.yml b/.woodpecker/docs-localized.yml
index be80cd880..05829b372 100644
--- a/.woodpecker/docs-localized.yml
+++ b/.woodpecker/docs-localized.yml
@@ -1,5 +1,5 @@
 matrix:
-  LANG:
+  TR:
     - it_IT
     - pt_BR
     - fr
@@ -19,19 +19,29 @@ pipeline:
       - mkdir -p build-docs && cd build-docs
       - ../configure --without-pg
       - make postgis_revision.h
+    when:
+      path: "doc/po/${TR}/*.po"
   check-xml:
     image: docker.osgeo.org/postgis/build-test:trisquel3
     commands:
-      - make -C build-docs/doc/po/${LANG} local-check
+      - make -C build-docs/doc/po/${TR} local-check
+    when:
   build-html:
     commands:
-      - make -C build-docs/doc/po/${LANG} local-html
+      - make -C build-docs/doc/po/${TR} local-html
+    when:
   build-pdf:
     commands:
-      - make -C build-docs/doc/po/${LANG} local-pdf
+      - make -C build-docs/doc/po/${TR} local-pdf
+    when:
   build-cheatsheets:
     commands:
-      - make -C build-docs/doc/po/${LANG} local-cheatsheets
+      - make -C build-docs/doc/po/${TR} local-cheatsheets
+    when:
Summary of changes:
 .woodpecker/docs-localized.yml | 20 +++++++++++++++-----
 doc/po/Makefile.local          |  4 ++--
 2 files changed, 17 insertions(+), 7 deletions(-)
hooks/post-receive
