[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1192-gdb53e7b7c
Sun Jul 9 11:44:18 PDT 2023
the project "PostGIS".
       via  db53e7b7ce679a9ed05a923e2550103ced3729b4 (commit)
       via  5d148fdf6c1990b2d25ac49cc8649f363424b57e (commit)
      from  faff5d0c03ac6b9481ac50a68251a2406cc3851a (commit)
revisions in full, below.
commit db53e7b7ce679a9ed05a923e2550103ced3729b4
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Jul 9 20:43:57 2023 +0200
    [woodie] tweak path condition for docs
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 24221e8f9..4ab19dbcd 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -1,27 +1,11 @@
-  check-xml- at LANG@:
+  @TARGET at -@LANG@:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/@LANG@ local-check
+      - make -C build-docs/doc/po/@LANG@ local- at TARGET@
+    group: localized- at TARGET@
     when:
-      path: *when_path
-  build-html- at LANG@:
-    image: *test_image
-    group: output- at LANG@
-    commands:
-      - make -C build-docs/doc/po/@LANG@ local-html
-    when:
-      path: *when_path
-  build-pdf- at LANG@:
-    commands:
-      - make -C build-docs/doc/po/@LANG@ local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets- at LANG@:
-    commands:
-      - make -C build-docs/doc/po/@LANG@ local-cheatsheets
-    when:
-      path: *when_path
+      path:
+        include:
+          # Localized assets
+          - "doc/po/@LANG@/Makefile.in"
+          - "doc/po/@LANG@/*.po"
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index c8e6f19a3..26efa4a41 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -2,17 +2,15 @@ variables:
   - &test_image 'docker.osgeo.org/postgis/build-test:trisquel3'
   - &when_path
       include:
+        # Common docs path
         # related config files
         - ".woodpecker/docs.yml"
         # Makefiles
         - "doc/Makefile.in"
         # XML sources
         - "doc/*.xml"
-        # Localized Makefiles
+        # Internationalization Makefiles
         - "doc/po/Makefile.local"
-        - "doc/po/*/Makefile.local"
-        # Translation files
-        - "doc/po/*/*.po"
 pipeline:
   prepare:
@@ -61,249 +59,723 @@ pipeline:
       path: *when_path
   # DO NOT EDIT PAST THIS LINE, use update-docs-localized.sh to update #
-# Supported languages  it_IT pt_BR fr es pl ko_KR de ja ru
-  check-xml-it_IT:
+  check-it_IT:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/it_IT local-check
-    when:
-      path: *when_path
-  build-html-it_IT:
+    group: localized-check
+    when:
+      path:
+        include:
+          - "doc/po/it_IT/Makefile.in"
+          - "doc/po/it_IT/*.po"
+          # related config files
+          - ".woodpecker/docs.yml"
+          # Makefiles
+          - "doc/Makefile.in"
+          # XML sources
+          - "doc/*.xml"
+          - "doc/po/Makefile.local"
+  check-pt_BR:
     image: *test_image
-    group: output-it_IT
     commands:
-      - make -C build-docs/doc/po/it_IT local-html
-    when:
-      path: *when_path
-  build-pdf-it_IT:
+      - make -C build-docs/doc/po/pt_BR local-check
+    when:
+      path:
+        include:
+          - "doc/po/pt_BR/Makefile.in"
+          - "doc/po/pt_BR/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-fr:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/it_IT local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets-it_IT:
+      - make -C build-docs/doc/po/fr local-check
+    when:
+      path:
+        include:
+          - "doc/po/fr/Makefile.in"
+          - "doc/po/fr/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-es:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/it_IT local-cheatsheets
-    when:
-      path: *when_path
-  check-xml-pt_BR:
+      - make -C build-docs/doc/po/es local-check
+    when:
+      path:
+        include:
+          - "doc/po/es/Makefile.in"
+          - "doc/po/es/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-pl:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/pt_BR local-check
-    when:
-      path: *when_path
-  build-html-pt_BR:
+      - make -C build-docs/doc/po/pl local-check
+    when:
+      path:
+        include:
+          - "doc/po/pl/Makefile.in"
+          - "doc/po/pl/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-ko_KR:
     image: *test_image
-    group: output-pt_BR
     commands:
-      - make -C build-docs/doc/po/pt_BR local-html
-    when:
-      path: *when_path
-  build-pdf-pt_BR:
+      - make -C build-docs/doc/po/ko_KR local-check
+    when:
+      path:
+        include:
+          - "doc/po/ko_KR/Makefile.in"
+          - "doc/po/ko_KR/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-de:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/pt_BR local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets-pt_BR:
+      - make -C build-docs/doc/po/de local-check
+    when:
+      path:
+        include:
+          - "doc/po/de/Makefile.in"
+          - "doc/po/de/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-ja:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/pt_BR local-cheatsheets
-    when:
-      path: *when_path
-  check-xml-fr:
+      - make -C build-docs/doc/po/ja local-check
+    when:
+      path:
+        include:
+          - "doc/po/ja/Makefile.in"
+          - "doc/po/ja/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-ru:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/fr local-check
-    when:
-      path: *when_path
-  build-html-fr:
+      - make -C build-docs/doc/po/ru local-check
+    when:
+      path:
+        include:
+          - "doc/po/ru/Makefile.in"
+          - "doc/po/ru/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  html-it_IT:
     image: *test_image
-    group: output-fr
     commands:
-      - make -C build-docs/doc/po/fr local-html
-    when:
-      path: *when_path
-  build-pdf-fr:
+      - make -C build-docs/doc/po/it_IT local-html
+    group: localized-html
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  html-pt_BR:
     image: *test_image
-    group: output-fr
     commands:
-      - make -C build-docs/doc/po/fr local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets-fr:
+      - make -C build-docs/doc/po/pt_BR local-html
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  html-fr:
     image: *test_image
-    group: output-fr
     commands:
-      - make -C build-docs/doc/po/fr local-cheatsheets
-    when:
-      path: *when_path
-  check-xml-es:
+      - make -C build-docs/doc/po/fr local-html
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  html-es:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/es local-check
-    when:
-      path: *when_path
-  build-html-es:
+      - make -C build-docs/doc/po/es local-html
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  html-pl:
     image: *test_image
-    group: output-es
     commands:
-      - make -C build-docs/doc/po/es local-html
-    when:
-      path: *when_path
-  build-pdf-es:
+      - make -C build-docs/doc/po/pl local-html
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  html-ko_KR:
     image: *test_image
-    group: output-es
     commands:
-      - make -C build-docs/doc/po/es local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets-es:
+      - make -C build-docs/doc/po/ko_KR local-html
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  html-de:
     image: *test_image
-    group: output-es
     commands:
-      - make -C build-docs/doc/po/es local-cheatsheets
-    when:
-      path: *when_path
-  check-xml-pl:
+      - make -C build-docs/doc/po/de local-html
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  html-ja:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/pl local-check
-    when:
-      path: *when_path
-  build-html-pl:
+      - make -C build-docs/doc/po/ja local-html
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  html-ru:
     image: *test_image
-    group: output-pl
     commands:
-      - make -C build-docs/doc/po/pl local-html
-    when:
-      path: *when_path
-  build-pdf-pl:
+      - make -C build-docs/doc/po/ru local-html
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  cheatsheets-it_IT:
     image: *test_image
-    group: output-pl
     commands:
-      - make -C build-docs/doc/po/pl local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets-pl:
+      - make -C build-docs/doc/po/it_IT local-cheatsheets
+    group: localized-cheatsheets
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  cheatsheets-pt_BR:
     image: *test_image
-    group: output-pl
     commands:
-      - make -C build-docs/doc/po/pl local-cheatsheets
-    when:
-      path: *when_path
-  check-xml-ko_KR:
+      - make -C build-docs/doc/po/pt_BR local-cheatsheets
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  cheatsheets-fr:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/ko_KR local-check
-    when:
-      path: *when_path
-  build-html-ko_KR:
+      - make -C build-docs/doc/po/fr local-cheatsheets
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  cheatsheets-es:
     image: *test_image
-    group: output-ko_KR
     commands:
-      - make -C build-docs/doc/po/ko_KR local-html
-    when:
-      path: *when_path
-  build-pdf-ko_KR:
+      - make -C build-docs/doc/po/es local-cheatsheets
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  cheatsheets-pl:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/ko_KR local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets-ko_KR:
+      - make -C build-docs/doc/po/pl local-cheatsheets
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  cheatsheets-ko_KR:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
-    when:
-      path: *when_path
-  check-xml-de:
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  cheatsheets-de:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/de local-check
-    when:
-      path: *when_path
-  build-html-de:
+      - make -C build-docs/doc/po/de local-cheatsheets
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  cheatsheets-ja:
     image: *test_image
-    group: output-de
     commands:
-      - make -C build-docs/doc/po/de local-html
-    when:
-      path: *when_path
-  build-pdf-de:
+      - make -C build-docs/doc/po/ja local-cheatsheets
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  cheatsheets-ru:
     image: *test_image
-    group: output-de
     commands:
-      - make -C build-docs/doc/po/de local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets-de:
+      - make -C build-docs/doc/po/ru local-cheatsheets
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  pdf-it_IT:
     image: *test_image
-    group: output-de
     commands:
-      - make -C build-docs/doc/po/de local-cheatsheets
-    when:
-      path: *when_path
-  check-xml-ja:
+      - make -C build-docs/doc/po/it_IT local-pdf
+    group: localized-pdf
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  pdf-pt_BR:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/ja local-check
-    when:
-      path: *when_path
-  build-html-ja:
+      - make -C build-docs/doc/po/pt_BR local-pdf
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  pdf-fr:
     image: *test_image
-    group: output-ja
     commands:
-      - make -C build-docs/doc/po/ja local-html
-    when:
-      path: *when_path
-  build-pdf-ja:
+      - make -C build-docs/doc/po/fr local-pdf
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  pdf-es:
     image: *test_image
-    group: output-ja
     commands:
-      - make -C build-docs/doc/po/ja local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets-ja:
+      - make -C build-docs/doc/po/es local-pdf
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  pdf-pl:
     image: *test_image
-    group: output-ja
     commands:
-      - make -C build-docs/doc/po/ja local-cheatsheets
-    when:
-      path: *when_path
-  check-xml-ru:
+      - make -C build-docs/doc/po/pl local-pdf
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  pdf-ko_KR:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/ru local-check
-    when:
-      path: *when_path
-  build-html-ru:
+      - make -C build-docs/doc/po/ko_KR local-pdf
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  pdf-de:
     image: *test_image
-    group: output-ru
     commands:
-      - make -C build-docs/doc/po/ru local-html
-    when:
-      path: *when_path
-  build-pdf-ru:
+      - make -C build-docs/doc/po/de local-pdf
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  pdf-ja:
     image: *test_image
-    group: output-ru
     commands:
-      - make -C build-docs/doc/po/ru local-pdf
-    when:
-      path: *when_path
-  build-cheatsheets-ru:
+      - make -C build-docs/doc/po/ja local-pdf
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  pdf-ru:
     image: *test_image
-    group: output-ru
     commands:
-      - make -C build-docs/doc/po/ru local-cheatsheets
-    when:
-      path: *when_path
+      - make -C build-docs/doc/po/ru local-pdf
+    when:
+      path:
+        include:
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index bb9f4fc67..973790bf9 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -4,17 +4,22 @@ cd $(dirname $0)
 SUPPORTED_LANGUAGES=$(grep ^translations ../doc/Makefile.in | cut -d= -f2)
-exec > docs.yml.new
+TARGETS="check html cheatsheets pdf"
-cat docs.yml | sed '/DO NOT EDIT/q'
-echo
-echo "# Supported languages $SUPPORTED_LANGUAGES"
-echo
+cat docs.yml | sed '/DO NOT EDIT/q' > docs.yml.new
+cat docs.yml.new | sed -n '/# Common docs path/,/^$/p' | grep -v '^$' | sed 's/^/  /' > docs.yml.common_paths
-for lang in ${SUPPORTED_LANGUAGES};
+exec >> docs.yml.new
+for target in ${TARGETS}
 do
-  sed "s/@LANG@/$lang/" docs-localized.yml.in
+  for lang in ${SUPPORTED_LANGUAGES};
+  do
+    sed "s/@LANG@/${lang}/;s/@TARGET@/${target}/" docs-localized.yml.in
+    # Add common docs paths
+    cat docs.yml.common_paths
+  done
 done
 mv -b docs.yml.new docs.yml
+rm docs.yml.common_paths
commit 5d148fdf6c1990b2d25ac49cc8649f363424b57e
Date:   Sun Jul 9 20:04:23 2023 +0200
    Japanese PDF requires the xetex backend
diff --git a/doc/po/ja/Makefile.in b/doc/po/ja/Makefile.in
index ed5866283..1dcdb708c 100644
--- a/doc/po/ja/Makefile.in
+++ b/doc/po/ja/Makefile.in
@@ -1,3 +1,4 @@
 include @srcdir@/../Makefile.local
+DBLATEX_EXTRA_OPTIONS = -b xetex
 DOCSUFFIX=-ja
 srcdir=@srcdir@
Summary of changes:
 .woodpecker/docs-localized.yml.in    |  32 +-
 .woodpecker/docs.yml                 | 824 +++++++++++++++++++++++++++--------
 .woodpecker/update-docs-localized.sh |  19 +-
 doc/po/ja/Makefile.in                |   1 +
 4 files changed, 669 insertions(+), 207 deletions(-)
hooks/post-receive
