[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1195-g7ddcceb56
Sun Jul 9 21:19:20 PDT 2023
the project "PostGIS".
       via  7ddcceb56c4acbd6952dc4401c377a14a2fd5667 (commit)
       via  2f7a8843486ab9770a6ce961a430e37edef9e15f (commit)
       via  06ae05923d084304a8d2416a1d5c3c82abb5d477 (commit)
      from  db53e7b7ce679a9ed05a923e2550103ced3729b4 (commit)
revisions in full, below.
commit 7ddcceb56c4acbd6952dc4401c377a14a2fd5667
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jul 10 06:18:25 2023 +0200
    [debbie] Use install rule to install pdf/epub, also build and install localized ones
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index ed0ebb99d..4fd622334 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -25,6 +25,8 @@ POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
 # TODO: take base as env variable ?
 HTML_DIR=/var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+STUFF_DIR=/var/www/postgis_stuff/
 echo $PATH
@@ -42,7 +44,8 @@ LDFLAGS="-L${PGPATH}/lib"  ./configure \
   --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
   --without-raster --without-protobuf \
-  --htmldir ${HTML_DIR}
+  --htmldir ${HTML_DIR} \
+  --docdir ${STUFF_DIR}
 make clean
 # generating postgis_revision.h in case hasn't been generated
@@ -71,21 +74,13 @@ if [[ "$POSTGIS_MICRO_VERSION" == *"dev"* ]]; then
 fi
 make cheatsheets
-make pdf
-make epub
 make -e chunked-html-web # TODO: do we really want this too in the doc-html-*.tar.gz package ?
 make html-localized # TODO: do we really want this too in the doc-html-*.tar.gz package ?
-STUFF_DIR=/var/www/postgis_stuff/
 package="doc-html-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.tar.gz"
 tar -czf "$package" --exclude='static' --exclude='wkt' --exclude '*.o' html
 cp $package ${STUFF_DIR}
-# TODO: Replace all of this by some `make *-install` rule
-cp *.pdf ${STUFF_DIR}
-cp *.epub ${STUFF_DIR}
 # Install all html
 make html-assets-install
 make html-install
@@ -110,8 +105,13 @@ for f in ${HTML_DIR}/postgis-web-*; do
 done
-#chmod -R 755 ${HTML_DIR} # TODO: still needed ?
+# Build and install pdf and epub
+make pdf-install # || : survive failure
+make epub-install # || : survive failure
+# Build and install localized pdf and epub
+make pdf-install-localized # || : survive failures
+make epub-install-localized # || : survive failures
commit 2f7a8843486ab9770a6ce961a430e37edef9e15f
Date:   Mon Jul 10 05:44:40 2023 +0200
    Add pdf and epub install/uninstall targets
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 31b50df17..4418864cb 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -379,6 +379,13 @@ else
 		 -o postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf $<
 endif
+pdf-install: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf
+	mkdir -p $(DESTDIR)$(docdir)
+	$(INSTALL_DATA) $< $(DESTDIR)$(docdir)/
+pdf-uninstall:
+	rm -f $(DESTDIR)$(docdir)/postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf
 postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub: postgis-out.xml images $(XML_INPUTS)
 ifeq ($(DBTOEPUB),)
 	@echo
@@ -393,6 +400,13 @@ else
 endif
+epub-install: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub
+epub-uninstall:
+	rm -f $(DESTDIR)$(docdir)/postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub
 epub: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub
 pdf: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf
commit 06ae05923d084304a8d2416a1d5c3c82abb5d477
Date:   Mon Jul 10 05:41:45 2023 +0200
    Make package name and version available to Makefiles
diff --git a/configure.ac b/configure.ac
index d2dd15ee0..d73dd1fc3 100644
--- a/configure.ac
+++ b/configure.ac
@@ -9,7 +9,14 @@ dnl * the terms of the GNU General Public Licence. See the COPYING file.
 dnl *
 dnl **********************************************************************
-AC_INIT
+AC_INIT(
+  [postgis],
+  m4_esyscmd_s(
+    [grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2]
+  ).m4_esyscmd_s(
+    [grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2]
 # test to see if srcdir already configured, when
 # building out of tree
index aa72fd3ea..31b50df17 100644
@@ -23,6 +23,8 @@
 translations = it_IT pt_BR fr es pl ko_KR de ja ru
+PACKAGE_TARNAME = @PACKAGE_TARNAME@
 prefix = @prefix@
 srcdir = @srcdir@
 top_srcdir = @top_srcdir@
Summary of changes:
 ci/debbie/postgis_release_docs.sh | 20 ++++++++++----------
 configure.ac                      |  9 ++++++++-
 doc/Makefile.in                   | 16 ++++++++++++++++
 3 files changed, 34 insertions(+), 11 deletions(-)
hooks/post-receive
