[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1205-gf44fd54f9
Tue Jul 11 08:29:56 PDT 2023
the project "PostGIS".
       via  f44fd54f97146dd3cef22cbb9901ff887438c7f4 (commit)
      from  e7b473841608110b1263f553612405657e041cb4 (commit)
revisions in full, below.
commit f44fd54f97146dd3cef22cbb9901ff887438c7f4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jul 11 08:25:13 2023 -0700
    Add linear referencing support functions for the geography
    type. Submitted by MobilityDB, @estebanzimanyi.
    * ST_LineInterpolatePoint(geography, float)
    * ST_LineInterpolatePoints(geography, float)
    * ST_LineLocatePoint(geography, geography)
    * ST_LineSubstring(geography, float, float)
    * ST_ClosestPoint(geography, geography)
    * ST_ShortestLine(geography, geography)
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index 5ce26bfe2..e28f23fa5 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -16,6 +16,14 @@
 				<paramdef><type>geometry </type> <parameter>a_linestring</parameter></paramdef>
 				<paramdef><type>float8 </type> <parameter>a_fraction</parameter></paramdef>
 			  </funcprototype>
+              <funcprototype>
+                <funcdef>geography <function>ST_LineInterpolatePoint</function></funcdef>
+                <paramdef><type>geography </type> <parameter>a_linestring</parameter></paramdef>
+                <paramdef><type>float8 </type> <parameter>a_fraction</parameter></paramdef>
+                <paramdef choice="opt"><type>boolean </type><parameter>use_spheroid = true</parameter></paramdef>
+              </funcprototype>
 			</funcsynopsis>
 		  </refsynopsisdiv>
@@ -183,6 +191,15 @@ SELECT ST_AsText(
 				<paramdef><type>boolean </type> <parameter>repeat</parameter></paramdef>
 			  </funcprototype>
+              <funcprototype>
+                <funcdef>geography <function>ST_LineInterpolatePoints</function></funcdef>
+                <paramdef choice="opt"><type>boolean </type> <parameter>repeat = true</parameter></paramdef>
+              </funcprototype>
 			</funcsynopsis>
 		  </refsynopsisdiv>
@@ -245,11 +262,20 @@ SELECT ST_AsText(ST_LineInterpolatePoints('LINESTRING(25 50, 100 125, 150 190)',
 		  <refsynopsisdiv>
 			<funcsynopsis>
 			  <funcprototype>
 				<funcdef>float8 <function>ST_LineLocatePoint</function></funcdef>
 				<paramdef><type>geometry </type> <parameter>a_point</parameter></paramdef>
 			  </funcprototype>
+              <funcprototype>
+                <funcdef>float8 <function>ST_LineLocatePoint</function></funcdef>
+                <paramdef><type>geography </type> <parameter>a_point</parameter></paramdef>
+              </funcprototype>
 			</funcsynopsis>
 		  </refsynopsisdiv>
@@ -330,6 +356,14 @@ FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
 				<paramdef><type>float8 </type> <parameter>startfraction</parameter></paramdef>
 				<paramdef><type>float8 </type> <parameter>endfraction</parameter></paramdef>
 			  </funcprototype>
+              <funcprototype>
+                <funcdef>geography <function>ST_LineSubstring</function></funcdef>
+                <paramdef><type>float8 </type> <parameter>startfraction</parameter></paramdef>
+                <paramdef><type>float8 </type> <parameter>endfraction</parameter></paramdef>
+              </funcprototype>
 			</funcsynopsis>
 		  </refsynopsisdiv>
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 4bd94c94d..21d5c9811 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -294,15 +294,25 @@ SELECT degrees( ST_Angle('LINESTRING(0 0, 0.3 0.7, 1 1)', 'LINESTRING(0 0, 0.2 0
 	  <refsynopsisdiv>
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>geometry <function>ST_ClosestPoint</function></funcdef>
 			<parameter>geom1</parameter></paramdef>
 			<parameter>geom2</parameter></paramdef>
 		  </funcprototype>
+          <funcprototype>
+            <funcdef>geography <function>ST_ClosestPoint</function></funcdef>
+              <parameter>geom1</parameter></paramdef>
+              <parameter>geom2</parameter></paramdef>
+              <parameter>repeat = true</parameter></paramdef>
+          </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -1879,13 +1889,21 @@ FROM ST_GeogFromText('MULTIPOLYGON(((-71.1044543107478 42.340674480411,-71.10445
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>geometry <function>ST_ShortestLine</function></funcdef>
 		  </funcprototype>
+          <funcprototype>
+            <funcdef>geography <function>ST_ShortestLine</function></funcdef>
+          </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
diff --git a/liblwgeom/Makefile.in b/liblwgeom/Makefile.in
index 9f0530c8f..3094837af 100644
--- a/liblwgeom/Makefile.in
+++ b/liblwgeom/Makefile.in
@@ -105,6 +105,7 @@ SA_OBJS = \
 	gserialized1.o \
 	gserialized2.o \
 	lwgeodetic.o \
+	lwgeodetic_measures.o \
 	lwgeodetic_tree.o \
 	lwrandom.o \
 	lwtree.o \
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index cbac60f3c..a27529e6c 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1791,6 +1791,26 @@ extern double lwgeom_length_spheroid(const LWGEOM *geom, const SPHEROID *s);
 extern int lwgeom_covers_lwgeom_sphere(const LWGEOM *lwgeom1, const LWGEOM *lwgeom2);
+extern LWGEOM * geography_substring(const LWLINE *line,
+    double from, double to,
+    double tolerance);
+extern LWGEOM * geography_interpolate_points(
+    const LWLINE *line,
+    double length_fraction,
+    const SPHEROID *s, char repeat);
+extern double
+ptarray_locate_point_spheroid(
+    const POINTARRAY *pa,
+    const POINT4D *p4d,
+    double tolerance,
+    double *mindistout,
+    POINT4D *proj4d);
 typedef struct {
 	POINT2D* center;
 	double radius;
diff --git a/liblwgeom/lwgeodetic_measures.c b/liblwgeom/lwgeodetic_measures.c
new file mode 100644
index 000000000..d8e245657
--- /dev/null
+++ b/liblwgeom/lwgeodetic_measures.c
@@ -0,0 +1,561 @@
+ * This MobilityDB code is provided under The PostgreSQL License.
+ * Copyright (c) 2016-2023, Université libre de Bruxelles and MobilityDB
+ * contributors
+ * MobilityDB includes portions of PostGIS version 3 source code released
+ * under the GNU General Public License (GPLv2 or later).
+ * Copyright (c) 2001-2023, PostGIS contributors
+ * Permission to use, copy, modify, and distribute this software and its
+ * documentation for any purpose, without fee, and without a written
+ * agreement is hereby granted, provided that the above copyright notice and
+ * this paragraph and the following two paragraphs appear in all copies.
+ * IN NO EVENT SHALL UNIVERSITE LIBRE DE BRUXELLES BE LIABLE TO ANY PARTY FOR
+ * DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING
+ * LOST PROFITS, ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION,
+ * EVEN IF UNIVERSITE LIBRE DE BRUXELLES HAS BEEN ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+ * UNIVERSITE LIBRE DE BRUXELLES SPECIFICALLY DISCLAIMS ANY WARRANTIES,
+ * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
+ * AND FITNESS FOR A PARTICULAR PURPOSE. THE SOFTWARE PROVIDED HEREUNDER IS ON
+ * AN "AS IS" BASIS, AND UNIVERSITE LIBRE DE BRUXELLES HAS NO OBLIGATIONS TO
+ * PROVIDE MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS, OR MODIFICATIONS.
+ * @file
+ * @brief Spatial functions for PostGIS geography.
+ * These functions are supposed to be included in a forthcoming version of
+ * PostGIS, to be proposed as a PR. This still remains to be done.
+ * These functions are not needed in MobilityDB.
+// #include "point/geography_funcs.h"
+/* C */
+#include <float.h>
+/* PostGIS */
+#include <liblwgeom_internal.h>
+#include <lwgeodetic_tree.h>
+ * ST_LineSubstring for geographies
+ * Find interpolation point p between geography points p1 and p2
+ * so that the len(p1,p) == len(p1,p2)
+ * f and p falls on p1,p2 segment
+ * @param[in] p1,p2 3D-space points we are interpolating between
+ * @param[in] v1,v2 real values and z/m coordinates
+ * @param[in] f Fraction
+ * @param[out] p Result
+static void
+interpolate_point4d_sphere(
+	const POINT3D *p1, const POINT3D *p2,
+	const POINT4D *v1, const POINT4D *v2,
+	double f, POINT4D *p)
+	/* Calculate interpolated point */
+	POINT3D mid;
+	mid.x = p1->x + ((p2->x - p1->x) * f);
+	mid.y = p1->y + ((p2->y - p1->y) * f);
+	mid.z = p1->z + ((p2->z - p1->z) * f);
+	normalize(&mid);
+	/* Calculate z/m values */
+	GEOGRAPHIC_POINT g;
+	cart2geog(&mid, &g);
+	p->x = rad2deg(g.lon);
+	p->y = rad2deg(g.lat);
+	p->z = v1->z + ((v2->z - v1->z) * f);
+	p->m = v1->m + ((v2->m - v1->m) * f);
+ * @brief Returns the length of the point array wrt the sphere
+static double
+ptarray_length_sphere(const POINTARRAY *pa)
+	GEOGRAPHIC_POINT a, b;
+	POINT4D p;
+	uint32_t i;
+	double length = 0.0;
+	/* Return zero on non-sensical inputs */
+	if ( ! pa || pa->npoints < 2 )
+		return 0.0;
+	/* Initialize first point */
+	getPoint4d_p(pa, 0, &p);
+	geographic_point_init(p.x, p.y, &a);
+	/* Loop and sum the length for each segment */
+	for ( i = 1; i < pa->npoints; i++ )
+		getPoint4d_p(pa, i, &p);
+		geographic_point_init(p.x, p.y, &b);
+		/* Add this segment length to the total */
+		length += sphere_distance(&a, &b);
+	return length;
+ * @brief Return the part of a line between two fractional locations.
+LWGEOM *
+geography_substring(
+	const LWLINE *lwline,
+	double tolerance)
+	POINTARRAY *dpa;
+	POINTARRAY *ipa = lwline->points;
+	LWGEOM *lwresult;
+	POINT4D pt;
+	POINT4D p1, p2;
+	POINT3D q1, q2;
+	GEOGRAPHIC_POINT g1, g2;
+	int nsegs, i;
+	double length, slength, tlength;
+	int state = 0; /* 0 = before, 1 = inside */
+	uint32_t srid = lwline->srid;
+	* Create a dynamic pointarray with an initial capacity
+	* equal to full copy of input points
+	dpa = ptarray_construct_empty(
+		(char) FLAGS_GET_Z(ipa->flags),
+		(char) FLAGS_GET_M(ipa->flags),
+		ipa->npoints);
+	/* Compute total line length */
+	length = ptarray_length_sphere(ipa);
+	/* Get 'from' and 'to' lengths */
+	from = length * from;
+	to = length * to;
+	tlength = 0;
+	getPoint4d_p(ipa, 0, &p1);
+	geographic_point_init(p1.x, p1.y, &g1);
+	nsegs = ipa->npoints - 1;
+	for (i = 0; i < nsegs; i++)
+		double dseg;
+		getPoint4d_p(ipa, (uint32_t) i+1, &p2);
+		geographic_point_init(p2.x, p2.y, &g2);
+		/* Find the length of this segment */
+		slength = sphere_distance(&g1, &g2);
+		/*  We are before requested start. */
+		if (state == 0) /* before */
+			if (fabs ( from - ( tlength + slength ) ) <= tolerance)
+				/* Second point is our start */
+				ptarray_append_point(dpa, &p2, LW_FALSE);
+				state = 1; /* we're inside now */
+				goto END;
+			else if (fabs(from - tlength) <= tolerance)
+				/*  First point is our start */
+				ptarray_append_point(dpa, &p1, LW_FALSE);
+				 * We're inside now, but will check
+				 * 'to' point as well
+				state = 1;
+			* Didn't reach the 'from' point,
+			* nothing to do
+			else if (from > tlength + slength)
+				goto END;
+			else  /* tlength < from < tlength+slength */
+				/* Our start is between first and second point */
+				dseg = (from - tlength) / slength;
+				geog2cart(&g1, &q1);
+				geog2cart(&g2, &q2);
+				interpolate_point4d_sphere(&q1, &q2, &p1, &p2, dseg, &pt);
+				ptarray_append_point(dpa, &pt, LW_FALSE);
+				/* We're inside now, but will check 'to' point as well */
+				state = 1;
+	    if (state == 1) /* inside */
+			/*  'to' point is our second point. */
+			if (fabs(to - ( tlength + slength ) ) <= tolerance )
+				break; /* substring complete */
+			* 'to' point is our first point.
+			* (should only happen if 'to' is 0)
+			else if (fabs(to - tlength) <= tolerance)
+			* Didn't reach the 'end' point,
+			* just copy second point
+			else if (to > tlength + slength)
+				goto END;
+			* 'to' point falls on this segment
+			* Interpolate and break.
+			else if (to < tlength + slength )
+				dseg = (to - tlength) / slength;
+				break;
+	END:
+		tlength += slength;
+		memcpy(&p1, &p2, sizeof(POINT4D));
+	if (dpa->npoints <= 1) {
+		lwresult = lwpoint_as_lwgeom(lwpoint_construct(srid, NULL, dpa));
+	else {
+		lwresult = lwline_as_lwgeom(lwline_construct(srid, NULL, dpa));
+	return lwresult;
+ * Interpolate a point along a geographic line.
+ * @brief Interpolate a point along a geographic line.
+LWGEOM *
+geography_interpolate_points(
+	const LWLINE *line, double length_fraction,
+	POINT4D pt;
+	uint32_t i;
+	uint32_t points_to_interpolate;
+	uint32_t points_found = 0;
+	double length;
+	double length_fraction_increment = length_fraction;
+	double length_fraction_consumed = 0;
+	char has_z = (char) lwgeom_has_z(lwline_as_lwgeom(line));
+	char has_m = (char) lwgeom_has_m(lwline_as_lwgeom(line));
+	const POINTARRAY* ipa = line->points;
+	POINTARRAY *opa;
+	POINT4D p1, p2;
+	POINT3D q1, q2;
+	LWGEOM *lwresult;
+	uint32_t srid = line->srid;
+	/* Empty.InterpolatePoint == Point Empty */
+	if ( lwline_is_empty(line) )
+		return lwgeom_clone_deep(lwline_as_lwgeom(line));
+	* If distance is one of the two extremes, return the point on that
+	* end rather than doing any computations
+	if ( length_fraction == 0.0 || length_fraction == 1.0 )
+		if ( length_fraction == 0.0 )
+			getPoint4d_p(ipa, 0, &pt);
+		else
+			getPoint4d_p(ipa, ipa->npoints-1, &pt);
+		opa = ptarray_construct(has_z, has_m, 1);
+		ptarray_set_point4d(opa, 0, &pt);
+		return lwpoint_as_lwgeom(lwpoint_construct(srid, NULL, opa));
+	/* Interpolate points along the line */
+	length = ptarray_length_spheroid(ipa, s);
+	points_to_interpolate = repeat ? (uint32_t) floor(1 / length_fraction) : 1;
+	opa = ptarray_construct(has_z, has_m, points_to_interpolate);
+	for ( i = 0; i < ipa->npoints - 1 && points_found < points_to_interpolate; i++ )
+		getPoint4d_p(ipa, i+1, &p2);
+		double segment_length_frac = spheroid_distance(&g1, &g2, s) / length;
+		/* If our target distance is before the total length we've seen
+		* so far. create a new point some distance down the current
+		* segment.
+		while ( length_fraction < length_fraction_consumed + segment_length_frac && points_found < points_to_interpolate )
+			double segment_fraction = (length_fraction - length_fraction_consumed) / segment_length_frac;
+			interpolate_point4d_sphere(&q1, &q2, &p1, &p2, segment_fraction, &pt);
+			ptarray_set_point4d(opa, points_found++, &pt);
+			length_fraction += length_fraction_increment;
+		length_fraction_consumed += segment_length_frac;
+		p1 = p2;
+		g1 = g2;
+	/* Return the last point on the line. This shouldn't happen, but
+	* could if there's some floating point rounding errors. */
+	if (points_found < points_to_interpolate)
+		getPoint4d_p(ipa, ipa->npoints - 1, &pt);
+		ptarray_set_point4d(opa, points_found, &pt);
+	if (opa->npoints <= 1)
+		lwresult = lwpoint_as_lwgeom(lwpoint_construct(srid, NULL, opa));
+	} else {
+		lwresult = lwmpoint_as_lwgeom(lwmpoint_construct(srid, opa));
+	return lwresult;
+ * @brief Locate a point along the point array defining a geographic line.
+double
+	double tolerance,
+	POINT4D *proj4d)
+	GEOGRAPHIC_EDGE e;
+	GEOGRAPHIC_POINT a, b, nearest = {0}; /* make compiler quiet */
+	POINT4D p1, p2;
+	const POINT2D *p;
+	POINT2D proj;
+	uint32_t i, seg = 0;
+	int use_sphere = (s->a == s->b ? 1 : 0);
+	int hasz;
+	double za = 0.0, zb = 0.0;
+	double distance,
+		length,   /* Used for computing lengths */
+		seglength = 0.0,  /* length of the segment where the closest point is located */
+		partlength = 0.0, /* length from the beginning of the point array to the closest point */
+		totlength = 0.0;  /* length of the point array */
+	/* Initialize our point */
+	geographic_point_init(p4d->x, p4d->y, &a);
+	/* Handle point/point case here */
+	if ( pa->npoints <= 1)
+		if ( pa->npoints == 1 )
+			p = getPoint2d_cp(pa, 0);
+			geographic_point_init(p->x, p->y, &b);
+			/* Sphere special case, axes equal */
+			*mindistout = s->radius * sphere_distance(&a, &b);
+			/* If close or greater than tolerance, get the real answer to be sure */
+			if ( ! use_sphere || *mindistout > 0.95 * tolerance )
+				*mindistout = spheroid_distance(&a, &b, s);
+		return 0.0;
+	/* Make result really big, so that everything will be smaller than it */
+	distance = FLT_MAX;
+	/* Initialize start of line */
+	geographic_point_init(p->x, p->y, &(e.start));
+	/* Iterate through the edges in our line */
+		double d;
+		p = getPoint2d_cp(pa, i);
+		geographic_point_init(p->x, p->y, &(e.end));
+		/* Get the spherical distance between point and edge */
+		d = s->radius * edge_distance_to_point(&e, &a, &b);
+		/* New shortest distance! Record this distance / location / segment */
+		if ( d < distance )
+			distance = d;
+			nearest = b;
+			seg = i - 1;
+	    /* We've gotten closer than the tolerance... */
+		if ( d < tolerance )
+			/* Working on a sphere? The answer is correct, return */
+			if ( use_sphere )
+				break;
+			/* Far enough past the tolerance that the spheroid calculation won't change things */
+			else if ( d < tolerance * 0.95 )
+				break;
+			/* On a spheroid and near the tolerance? Confirm that we are *actually* closer than tolerance */
+			else
+				d = spheroid_distance(&a, &nearest, s);
+				/* Yes, closer than tolerance, return! */
+					break;
+		e.start = e.end;
+	if ( mindistout ) *mindistout = distance;
+	/* See if we have a third dimension */
+	hasz = (bool) FLAGS_GET_Z(pa->flags);
+	/* Initialize first point of array */
+	getPoint4d_p(pa, 0, &p1);
+	geographic_point_init(p1.x, p1.y, &a);
+	if ( hasz )
+		za = p1.z;
+		getPoint4d_p(pa, i, &p1);
+		geographic_point_init(p1.x, p1.y, &b);
+		if ( hasz )
+			zb = p1.z;
+		/* Special sphere case */
+		if ( s->a == s->b )
+			length = s->radius * sphere_distance(&a, &b);
+		/* Spheroid case */
+		else
+			length = spheroid_distance(&a, &b, s);
+		/* Add in the vertical displacement if we're in 3D */
+		if ( hasz )
+			length = sqrt( (zb-za)*(zb-za) + length*length );
+		/* Add this segment length to the total length */
+		totlength += length;
+		/* Add this segment length to the partial length */
+		if (i - 1 < seg)
+			partlength += length;
+		else if (i - 1 == seg)
+			/* Save segment length for computing the final value of partlength */
+			seglength = length;
+		/* B gets incremented in the next loop, so we save the value here */
+		a = b;
+		za = zb;
+	/* Copy nearest into 2D/4D holder */
+	proj4d->x = proj.x = rad2deg(nearest.lon);
+	proj4d->y = proj.y = rad2deg(nearest.lat);
+	/* Compute distance from beginning of the segment to closest point */
+	/* Start of the segment */
+	getPoint4d_p(pa, seg, &p1);
+	/* Closest point */
+	geographic_point_init(proj4d->x, proj4d->y, &b);
+	else
+	if ( hasz )
+		/* Compute Z and M values for closest point */
+		double f = length / seglength;
+		getPoint4d_p(pa, seg + 1, &p2);
+		proj4d->z = p1.z + ((p2.z - p1.z) * f);
+		proj4d->m = p1.m + ((p2.m - p1.m) * f);
+		za = p1.z;
+		zb = proj4d->z;
+	/* Location of any point on a zero-length line is 0 */
+	/* See http://trac.osgeo.org/postgis/ticket/1772#comment:2 */
+	if ( partlength == 0 || totlength == 0 )
+		return 0.0;
+	/* For robustness, force 0 when closest point == startpoint */
+	if ( seg == 0 && p2d_same(&proj, p) )
+		return 0.0;
+	/* For robustness, force 1 when closest point == endpoint */
+	p = getPoint2d_cp(pa, pa->npoints - 1);
+	if ( (seg >= (pa->npoints-2)) && p2d_same(&proj, p) )
+		return 1.0;
+	return partlength / totlength;
diff --git a/liblwgeom/lwgeodetic_tree.c b/liblwgeom/lwgeodetic_tree.c
index 9baa8cd3b..a425046a0 100644
--- a/liblwgeom/lwgeodetic_tree.c
+++ b/liblwgeom/lwgeodetic_tree.c
@@ -674,7 +674,7 @@ circ_internal_nodes_sort(CIRC_NODE **nodes, uint32_t num_nodes, const CIRC_NODE
-static double
+double
 circ_tree_distance_tree_internal(const CIRC_NODE* n1, const CIRC_NODE* n2, double threshold, double* min_dist, double* max_dist, GEOGRAPHIC_POINT* closest1, GEOGRAPHIC_POINT* closest2)
 	double max;
@@ -1026,3 +1026,83 @@ lwgeom_calculate_circ_tree(const LWGEOM* lwgeom)
+ * Closest point and closest line functions for geographies.
+LWGEOM *
+geography_tree_closestpoint(const LWGEOM* lwgeom1, const LWGEOM* lwgeom2, double threshold)
+	CIRC_NODE* circ_tree1 = NULL;
+	CIRC_NODE* circ_tree2 = NULL;
+	double min_dist = FLT_MAX;
+	double max_dist = FLT_MAX;
+	GEOGRAPHIC_POINT closest1, closest2;
+	LWGEOM *result;
+	POINT4D p;
+	circ_tree1 = lwgeom_calculate_circ_tree(lwgeom1);
+	circ_tree2 = lwgeom_calculate_circ_tree(lwgeom2);
+	/* Quietly decrease the threshold just a little to avoid cases where */
+	/* the actual spheroid distance is larger than the sphere distance */
+	/* causing the return value to be larger than the threshold value */
+	// double threshold_radians = 0.95 * threshold / spheroid->radius;
+	double threshold_radians = threshold / WGS84_RADIUS;
+	circ_tree_distance_tree_internal(
+		circ_tree1, circ_tree2, threshold_radians,
+		&min_dist, &max_dist, &closest1, &closest2);
+	p.x = rad2deg(closest1.lon);
+	p.y = rad2deg(closest1.lat);
+	result = (LWGEOM *)lwpoint_make2d(lwgeom_get_srid(lwgeom1), p.x, p.y);
+	circ_tree_free(circ_tree1);
+	circ_tree_free(circ_tree2);
+	return result;
+LWGEOM *
+geography_tree_shortestline(const LWGEOM* lwgeom1, const LWGEOM* lwgeom2, double threshold, const SPHEROID *spheroid)
+  LWGEOM *geoms[2];
+  LWGEOM *result;
+  POINT4D p1, p2;
+  uint32_t srid = lwgeom1->srid;
+  double threshold_radians = threshold / spheroid->radius;
+  circ_tree_distance_tree_internal(circ_tree1, circ_tree2, threshold_radians,
+  p1.x = rad2deg(closest1.lon);
+  p1.y = rad2deg(closest1.lat);
+  p2.x = rad2deg(closest2.lon);
+  p2.y = rad2deg(closest2.lat);
+  geoms[0] = (LWGEOM *)lwpoint_make2d(srid, p1.x, p1.y);
+  geoms[1] = (LWGEOM *)lwpoint_make2d(srid, p2.x, p2.y);
+  result = (LWGEOM *)lwline_from_lwgeom_array(srid, 2, geoms);
+  lwgeom_free(geoms[0]);
+  lwgeom_free(geoms[1]);
+  return result;
diff --git a/liblwgeom/lwgeodetic_tree.h b/liblwgeom/lwgeodetic_tree.h
index c367ebf16..90987a6cf 100644
--- a/liblwgeom/lwgeodetic_tree.h
+++ b/liblwgeom/lwgeodetic_tree.h
@@ -56,6 +56,10 @@ CIRC_NODE* lwgeom_calculate_circ_tree(const LWGEOM* lwgeom);
 int circ_tree_get_point(const CIRC_NODE* node, POINT2D* pt);
 int circ_tree_get_point_outside(const CIRC_NODE* node, POINT2D* pt);
+LWGEOM * geography_tree_closestpoint(const LWGEOM* g1, const LWGEOM* g2, double threshold);
+LWGEOM * geography_tree_shortestline(const LWGEOM* g1, const LWGEOM* g2, double threshold, const SPHEROID *spheroid);
 #endif /* _LWGEODETIC_TREE_H */
diff --git a/postgis/geography.h b/postgis/geography.h
index 2cc925ff6..e81547e71 100644
--- a/postgis/geography.h
+++ b/postgis/geography.h
@@ -37,3 +37,4 @@ void geography_valid_type(uint8_t type);
 /* Expand the embedded bounding box in a #GSERIALIZED */
 GSERIALIZED* gserialized_expand(GSERIALIZED *g, double distance);
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index 9a61d7a7a..016559adb 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -867,4 +867,76 @@ CREATE OR REPLACE FUNCTION ST_Intersects(text, text)
+-- Availability: 3.4.0
+CREATE OR REPLACE FUNCTION ST_ClosestPoint(geography, geography, use_spheroid boolean DEFAULT true)
+ 	RETURNS geography
+	AS 'MODULE_PATHNAME', 'geography_closestpoint'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
+CREATE OR REPLACE FUNCTION ST_ClosestPoint(text, text)
+	RETURNS geometry AS
+	$$ SELECT @extschema at .ST_ClosestPoint($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
+	LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
+CREATE OR REPLACE FUNCTION ST_ShortestLine(geography, geography, use_spheroid boolean DEFAULT true)
+	RETURNS geography
+	AS 'MODULE_PATHNAME', 'geography_shortestline'
+CREATE OR REPLACE FUNCTION ST_ShortestLine(text, text)
+	$$ SELECT @extschema at .ST_ShortestLine($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
+CREATE OR REPLACE FUNCTION ST_LineSubstring(geography, float8, float8)
+	RETURNS geography
+	AS 'MODULE_PATHNAME', 'geography_line_substring'
+CREATE OR REPLACE FUNCTION ST_LineSubstring(text, float8, float8)
+	$$ SELECT @extschema at .ST_LineSubstring($1::@extschema at .geometry, $2, $3);  $$
+CREATE OR REPLACE FUNCTION ST_LineLocatePoint(geography, geography, use_spheroid boolean DEFAULT true)
+	RETURNS float
+	AS 'MODULE_PATHNAME', 'geography_line_locate_point'
+CREATE OR REPLACE FUNCTION ST_LineLocatePoint(text, text)
+	RETURNS float AS
+	$$ SELECT @extschema at .ST_LineLocatePoint($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
+CREATE OR REPLACE FUNCTION ST_LineInterpolatePoints(geography, float8, use_spheroid boolean DEFAULT true, repeat boolean DEFAULT true)
+	RETURNS geography
+	AS 'MODULE_PATHNAME', 'geography_line_interpolate_point'
+CREATE OR REPLACE FUNCTION ST_LineInterpolatePoints(text, float8)
+	$$ SELECT @extschema at .ST_LineInterpolatePoints($1::@extschema at .geometry, $2);  $$
+CREATE OR REPLACE FUNCTION ST_LineInterpolatePoint(geography, float8, use_spheroid boolean DEFAULT true)
+	RETURNS geography
+CREATE OR REPLACE FUNCTION ST_LineInterpolatePoint(text, float8)
+	$$ SELECT @extschema at .ST_LineInterpolatePoint($1::@extschema at .geometry, $2);  $$
diff --git a/postgis/geography_measurement.c b/postgis/geography_measurement.c
index 6bda676b3..e52671f4f 100644
--- a/postgis/geography_measurement.c
+++ b/postgis/geography_measurement.c
@@ -66,6 +66,12 @@ Datum geography_project(PG_FUNCTION_ARGS);
 Datum geography_azimuth(PG_FUNCTION_ARGS);
 Datum geography_segmentize(PG_FUNCTION_ARGS);
+Datum geography_line_locate_point(PG_FUNCTION_ARGS);
+Datum geography_line_interpolate_point(PG_FUNCTION_ARGS);
+Datum geography_line_substring(PG_FUNCTION_ARGS);
+Datum geography_closestpoint(PG_FUNCTION_ARGS);
+Datum geography_shortestline(PG_FUNCTION_ARGS);
 PG_FUNCTION_INFO_V1(geography_distance_knn);
 Datum geography_distance_knn(PG_FUNCTION_ARGS)
@@ -135,17 +141,13 @@ Datum geography_distance_uncached(PG_FUNCTION_ARGS)
 	LWGEOM *lwgeom1 = NULL;
 	LWGEOM *lwgeom2 = NULL;
-	GSERIALIZED *g1 = NULL;
-	GSERIALIZED *g2 = NULL;
+	GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
+	GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
 	double distance;
 	double tolerance = FP_TOLERANCE;
 	bool use_spheroid = true;
 	SPHEROID s;
-	/* Get our geometry objects loaded into memory. */
-	g1 = PG_GETARG_GSERIALIZED_P(0);
-	g2 = PG_GETARG_GSERIALIZED_P(1);
 	/* Read our tolerance value. */
 	if ( PG_NARGS() > 2 && ! PG_ARGISNULL(2) )
 		tolerance = PG_GETARG_FLOAT8(2);
@@ -167,7 +169,7 @@ Datum geography_distance_uncached(PG_FUNCTION_ARGS)
 	lwgeom2 = lwgeom_from_gserialized(g2);
 	/* Return NULL on empty arguments. */
-	if ( lwgeom_is_empty(lwgeom1) || lwgeom_is_empty(lwgeom2) )
+	if ( !lwgeom1 || !lwgeom2 || lwgeom_is_empty(lwgeom1) || lwgeom_is_empty(lwgeom2) )
 		PG_FREE_IF_COPY(g1, 0);
 		PG_FREE_IF_COPY(g2, 1);
@@ -180,8 +182,6 @@ Datum geography_distance_uncached(PG_FUNCTION_ARGS)
 	distance = lwgeom_distance_spheroid(lwgeom1, lwgeom2, &s, tolerance);
-	POSTGIS_DEBUGF(2, "[GIST] '%s' got distance %g", __func__, distance);
 	/* Clean up */
 	lwgeom_free(lwgeom1);
 	lwgeom_free(lwgeom2);
@@ -213,7 +213,6 @@ Datum geography_distance(PG_FUNCTION_ARGS)
 	SPHEROID s;
 	if (PG_NARGS() > 2)
 		use_spheroid = PG_GETARG_BOOL(2);
@@ -1107,18 +1106,14 @@ Datum geography_project_geography(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(geography_azimuth);
 	double azimuth;
 	SPHEROID s;
 	uint32_t type1, type2;
-	/* Get our geometry object loaded into memory. */
 	/* Only return for points. */
 	type1 = gserialized_get_type(g1);
 	type2 = gserialized_get_type(g2);
@@ -1154,7 +1149,7 @@ Datum geography_azimuth(PG_FUNCTION_ARGS)
 	/* Return NULL for unknown (same point) azimuth */
-	if( isnan(azimuth) )
+	if( !isfinite(azimuth) )
 		PG_RETURN_NULL();
@@ -1164,26 +1159,19 @@ Datum geography_azimuth(PG_FUNCTION_ARGS)
-** geography_segmentize(GSERIALIZED *g1, double max_seg_length)
-** returns densified geometry with no segment longer than max
+ * ST_Segmentize(geography, double max_seg_length)
+ * Returns densified geometry with no segment longer than maximum.
 PG_FUNCTION_INFO_V1(geography_segmentize);
-	double max_seg_length;
-	uint32_t type1;
-	type1 = gserialized_get_type(g1);
-	/* Convert max_seg_length from metric units to radians */
-	max_seg_length = PG_GETARG_FLOAT8(1) / WGS84_RADIUS;
+	double max_seg_length = PG_GETARG_FLOAT8(1) / WGS84_RADIUS;
+	uint32_t type1 = gserialized_get_type(g1);
 	/* We can't densify points or points, reflect them back */
 	if ( type1 == POINTTYPE || type1 == MULTIPOINTTYPE || gserialized_is_empty(g1) )
@@ -1216,3 +1204,275 @@ Datum geography_segmentize(PG_FUNCTION_ARGS)
+ * ST_LineSubstring(geography line, float start_fraction, float end_fraction)
+ * Return the part of a line between two fractional locations.
+PG_FUNCTION_INFO_V1(geography_line_substring);
+	GSERIALIZED *gs = PG_GETARG_GSERIALIZED_P(0);
+	double from_fraction = PG_GETARG_FLOAT8(1);
+	double to_fraction = PG_GETARG_FLOAT8(2);
+	LWLINE *lwline;
+	LWGEOM *lwresult;
+	GSERIALIZED *result;
+	/* Return NULL on empty argument. */
+	if ( gserialized_is_empty(gs) )
+		PG_FREE_IF_COPY(gs, 0);
+		PG_RETURN_NULL();
+	if ( from_fraction < 0 || from_fraction > 1 )
+		elog(ERROR,"%s: second argument is not within [0,1]", __func__);
+		PG_RETURN_NULL();
+	if ( to_fraction < 0 || to_fraction > 1 )
+		elog(ERROR,"%s: argument arg is not within [0,1]", __func__);
+		PG_RETURN_NULL();
+	if ( from_fraction > to_fraction )
+		elog(ERROR, "%s: second argument must be smaller than third argument", __func__);
+		PG_RETURN_NULL();
+	lwline = lwgeom_as_lwline(lwgeom_from_gserialized(gs));
+	if ( !lwline )
+		elog(ERROR,"%s: first argument is not a line", __func__);
+		PG_RETURN_NULL();
+	lwresult = geography_substring(lwline,
+		from_fraction, to_fraction, FP_TOLERANCE);
+	lwline_free(lwline);
+	lwgeom_set_geodetic(lwresult, true);
+	result = geography_serialize(lwresult);
+	lwgeom_free(lwresult);
+	PG_RETURN_POINTER(result);
+ * ST_LineInterpolatePoint(geography line, float fraction, boolean use_spheroid)
+ * ST_LineInterpolatePoints(geography line, float fraction, boolean use_spheroid)
+ * In-fill geographic line with multiple points using the fraction as the interval
+ * between each point.
+PG_FUNCTION_INFO_V1(geography_line_interpolate_point);
+	double distance_fraction = PG_GETARG_FLOAT8(1);
+	/* Read calculation type */
+	bool use_spheroid = PG_GETARG_BOOL(2);
+	/* Read repeat mode */
+	bool repeat = (PG_NARGS() > 3) && PG_GETARG_BOOL(3);
+	LWLINE* lwline;
+	LWGEOM* lwresult;
+	SPHEROID s;
+		PG_RETURN_NULL();
+	if ( distance_fraction < 0 || distance_fraction > 1 )
+		elog(ERROR,"%s: second arg is not within [0,1]", __func__);
+		PG_RETURN_NULL();
+	if ( !lwline )
+		elog(ERROR,"%s: first arg is not a line", __func__);
+		PG_RETURN_NULL();
+	/* Initialize spheroid */
+	// spheroid_init_from_srid(fcinfo, srid, &s);
+	spheroid_init(&s, WGS84_MAJOR_AXIS, WGS84_MINOR_AXIS);
+	/* Set to sphere if requested */
+	if ( ! use_spheroid )
+		s.a = s.b = s.radius;
+	lwresult = geography_interpolate_points(lwline, distance_fraction, &s, repeat);
+	lwgeom_free(lwline_as_lwgeom(lwline));
+ * ST_LineLocatePoint(geography line, geography point, bool use_spheroid)
+ * Locate a point along a geographic line.
+PG_FUNCTION_INFO_V1(geography_line_locate_point);
+	GSERIALIZED *gs1 = PG_GETARG_GSERIALIZED_P(0);
+	GSERIALIZED *gs2 = PG_GETARG_GSERIALIZED_P(1);
+	double tolerance = FP_TOLERANCE;
+	SPHEROID s;
+	LWLINE *lwline;
+	LWPOINT *lwpoint;
+	POINTARRAY *pa;
+	POINT4D p, p_proj;
+	double ret;
+	gserialized_error_if_srid_mismatch(gs1, gs2, __func__);
+	if ( gserialized_is_empty(gs1) || gserialized_is_empty(gs2))
+		PG_FREE_IF_COPY(gs1, 0);
+		PG_FREE_IF_COPY(gs2, 1);
+		PG_RETURN_NULL();
+	if ( gserialized_get_type(gs1) != LINETYPE )
+		elog(ERROR,"%s: 1st arg is not a line", __func__);
+		PG_RETURN_NULL();
+	if ( gserialized_get_type(gs2) != POINTTYPE )
+		elog(ERROR,"%s: 2st arg is not a point", __func__);
+		PG_RETURN_NULL();
+	if ( ! use_spheroid ) {
+	else {
+	lwline = lwgeom_as_lwline(lwgeom_from_gserialized(gs1));
+	lwpoint = lwgeom_as_lwpoint(lwgeom_from_gserialized(gs2));
+	pa = lwline->points;
+	lwpoint_getPoint4d_p(lwpoint, &p);
+	ret = ptarray_locate_point_spheroid(pa, &p, &s, tolerance, NULL, &p_proj);
+	PG_RETURN_FLOAT8(ret);
+ * ST_ClosestPoint(geography line, geography point)
+ * Return the point in first input geography that is closest to the
+ * second input geography in 2d
+PG_FUNCTION_INFO_V1(geography_closestpoint);
+	LWGEOM *point, *lwg1, *lwg2;
+	gserialized_error_if_srid_mismatch(g1, g2, __func__);
+	lwg1 = lwgeom_from_gserialized(g1);
+	lwg2 = lwgeom_from_gserialized(g2);
+	/* Return NULL on empty/bad arguments. */
+	if ( !lwg1 || !lwg2 || lwgeom_is_empty(lwg1) || lwgeom_is_empty(lwg2) )
+		PG_FREE_IF_COPY(g1, 0);
+		PG_FREE_IF_COPY(g2, 1);
+		PG_RETURN_NULL();
+	point = geography_tree_closestpoint(lwg1, lwg2, FP_TOLERANCE);
+	result = geography_serialize(point);
+	lwgeom_free(point);
+	lwgeom_free(lwg1);
+	lwgeom_free(lwg2);
+ * ST_ShortestLine(geography, geography)
+ * Return the shortest line between the first and second arguments.
+PG_FUNCTION_INFO_V1(geography_shortestline);
+	GSERIALIZED* g1 = PG_GETARG_GSERIALIZED_P(0);
+	GSERIALIZED* g2 = PG_GETARG_GSERIALIZED_P(1);
+	LWGEOM *line, *lwgeom1, *lwgeom2;
+	GSERIALIZED* result;
+	SPHEROID s;
+	lwgeom1 = lwgeom_from_gserialized(g1);
+	lwgeom2 = lwgeom_from_gserialized(g2);
+		PG_RETURN_NULL();
+	line = geography_tree_shortestline(lwgeom1, lwgeom2, FP_TOLERANCE, &s);
+	if (lwgeom_is_empty(line))
+		PG_RETURN_NULL();
+	result = geography_serialize(line);
+	lwgeom_free(line);
diff --git a/postgis/geography_measurement_trees.h b/postgis/geography_measurement_trees.h
index 501a2c6e1..6446d5d09 100644
--- a/postgis/geography_measurement_trees.h
+++ b/postgis/geography_measurement_trees.h
@@ -27,14 +27,22 @@
 #include "lwgeom_cache.h"
 int geography_dwithin_cache(FunctionCallInfo fcinfo,
-			    SHARED_GSERIALIZED *g1,
-			    SHARED_GSERIALIZED *g2,
-			    const SPHEROID *s,
-			    double tolerance,
-			    int *dwithin);
+	SHARED_GSERIALIZED *g1,
+	SHARED_GSERIALIZED *g2,
+	double tolerance,
+	int *dwithin);
 int geography_distance_cache(FunctionCallInfo fcinfo,
-			     double *distance);
-int geography_tree_distance(const GSERIALIZED* g1, const GSERIALIZED* g2, const SPHEROID* s, double tolerance, double* distance);
+	double *distance);
+int geography_tree_distance(
+	const GSERIALIZED* g1,
+	const GSERIALIZED* g2,
+	const SPHEROID* s,
+	double tolerance,
+	double* distance);
diff --git a/regress/core/geography.sql b/regress/core/geography.sql
index f17bcdfec..1ad7e4e04 100644
--- a/regress/core/geography.sql
+++ b/regress/core/geography.sql
@@ -124,3 +124,31 @@ select 'dwithin_poly_line_1', ST_DWithin('POLYGON((1 1, 2 2, 3 0, 1 1))'::geogra
 select 'dwithin_poly_poly_1', ST_DWithin('POLYGON((0 0, -2 -2, -3 0, 0 0))'::geography, 'POLYGON((1 1, 2 2, 3 0, 1 1))'::geography, 10);
 select 'dwithin_poly_poly_2', ST_DWithin('POLYGON((0 0, -2 -2, -3 0, 0 0))'::geography, 'POLYGON((1 1, 2 2, 3 0, 1 1))'::geography, 300000);
 select 'dwithin_poly_poly_3', ST_DWithin('POLYGON((1 1, -2 -2, -3 0, 1 1))'::geography, 'POLYGON((1 1, 2 2, 3 0, 1 1))'::geography, 300000);
+-- Linear Referencing functions
+SELECT 'lrs_empty_1', ST_LineInterpolatePoint(geography 'Linestring empty', 0.1);
+SELECT 'lrs_empty_2', ST_LineInterpolatePoints(geography 'Linestring empty', 0.1, true);
+SELECT 'lrs_empty_3', ST_LineLocatePoint(geography 'Linestring empty', 'Point(45 45)', true);
+SELECT 'lrs_empty_4', ST_LineSubstring(geography 'Linestring empty', 0.1, 0.2);
+SELECT 'lrs_empty_5', ST_ClosestPoint(geography 'Linestring empty', 'Point(45 45)', true);
+SELECT 'lrs_empty_6', ST_ShortestLine(geography 'Linestring empty', 'Point(45 45)', true);
+SELECT 'lrs_lip_1', ST_AsText(ST_LineInterpolatePoint(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 0.0), 2);
+SELECT 'lrs_lip_2', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 0.0, true), 2);
+SELECT 'lrs_lip_3', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 1.0, false), 2);
+SELECT 'lrs_lip_4', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 0.1, true), 2);
+SELECT 'lrs_llp_1', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Point(25 0)')::numeric, 2);
+SELECT 'lrs_llp_2', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Point(-5 0)')::numeric, 2);
+SELECT 'lrs_llp_3', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Point(55 0)')::numeric, 2);
+SELECT 'lrs_llp_4', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Linestring(25 0,26 1)')::numeric, 2);
+SELECT 'lrs_substr_1', ST_AsText(ST_LineSubstring(geography 'linestring(0 1, 100 1)', 0.1, 0.2),2);
+--SELECT 'lrs_cp_1', ST_AsText(ST_ClosestPoint(geography 'linestring(0 1, 50 1)', 'Point(25 0)'), 3);
+--SELECT 'lrs_cp_2', ST_AsText(ST_ClosestPoint(geography 'Point(25 0)', geography 'linestring(0 1, 50 1)'), 3);
+SELECT 'lrs_sl_1', ST_AsText(ST_ShortestLine(geography 'linestring(0 1, 50 1)', 'Point(25 0)', true), 2);
diff --git a/regress/core/geography_expected b/regress/core/geography_expected
index 97846a1a0..4fc2e88c5 100644
--- a/regress/core/geography_expected
+++ b/regress/core/geography_expected
@@ -49,3 +49,19 @@ dwithin_poly_line_1|t
 dwithin_poly_poly_1|f
 dwithin_poly_poly_2|t
 dwithin_poly_poly_3|t
+lrs_empty_1|
+lrs_empty_2|
+lrs_empty_3|
+lrs_empty_4|
+lrs_empty_5|
+lrs_empty_6|
+lrs_lip_1|POINT(4.35 50.85)
+lrs_lip_2|POINT(4.35 50.85)
+lrs_lip_3|POINT(37.62 55.76)
+lrs_lip_4|MULTIPOINT((7.22 51.72),(10.23 52.53),(13.37 53.26),(16.63 53.91),(20 54.46),(23.45 54.93),(26.96 55.29),(30.51 55.55),(34.07 55.7),(37.62 55.76))
+lrs_llp_1|0.50
+lrs_llp_2|0.00
+lrs_llp_3|1.00
+ERROR:  geography_line_locate_point: 2st arg is not a point
+lrs_substr_1|LINESTRING(6.37 1.13,14.43 1.27)
+lrs_sl_1|LINESTRING(25 0,25 1.1)
Summary of changes:
 doc/reference_lrs.xml                 |  34 +++
 doc/reference_measure.xml             |  26 +-
 liblwgeom/Makefile.in                 |   1 +
 liblwgeom/liblwgeom.h.in              |  20 ++
 liblwgeom/lwgeodetic_measures.c       | 561 ++++++++++++++++++++++++++++++++++
 liblwgeom/lwgeodetic_tree.c           |  82 ++++-
 liblwgeom/lwgeodetic_tree.h           |   4 +
 postgis/geography.h                   |   1 +
 postgis/geography.sql.in              |  72 +++++
 postgis/geography_measurement.c       | 322 +++++++++++++++++--
 postgis/geography_measurement_trees.h |  28 +-
 regress/core/geography.sql            |  28 ++
 regress/core/geography_expected       |  16 +
 13 files changed, 1149 insertions(+), 46 deletions(-)
 create mode 100644 liblwgeom/lwgeodetic_measures.c
hooks/post-receive
