[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1204-ge7b473841
Tue Jul 11 02:35:36 PDT 2023
the project "PostGIS".
       via  e7b473841608110b1263f553612405657e041cb4 (commit)
      from  56f36200e7ab1e7ff9d69385f675c62e85105181 (commit)
revisions in full, below.
commit e7b473841608110b1263f553612405657e041cb4
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 11 11:35:08 2023 +0200
    [woodie] don't miss to run the prepare step if only po/* changed
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 26efa4a41..6010a6401 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -22,7 +22,20 @@ pipeline:
       - ../configure --without-pg
       - make postgis_revision.h
     when:
-      path: *when_path
+      path:
+        include:
+          # Common docs path
+          # related config files
+          - ".woodpecker/docs.yml"
+          # Makefiles
+          - "doc/Makefile.in"
+          # XML sources
+          - "doc/*.xml"
+          # Internationalization Makefiles
+          - "doc/po/Makefile.local"
+          # Localized assets
+          - "doc/po/*/Makefile.in"
+          - "doc/po/*/*.po"
   check-xml:
     image: *test_image
     commands:
Summary of changes:
 .woodpecker/docs.yml | 15 ++++++++++++++-
 1 file changed, 14 insertions(+), 1 deletion(-)
hooks/post-receive
