[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1207-ga53150336
Tue Jul 11 13:28:52 PDT 2023
the project "PostGIS".
       via  a53150336c03aa34887a0f451240e9aaf6ee3d56 (commit)
      from  b21da4cec0b1578488baf85834eacaa66e6bd81d (commit)
revisions in full, below.
commit a53150336c03aa34887a0f451240e9aaf6ee3d56
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jul 11 13:28:31 2023 -0700
    Rename ST_CoverageInvalidEdges to ST_CoverageInvalidLocations
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index bbcad7cf5..4b00af880 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -87,7 +87,7 @@ GENERATED_IMAGES= \
 	st_concavehull03.png \
 	st_concavehull04.png \
 	st_convexhull01.png \
-	st_coverageinvalidlocations01.png \
+	ST_coverageinvalidedges01.png \
 	st_coveragesimplify01.png \
 	st_coveragesimplify02.png \
 	st_coverageunion01.png \
diff --git a/doc/html/images/wkt/st_coverageinvalidlocations01.wkt b/doc/html/images/wkt/st_coverageinvalidedges01.wkt
similarity index 100%
rename from doc/html/images/wkt/st_coverageinvalidlocations01.wkt
rename to doc/html/images/wkt/st_coverageinvalidedges01.wkt
diff --git a/doc/po/templates/reference_coverage.xml.pot b/doc/po/templates/reference_coverage.xml.pot
index e31aa0a63..63caae4fe 100644
--- a/doc/po/templates/reference_coverage.xml.pot
+++ b/doc/po/templates/reference_coverage.xml.pot
@@ -34,7 +34,7 @@ msgstr ""
 #. Tag: refname
 #: reference_coverage.xml:15
 #, no-c-format
-msgid "ST_CoverageInvalidLocations"
+msgid "ST_CoverageInvalidEdges"
 msgstr ""
 #. Tag: refpurpose
@@ -49,7 +49,7 @@ msgstr ""
 #: reference_coverage.xml:22
 #, no-c-format
 msgid ""
-"<funcdef>geometry <function>ST_CoverageInvalidLocations</function></funcdef> "
+"<funcdef>geometry <function>ST_CoverageInvalidEdges</function></funcdef> "
 "<paramdef><type>geometry winset </type> <parameter>geom</parameter></"
 "paramdef> <paramdef><type>float8 </type> <parameter>tolerance = 0</"
 "parameter></paramdef>"
@@ -156,7 +156,7 @@ msgid ""
 "  (4, 'POLYGON ((180 40, 120 10, 100 70, 140 80, 190 80, 180 40))'::"
 "geometry)\n"
 ")\n"
-"SELECT id, ST_AsText(ST_CoverageInvalidLocations(geom) OVER ())\n"
+"SELECT id, ST_AsText(ST_CoverageInvalidEdges(geom) OVER ())\n"
 "  FROM coverage;\n"
 "\n"
 " id |               st_astext\n"
@@ -174,7 +174,7 @@ msgstr ""
 msgid ""
 "-- Test entire table for coverage validity\n"
 "SELECT true = ALL (\n"
-"    SELECT ST_CoverageInvalidLocations(geom) OVER () IS NULL\n"
+"    SELECT ST_CoverageInvalidEdges(geom) OVER () IS NULL\n"
 "    FROM coverage\n"
 msgstr ""
@@ -253,7 +253,7 @@ msgstr ""
 msgid ""
 "If the input is not a valid coverage there may be unexpected artifacts in "
 "the output (such as boundary intersections, or separated boundaries which "
-"appeared to be shared). Use <xref linkend=\"ST_CoverageInvalidLocations\"/> "
+"appeared to be shared). Use <xref linkend=\"ST_CoverageInvalidEdges\"/> "
 "to determine if a coverage is valid."
 msgstr ""
@@ -336,7 +336,7 @@ msgstr ""
 msgid ""
 "the output (such as unmerged or overlapping polygons). Use <xref "
-"linkend=\"ST_CoverageInvalidLocations\"/> to determine if a coverage is "
+"linkend=\"ST_CoverageInvalidEdges\"/> to determine if a coverage is "
 "valid."
 msgstr ""
diff --git a/doc/reference_coverage.xml b/doc/reference_coverage.xml
index 2bddc3b64..b6fc6250e 100644
--- a/doc/reference_coverage.xml
+++ b/doc/reference_coverage.xml
@@ -10,9 +10,9 @@
   <title>Coverages</title>
-  <refentry id="ST_CoverageInvalidLocations">
+  <refentry id="ST_CoverageInvalidEdges">
     <refnamediv>
-      <refname>ST_CoverageInvalidLocations</refname>
+      <refname>ST_CoverageInvalidEdges</refname>
       <refpurpose>Window function that finds locations where polygons fail to form a valid coverage.</refpurpose>
     </refnamediv>
@@ -20,7 +20,7 @@
     <refsynopsisdiv>
       <funcsynopsis>
         <funcprototype>
-          <funcdef>geometry <function>ST_CoverageInvalidLocations</function></funcdef>
+          <funcdef>geometry <function>ST_CoverageInvalidEdges</function></funcdef>
             <parameter>geom</parameter></paramdef>
@@ -72,7 +72,7 @@
         <informalfigure>
           <mediaobject>
               <imageobject>
-              <imagedata fileref="images/st_coverageinvalidlocations01.png" />
+              <imagedata fileref="images/st_coverageinvalidedges01.png" />
               </imageobject>
               <caption><para>Invalid edges caused by overlap and non-matching vertices</para></caption>
           </mediaobject>
@@ -84,7 +84,7 @@
   (3, 'POLYGON ((140 190, 190 190, 190 80, 140 80, 140 190))'::geometry),
   (4, 'POLYGON ((180 40, 120 10, 100 70, 140 80, 190 80, 180 40))'::geometry)
-SELECT id, ST_AsText(ST_CoverageInvalidLocations(geom) OVER ())
+SELECT id, ST_AsText(ST_CoverageInvalidEdges(geom) OVER ())
   FROM coverage;
  id |               st_astext
@@ -97,7 +97,7 @@ SELECT id, ST_AsText(ST_CoverageInvalidLocations(geom) OVER ())
       <programlisting>-- Test entire table for coverage validity
 SELECT true = ALL (
-    SELECT ST_CoverageInvalidLocations(geom) OVER () IS NULL
+    SELECT ST_CoverageInvalidEdges(geom) OVER () IS NULL
     FROM coverage
       </programlisting>
@@ -152,7 +152,7 @@ SELECT true = ALL (
       <para>To simplify only the "internal" edges of the coverage (those that are shared by two polygons) set the <parameter>simplifyBoundary</parameter> parameter to false.</para>
       <note><para>If the input is not a valid coverage there may be unexpected artifacts in the output (such as boundary intersections, or separated boundaries which appeared to be shared).
-      Use <xref linkend="ST_CoverageInvalidLocations" /> to determine if a coverage is valid.
+      Use <xref linkend="ST_CoverageInvalidEdges" /> to determine if a coverage is valid.
       </para></note>
       <para role="availability" conformance="3.4.0">Availability: 3.4.0 - requires GEOS >= 3.12.0</para>
@@ -211,7 +211,7 @@ SELECT id, ST_AsText(ST_CoverageSimplify(geom, 30) OVER ())
     <refsection>
       <title>See Also</title>
       <para>
-        <xref linkend="ST_CoverageInvalidLocations" />
+        <xref linkend="ST_CoverageInvalidEdges" />
       </para>
     </refsection>
@@ -244,7 +244,7 @@ SELECT id, ST_AsText(ST_CoverageSimplify(geom, 30) OVER ())
       </para>
       <note><para>If the input is not a valid coverage there may be unexpected artifacts in the output (such as unmerged or overlapping polygons).
       </para></note>
       <para role="availability" conformance="3.4.0">Availability: 3.4.0 - requires GEOS >= 3.8.0</para>
@@ -299,7 +299,7 @@ MULTIPOLYGON (((10 150, 80 190, 110 150, 140 80, 120 10, 10 10, 10 150), (50 60,
     <refsection>
       <para>
-        <xref linkend="ST_CoverageInvalidLocations" />,
+        <xref linkend="ST_CoverageInvalidEdges" />,
         <xref linkend="ST_Union" />
       </para>
     </refsection>
diff --git a/postgis/lwgeom_window.c b/postgis/lwgeom_window.c
index af34e70fb..1132daa84 100644
--- a/postgis/lwgeom_window.c
+++ b/postgis/lwgeom_window.c
@@ -767,9 +767,9 @@ Datum ST_CoverageSimplify(PG_FUNCTION_ARGS)
-extern Datum ST_CoverageInvalidLocations(PG_FUNCTION_ARGS);
-PG_FUNCTION_INFO_V1(ST_CoverageInvalidLocations);
-Datum ST_CoverageInvalidLocations(PG_FUNCTION_ARGS)
+extern Datum ST_CoverageInvalidEdges(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_CoverageInvalidEdges);
+Datum ST_CoverageInvalidEdges(PG_FUNCTION_ARGS)
 #if POSTGIS_GEOS_VERSION < 31200
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 016233f6d..c79ed40cb 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4441,9 +4441,9 @@ CREATE OR REPLACE FUNCTION ST_CoverageSimplify (geom geometry, tolerance float8,
 	_COST_HIGH;
 -- Availability: 3.4.0
-CREATE OR REPLACE FUNCTION ST_CoverageInvalidLocations (geom geometry, tolerance float8 default 0.0)
+CREATE OR REPLACE FUNCTION ST_CoverageInvalidEdges (geom geometry, tolerance float8 default 0.0)
 	RETURNS geometry
-	AS 'MODULE_PATHNAME', 'ST_CoverageInvalidLocations'
+	AS 'MODULE_PATHNAME', 'ST_CoverageInvalidEdges'
 	LANGUAGE 'c' IMMUTABLE STRICT WINDOW PARALLEL SAFE
 	_COST_HIGH;
diff --git a/regress/core/coverage.sql b/regress/core/coverage.sql
index 287e66c75..f0d1f5a9b 100644
--- a/regress/core/coverage.sql
+++ b/regress/core/coverage.sql
@@ -3,7 +3,7 @@ CREATE TABLE coverage (id integer, seq integer, geom geometry);
 SELECT 'empty table a' AS test,
   id, ST_AsText(GEOM) AS input,
-  ST_AsText(ST_CoverageInvalidLocations(geom) OVER (partition by id)) AS invalid,
+  ST_AsText(ST_CoverageInvalidEdges(geom) OVER (partition by id)) AS invalid,
   ST_AsText(ST_CoverageSimplify(geom, 1.0) OVER (partition by id)) AS simple
 FROM coverage
 ORDER BY id, seq;
@@ -18,7 +18,7 @@ INSERT INTO coverage VALUES
 SELECT 'one partition a' AS test,
   id, seq, ST_AsText(GEOM) AS input,
 FROM coverage
 ORDER BY id, seq;
@@ -31,7 +31,7 @@ INSERT INTO coverage VALUES
 SELECT 'two partition a' AS test,
   id, seq, ST_AsText(geom) AS input,
 FROM coverage
 ORDER BY id, seq;
@@ -43,7 +43,7 @@ INSERT INTO coverage VALUES
 SELECT 'three partition a' AS test,
 FROM coverage
 ORDER BY id, seq;
Summary of changes:
 doc/html/images/Makefile.in                          |  2 +-
 ...locations01.wkt => st_coverageinvalidedges01.wkt} |  0
 doc/po/templates/reference_coverage.xml.pot          | 12 ++++++------
 doc/reference_coverage.xml                           | 20 ++++++++++----------
 postgis/lwgeom_window.c                              |  6 +++---
 postgis/postgis.sql.in                               |  4 ++--
 regress/core/coverage.sql                            |  8 ++++----
 7 files changed, 26 insertions(+), 26 deletions(-)
 rename doc/html/images/wkt/{st_coverageinvalidlocations01.wkt => st_coverageinvalidedges01.wkt} (100%)
hooks/post-receive
