[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1208-g4c7fc0145
Wed Jul 12 01:19:14 PDT 2023
the project "PostGIS".
       via  4c7fc01454a3ae81ef03952e5d7715f937451c11 (commit)
      from  a53150336c03aa34887a0f451240e9aaf6ee3d56 (commit)
revisions in full, below.
commit 4c7fc01454a3ae81ef03952e5d7715f937451c11
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 12 10:17:46 2023 +0200
    Use html output rather than text for postgis_cheatsheet
    Moves toward easier internationalization of headers
    References #5435
diff --git a/doc/xsl/postgis_cheatsheet.html.xsl b/doc/xsl/postgis_cheatsheet.html.xsl
index a37d1c5ce..7a587ed8b 100644
--- a/doc/xsl/postgis_cheatsheet.html.xsl
+++ b/doc/xsl/postgis_cheatsheet.html.xsl
@@ -1,5 +1,8 @@
-<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
+<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
+<xsl:stylesheet version="1.0"
+xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
 	 Copyright 2011, Regina Obe
@@ -11,15 +14,14 @@
 	<xsl:include href="common_utils.xsl" />
 	<xsl:include href="common_cheatsheet.xsl" />
-	<xsl:output method="text" />
+	<xsl:output method="html" />
 <xsl:template match="/">
-	<xsl:text><![CDATA[<html>
-<head>
-<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
-<title>PostGIS Cheat Sheet</title>
-	<style type="text/css">
+	<html>
+		<head>
+			<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
+			<title>PostGIS Cheat Sheet</title>
+			<style type="text/css">
 table { page-break-inside:avoid; page-break-after:auto }
 tr    { page-break-inside:avoid; page-break-after:avoid }
 thead { display:table-header-group }
@@ -32,7 +34,12 @@ body {
 @media screen { a , a:hover, a:focus, a:active{text-decoration: underline} }
 .comment {font-size:x-small;color:green;font-family:"courier new"}
-.notes {font-size:x-small;color:#dd1111;font-weight:500;font-family:verdana}
+.notes {
+	font-size:x-small;
+	color:#dd1111;
+	font-weight:500;
+	font-family:verdana;
 #example_heading {
 	border-bottom: 1px solid #000;
 	margin: 10px 15px 10px 85px;
@@ -64,9 +71,9 @@ body {
 .section {
 	border: 1px solid #000;
 	margin: 4px;
-	]]></xsl:text>
-	<xsl:choose><xsl:when test="$output_purpose = 'false'"><![CDATA[width: 100%]]></xsl:when><xsl:otherwise><![CDATA[width: 100%;]]></xsl:otherwise></xsl:choose>
-<xsl:text><![CDATA[
+	<xsl:choose><xsl:when test="$output_purpose = 'false'">width: 100%</xsl:when><xsl:otherwise>width: 100%;</xsl:otherwise></xsl:choose>
 	float: left;
@@ -117,25 +124,31 @@ h1 {
 	font-size: 14pt;
 code {font-size: 8pt}
-</style>
-	</head><body><h1 style='text-align:center'>PostGIS ]]></xsl:text> <xsl:value-of select="$postgis_version" /><xsl:text><![CDATA[ Cheatsheet</h1>]]></xsl:text>
-		<xsl:text><![CDATA[<span class='notes'>New in this release <sup>1</sup> Enhanced in this release <sup>2</sup>  aggregate <sup>agg</sup>   window function <sup>W</sup>  Requires GEOS 3.9 or higher<sup>g3.9</sup>     2.5/3D support<sup>3d</sup> SQL-MM<sup>mm</sup>  Supports geography <sup>G</sup></span><div id="content_functions">]]></xsl:text>
-			<xsl:apply-templates select="/book/chapter[@id='reference']" />
-			<xsl:text><![CDATA[</div>]]></xsl:text>
-			<xsl:text><![CDATA[<div id="content_examples">]]></xsl:text>
-			<!-- examples go here -->
-			<xsl:if test="$include_examples='true'">
-			<xsl:apply-templates select="//chapter[@id='reference']/sect1[count(//refentry//refsection//programlisting) > 0]"   />
-			</xsl:if>
-			<xsl:text><![CDATA[</body></html>]]></xsl:text>
+			</style>
+		</head>
+		<body><h1 style='text-align:center'>PostGIS  <xsl:value-of select="$postgis_version" /> Cheatsheet</h1>
+			<span class='notes'>
+				<!-- TODO: make text equally distributed horizontally ? -->
+				New in this release <sup>1</sup>
+				Enhanced in this release <sup>2</sup>
+				Aggregate <sup>agg</sup>
+				Window function <sup>W</sup>
+				Requires GEOS 3.9 or higher<sup>g3.9</sup>
+				2.5/3D support<sup>3d</sup>
+				SQL-MM<sup>mm</sup>
+				Supports geography <sup>G</sup>
+			</span>
+			<div id="content_functions">
+				<xsl:apply-templates select="/book/chapter[@id='reference']" />
+			</div>
+		</body>
+	</html>
 </xsl:template>
     <xsl:template match="chapter" name="function_list">
-    	<![CDATA[<div id="content_functions_left">]]>
+			<div id="content_functions_left">
     	<xsl:variable name="col_func_count"><xsl:value-of select="count(descendant::*//funcprototype) div 1.65" /></xsl:variable>
@@ -145,80 +158,59 @@ code {font-size: 8pt}
 			<xsl:variable name="col_cur"><xsl:value-of select="count(current()//funcprototype) + count(preceding-sibling::*//funcprototype)"/></xsl:variable>
 			<xsl:if test="$col_cur >$col_func_count and count(preceding-sibling::*//funcprototype) < $col_func_count ">
-				<![CDATA[</div><div id="content_functions_right">]]>
+				<![CDATA[
+					</div><div id="content_functions_right">
 			</xsl:if>
 			<!--Beginning of section -->
-			<xsl:text><![CDATA[<table class="section"><tr><th colspan="2">]]></xsl:text><xsl:value-of select="title" />
+			<table class="section"><tr><th colspan="2"><xsl:value-of select="title" />
 				<!-- end of section header beginning of function list -->
-				<xsl:text><![CDATA[</th></tr>]]></xsl:text>
+				</th></tr>
 			<xsl:for-each select="current()//refentry">
 				<!-- add row for each function and alternate colors of rows -->
 				<!-- , hyperlink to online manual -->
-		 		<![CDATA[<tr]]> class="<xsl:choose><xsl:when test="position() mod 2 = 0">evenrow</xsl:when><xsl:otherwise>oddrow</xsl:otherwise></xsl:choose>" <![CDATA[><td colspan='2'><span class='func'>]]><xsl:text><![CDATA[<a href="]]></xsl:text><xsl:value-of select="$linkstub" /><xsl:value-of select="@id" />.html<xsl:text><![CDATA[" target="_blank">]]></xsl:text><xsl:value-of select="refnamediv/refname" /><xsl:text><![CDATA[</a>]]></xsl:text><![CDATA[</span>]]><xsl:if test="contains(.,$new_tag)"><![CDATA[<sup>1</sup> ]]></xsl:if>
+				<tr>
+					<xsl:attribute name="class">
+						<xsl:choose>
+							<xsl:when test="position() mod 2 = 0">evenrow</xsl:when>
+							<xsl:otherwise>oddrow</xsl:otherwise>
+						</xsl:choose>
+					</xsl:attribute>
+				<td colspan='2'>
+					<span class='func'>
+						<a target="_blank">
+							<xsl:attribute name="href">
+								<xsl:value-of select="concat(concat($linkstub, @id), '.html')" />
+							</xsl:attribute>
+							<xsl:value-of select="refnamediv/refname" />
+						</a>
+					</span>
+				<xsl:if test="contains(.,$new_tag)"><sup>1</sup> </xsl:if>
 		 		<!-- enhanced tag -->
-		 		<xsl:if test="contains(.,$enhanced_tag)"><![CDATA[<sup>2</sup> ]]></xsl:if>
-		 		<xsl:if test="contains(.,'implements the SQL/MM')"><![CDATA[<sup>mm</sup> ]]></xsl:if>
-		 		<xsl:if test="contains(refsynopsisdiv/funcsynopsis,'geography') or contains(refsynopsisdiv/funcsynopsis/funcprototype/funcdef,'geography')"><![CDATA[<sup>G</sup>  ]]></xsl:if>
-		 		<xsl:if test="contains(.,'GEOS >= 3.9')"><![CDATA[<sup>g3.9</sup> ]]></xsl:if>
-		 		<xsl:if test="contains(.,'This function supports 3d')"><![CDATA[<sup>3d</sup> ]]></xsl:if>
+		 		<xsl:if test="contains(.,$enhanced_tag)"><sup>2</sup> </xsl:if>
+		 		<xsl:if test="contains(.,'implements the SQL/MM')"><sup>mm</sup> </xsl:if>
+		 		<xsl:if test="contains(refsynopsisdiv/funcsynopsis,'geography') or contains(refsynopsisdiv/funcsynopsis/funcprototype/funcdef,'geography')"><sup>G</sup>  </xsl:if>
+		 		<xsl:if test="contains(.,'GEOS >= 3.9')"><sup>g3.9</sup> </xsl:if>
+		 		<xsl:if test="contains(.,'This function supports 3d')"><sup>3d</sup> </xsl:if>
 		 		<!-- if only one proto just dispaly it on first line -->
 		 		<xsl:if test="count(refsynopsisdiv/funcsynopsis/funcprototype) = 1">
 		 			(<xsl:call-template name="list_in_params"><xsl:with-param name="func" select="refsynopsisdiv/funcsynopsis/funcprototype" /></xsl:call-template>)
 		 		</xsl:if>
-		 		<![CDATA[  ]]>
 		 		<xsl:if test="$output_purpose = 'true'"><xsl:value-of select="refnamediv/refpurpose" /></xsl:if>
 		 		<!-- output different proto arg combos -->
-		 		<xsl:if test="count(refsynopsisdiv/funcsynopsis/funcprototype) > 1"><![CDATA[<span class='func_args'><ol>]]><xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype"><![CDATA[<li>]]><xsl:call-template name="list_in_params"><xsl:with-param name="func" select="." /></xsl:call-template><xsl:if test=".//paramdef[contains(type,' set')] or .//paramdef[contains(type,'geography set')] or
-						.//paramdef[contains(type,'raster set')]"><![CDATA[<sup> agg</sup> ]]></xsl:if><xsl:if test=".//paramdef[contains(type,'winset')]"><![CDATA[ <sup>W</sup> ]]></xsl:if><![CDATA[</li>]]></xsl:for-each>
-		 		<![CDATA[</ol></span>]]></xsl:if>
-		 		<![CDATA[</td></tr>]]>
+		 		<xsl:if test="count(refsynopsisdiv/funcsynopsis/funcprototype) > 1"><span class='func_args'><ol><xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype"><li><xsl:call-template name="list_in_params"><xsl:with-param name="func" select="." /></xsl:call-template><xsl:if test=".//paramdef[contains(type,' set')] or .//paramdef[contains(type,'geography set')] or
+						.//paramdef[contains(type,'raster set')]"><sup> agg</sup> </xsl:if><xsl:if test=".//paramdef[contains(type,'winset')]"> <sup>W</sup> </xsl:if></li></xsl:for-each>
+		 		</ol></span></xsl:if>
+		 		</td></tr>
 		 		</xsl:for-each>
-		 		<![CDATA[</table><br />]]>
+		 		</table><br />
 		 		<!--close section -->
 		 	</xsl:for-each>
-		<![CDATA[</div>]]>
-	</xsl:template>
-	 <xsl:template match="sect1[//refentry//refsection[contains(title,'Example')]]">
-	 		<!-- less than needed for converting html tags in listings so they are printable -->
-	 		<xsl:variable name="lt"><xsl:text><![CDATA[<]]></xsl:text></xsl:variable>
-	 		<!-- only print section header if it has examples - not sure why this is necessary -->
-	 		<xsl:if test="refentry/refsection/programlisting">
-			<!--Beginning of section -->
-				<xsl:text><![CDATA[<table class='example'><tr><th colspan="2" class="example_heading">]]></xsl:text>
-				<xsl:value-of select="title" /> Examples
-				<!-- end of section header beginning of function list -->
-				<!--only pull the first example section of each function -->
-			<xsl:for-each select="refentry//refsection[contains(title,'Example')][1]/programlisting[1]">
-				 <xsl:variable name='plainlisting'>
-					<xsl:call-template name="globalReplace">
-						<xsl:with-param name="outputString" select="."/>
-						<xsl:with-param name="target" select="$lt"/>
-						<xsl:with-param name="replacement" select="'&lt;'"/>
-					</xsl:call-template>
-				</xsl:variable>
-				<xsl:variable name='listing'>
-					<xsl:call-template name="break">
-						<xsl:with-param name="text" select="$plainlisting" />
-				</xsl:variable>
-				<!-- add row for each function and alternate colors of rows -->
-		 		<![CDATA[<tr]]> class="<xsl:choose><xsl:when test="position() mod 2 = 0">evenrow</xsl:when><xsl:otherwise>oddrow</xsl:otherwise></xsl:choose>"<![CDATA[>]]>
-		 		<![CDATA[<td><b>]]><xsl:value-of select="ancestor::refentry/refnamediv/refname" /><![CDATA[</b><br /><code>]]><xsl:value-of select="$listing"  disable-output-escaping="no"/><![CDATA[</code></td></tr>]]>
-		 	</xsl:for-each>
-		 	<![CDATA[</table>]]>
-		 	</xsl:if>
-		 	<!--close section -->
+		</div>
 	</xsl:template>
Summary of changes:
 doc/xsl/postgis_cheatsheet.html.xsl | 158 +++++++++++++++++-------------------
 1 file changed, 75 insertions(+), 83 deletions(-)
hooks/post-receive
