[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1210-gf57a8902f
Wed Jul 12 01:36:54 PDT 2023
the project "PostGIS".
       via  f57a8902f1dcd75a6cca9d958522d9d5c6a535a3 (commit)
       via  6c9adfa052051897ffc467724a199fd6969d1f66 (commit)
      from  4c7fc01454a3ae81ef03952e5d7715f937451c11 (commit)
revisions in full, below.
commit f57a8902f1dcd75a6cca9d958522d9d5c6a535a3
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 12 10:36:31 2023 +0200
    Translate cheatsheet header in italian
diff --git a/doc/po/it_IT/xsl-config.xml.po b/doc/po/it_IT/xsl-config.xml.po
index 547328bf1..dcfda8462 100644
--- a/doc/po/it_IT/xsl-config.xml.po
+++ b/doc/po/it_IT/xsl-config.xml.po
@@ -55,7 +55,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-07-04 20:03+0000\n"
+"POT-Creation-Date: 2023-07-12 08:31+0000\n"
 "PO-Revision-Date: 2023-06-29 14:24+0000\n"
 "Last-Translator: Automatically generated\n"
 "Language-Team: none\n"
@@ -207,3 +207,45 @@ msgstr ""
 #, no-c-format
 msgid "This function supports 3d and will not drop the z-index."
 msgstr "Questa funzione supporta il 3d e non distrugge gli z-index."
+#. Tag: para
+#: xsl-config.xml:169
+#, no-c-format
+msgid "New in this release"
+msgstr "Aggiunta in questo rilascio"
+#. Tag: para
+#: xsl-config.xml:172
+#, no-c-format
+msgid "Enhanced in this release"
+msgstr "Migliorata in questo rilascio"
+#. Tag: para
+#: xsl-config.xml:175
+#, no-c-format
+msgid "Aggregate"
+msgstr "Aggregato"
+#. Tag: para
+#: xsl-config.xml:178
+#, no-c-format
+msgid "Window function"
+msgstr "Funzione finestra"
+#. Tag: para
+#: xsl-config.xml:181
+#, no-c-format
+msgid "Requires GEOS 3.9 or higher"
+msgstr "Richiede GEOS 3.9 o superiore"
+#. Tag: para
+#: xsl-config.xml:184
+#, no-c-format
+msgid "2.5/3D support"
+msgstr "Supporta il 2.5/3D"
+#. Tag: para
+#: xsl-config.xml:187
+#, no-c-format
+msgid "Supports geography"
+msgstr "Supporta il tipo geography"
commit 6c9adfa052051897ffc467724a199fd6969d1f66
Date:   Wed Jul 12 10:30:38 2023 +0200
    Make postgis cheatsheet legend translatable
    See #5435
diff --git a/doc/po/templates/xsl-config.xml.pot b/doc/po/templates/xsl-config.xml.pot
index a313f229e..b17dc0fb4 100644
--- a/doc/po/templates/xsl-config.xml.pot
+++ b/doc/po/templates/xsl-config.xml.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -124,3 +124,45 @@ msgstr ""
 #, no-c-format
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Aggregate"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
diff --git a/doc/xsl-config.xml b/doc/xsl-config.xml
index e30985268..4ddae4c99 100644
--- a/doc/xsl-config.xml
+++ b/doc/xsl-config.xml
@@ -165,4 +165,28 @@
         </para>
     </tags>
+    <cheatsheets>
+        <para role="new_in_release">
+            New in this release
+        </para>
+        <para role="enhanced_in_release">
+            Enhanced in this release
+        </para>
+        <para role="aggregate">
+				Aggregate
+        </para>
+        <para role="window_function">
+				Window function
+        </para>
+        <para role="requires_geos_3.9_or_higher">
+				Requires GEOS 3.9 or higher
+        </para>
+        <para role="z_support">
+				2.5/3D support
+        </para>
+        <para role="geography_support">
+				Supports geography
+        </para>
+    </cheatsheets>
 </config>
diff --git a/doc/xsl/common_cheatsheet.xsl b/doc/xsl/common_cheatsheet.xsl
index acb56a102..6ee0faa64 100644
--- a/doc/xsl/common_cheatsheet.xsl
+++ b/doc/xsl/common_cheatsheet.xsl
@@ -6,6 +6,7 @@
 <xsl:variable name='include_examples'>false</xsl:variable>
 <xsl:variable name='output_purpose'>true</xsl:variable>
 <xsl:variable name='linkstub'>https://postgis.net/docs/manual-<xsl:value-of select="$postgis_version" />/<xsl:value-of select="$postgis_language" /></xsl:variable>
+<xsl:variable name="cheatsheets_config" select="document('xsl-config.xml')//cheatsheets" />
 <!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function -->
diff --git a/doc/xsl/postgis_cheatsheet.html.xsl b/doc/xsl/postgis_cheatsheet.html.xsl
index 7a587ed8b..699c99341 100644
--- a/doc/xsl/postgis_cheatsheet.html.xsl
+++ b/doc/xsl/postgis_cheatsheet.html.xsl
@@ -129,14 +129,21 @@ code {font-size: 8pt}
 		<body><h1 style='text-align:center'>PostGIS  <xsl:value-of select="$postgis_version" /> Cheatsheet</h1>
 			<span class='notes'>
 				<!-- TODO: make text equally distributed horizontally ? -->
-				New in this release <sup>1</sup>
-				Enhanced in this release <sup>2</sup>
-				Aggregate <sup>agg</sup>
-				Window function <sup>W</sup>
-				Requires GEOS 3.9 or higher<sup>g3.9</sup>
-				2.5/3D support<sup>3d</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='new_in_release']" />
+					<sup>1</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='enhanced_in_release']" />
+					<sup>2</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='aggregate']" />
+					<sup>agg</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='window_function']" />
+					<sup>W</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='requires_geos_3.9_or_higher']" />
+					<sup>g3.9</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='z_support']" />
+					<sup>3d</sup>
 				SQL-MM<sup>mm</sup>
-				Supports geography <sup>G</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='geography_support']" />
+					<sup>G</sup>
 			</span>
 			<div id="content_functions">
 				<xsl:apply-templates select="/book/chapter[@id='reference']" />
Summary of changes:
 doc/po/it_IT/xsl-config.xml.po      | 44 ++++++++++++++++++++++++++++++++++++-
 doc/po/templates/xsl-config.xml.pot | 44 ++++++++++++++++++++++++++++++++++++-
 doc/xsl-config.xml                  | 24 ++++++++++++++++++++
 doc/xsl/common_cheatsheet.xsl       |  1 +
 doc/xsl/postgis_cheatsheet.html.xsl | 21 ++++++++++++------
 5 files changed, 125 insertions(+), 9 deletions(-)
hooks/post-receive
