[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1216-gd92ef780d
Wed Jul 12 04:01:13 PDT 2023
the project "PostGIS".
       via  d92ef780d2183eb70fd831125657ffa01bea6edb (commit)
       via  f8adda875cdf101423ce340308ad96b43121ee93 (commit)
      from  b7e9771603f21ee28fcca99f4cf0de268e470b0a (commit)
revisions in full, below.
commit d92ef780d2183eb70fd831125657ffa01bea6edb
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 12 13:01:01 2023 +0200
    Refactor sfcgal cheatsheet to use shared templates
    References #5435
diff --git a/doc/xsl/common_cheatsheet.xsl b/doc/xsl/common_cheatsheet.xsl
index af4a8e92b..782ac582d 100644
--- a/doc/xsl/common_cheatsheet.xsl
+++ b/doc/xsl/common_cheatsheet.xsl
@@ -55,63 +55,80 @@
     <!--count(preceding-sibling::*/refentry/refsynopsisdiv/funcsynopsis/funcprototype)-->
 		<xsl:for-each select="sect1[count(//funcprototype) > 0 and not( contains(@id,'sfcgal') )]">
-			<xsl:variable name="col_cur"><xsl:value-of select="count(current()//funcprototype) + count(preceding-sibling::*//funcprototype)"/></xsl:variable>
+			 <xsl:apply-templates select="." />
+		</xsl:for-each>
+	</div>
+</xsl:template>
+<xsl:template match="sect1">
+	<xsl:variable name="col_cur"><xsl:value-of select="count(current()//funcprototype) + count(preceding-sibling::*//funcprototype)"/></xsl:variable>
-			<xsl:if test="$col_cur >$col_func_count and count(preceding-sibling::*//funcprototype) < $col_func_count ">
-					</div><div id="content_functions_right">
-			</xsl:if>
+	<xsl:if test="$col_cur >$col_func_count and count(preceding-sibling::*//funcprototype) < $col_func_count ">
+			</div><div id="content_functions_right">
+	</xsl:if>
-			<!--Beginning of section -->
-			<table class="section"><tr><th colspan="2"><xsl:value-of select="title" />
-				<!-- end of section header beginning of function list -->
-				</th></tr>
-			<xsl:for-each select="current()//refentry">
-				<!-- add row for each function and alternate colors of rows -->
-				<!-- , hyperlink to online manual -->
-				<tr>
-					<xsl:attribute name="class">
-						<xsl:choose>
-							<xsl:when test="position() mod 2 = 0">evenrow</xsl:when>
-							<xsl:otherwise>oddrow</xsl:otherwise>
-						</xsl:choose>
+	<!--Beginning of section -->
+	<table class="section"><tr><th colspan="2"><xsl:value-of select="title" />
+		<!-- end of section header beginning of function list -->
+		</th></tr>
+	<xsl:for-each select="current()//refentry">
+		<!-- add row for each function and alternate colors of rows -->
+		<!-- , hyperlink to online manual -->
+		<tr>
+			<xsl:attribute name="class">
+				<xsl:choose>
+					<xsl:when test="position() mod 2 = 0">evenrow</xsl:when>
+					<xsl:otherwise>oddrow</xsl:otherwise>
+				</xsl:choose>
+			</xsl:attribute>
+		<td colspan='2'>
+			<span class='func'>
+				<a target="_blank">
+					<xsl:attribute name="href">
+						<xsl:value-of select="concat(concat($linkstub, @id), '.html')" />
 					</xsl:attribute>
-				<td colspan='2'>
-					<span class='func'>
-						<a target="_blank">
-							<xsl:attribute name="href">
-								<xsl:value-of select="concat(concat($linkstub, @id), '.html')" />
-							</xsl:attribute>
-							<xsl:value-of select="refnamediv/refname" />
-						</a>
-					</span>
-				<xsl:if test="contains(.,$new_tag)"><sup>1</sup> </xsl:if>
-		 		<!-- enhanced tag -->
-		 		<xsl:if test="contains(.,$enhanced_tag)"><sup>2</sup> </xsl:if>
-		 		<xsl:if test="contains(.,'implements the SQL/MM')"><sup>mm</sup> </xsl:if>
-		 		<xsl:if test="contains(refsynopsisdiv/funcsynopsis,'geography') or contains(refsynopsisdiv/funcsynopsis/funcprototype/funcdef,'geography')"><sup>G</sup>  </xsl:if>
-		 		<xsl:if test="contains(.,'GEOS >= 3.9')"><sup>g3.9</sup> </xsl:if>
-		 		<xsl:if test="contains(.,'This function supports 3d')"><sup>3d</sup> </xsl:if>
-		 		<!-- if only one proto just dispaly it on first line -->
-		 		<xsl:if test="count(refsynopsisdiv/funcsynopsis/funcprototype) = 1">
-		 			(<xsl:call-template name="list_in_params"><xsl:with-param name="func" select="refsynopsisdiv/funcsynopsis/funcprototype" /></xsl:call-template>)
-		 		</xsl:if>
-		 		<xsl:if test="$output_purpose = 'true'"><xsl:value-of select="refnamediv/refpurpose" /></xsl:if>
-		 		<!-- output different proto arg combos -->
-		 		<xsl:if test="count(refsynopsisdiv/funcsynopsis/funcprototype) > 1"><span class='func_args'><ol><xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype"><li><xsl:call-template name="list_in_params"><xsl:with-param name="func" select="." /></xsl:call-template><xsl:if test=".//paramdef[contains(type,' set')] or .//paramdef[contains(type,'geography set')] or
-						.//paramdef[contains(type,'raster set')]"><sup> agg</sup> </xsl:if><xsl:if test=".//paramdef[contains(type,'winset')]"> <sup>W</sup> </xsl:if></li></xsl:for-each>
-		 		</ol></span></xsl:if>
-		 		</td></tr>
-		 		</xsl:for-each>
-		 		</table><br />
-		 		<!--close section -->
-		 	</xsl:for-each>
-		</div>
+					<xsl:value-of select="refnamediv/refname" />
+				</a>
+			</span>
+		<xsl:if test="contains(.,$new_tag)">
+			 <sup>1</sup>
+		</xsl:if>
+		<xsl:if test="contains(.,$enhanced_tag)">
+			 <sup>2</sup>
+		</xsl:if>
+		<xsl:if test="contains(.,'implements the SQL/MM')">
+			 <sup>mm</sup>
+		</xsl:if>
+		<xsl:if test="contains(refsynopsisdiv/funcsynopsis,'geography') or contains(refsynopsisdiv/funcsynopsis/funcprototype/funcdef,'geography')">
+			 <sup>G</sup>
+		</xsl:if>
+		<xsl:if test="contains(.,'GEOS >= 3.9')">
+			 <sup>g3.9</sup>
+		</xsl:if>
+		<xsl:if test="contains(.,'This function supports 3d')">
+			 <sup>3d</sup>
+		</xsl:if>
+		<!-- if only one proto just dispaly it on first line -->
+		<xsl:if test="count(refsynopsisdiv/funcsynopsis/funcprototype) = 1">
+			(<xsl:call-template name="list_in_params"><xsl:with-param name="func" select="refsynopsisdiv/funcsynopsis/funcprototype" /></xsl:call-template>)
+		</xsl:if>
+		<xsl:if test="$output_purpose = 'true'"><xsl:value-of select="refnamediv/refpurpose" /></xsl:if>
+		<!-- output different proto arg combos -->
+		<xsl:if test="count(refsynopsisdiv/funcsynopsis/funcprototype) > 1"><span class='func_args'><ol><xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype"><li><xsl:call-template name="list_in_params"><xsl:with-param name="func" select="." /></xsl:call-template><xsl:if test=".//paramdef[contains(type,' set')] or .//paramdef[contains(type,'geography set')] or
+				.//paramdef[contains(type,'raster set')]"><sup> agg</sup> </xsl:if><xsl:if test=".//paramdef[contains(type,'winset')]"> <sup>W</sup> </xsl:if></li></xsl:for-each>
+		</ol></span></xsl:if>
+		</td></tr>
+		</xsl:for-each>
+		</table><br />
+		<!--close section -->
 </xsl:template>
diff --git a/doc/xsl/sfcgal_cheatsheet.html.xsl b/doc/xsl/sfcgal_cheatsheet.html.xsl
index 929347f90..3a3fc6303 100644
--- a/doc/xsl/sfcgal_cheatsheet.html.xsl
+++ b/doc/xsl/sfcgal_cheatsheet.html.xsl
@@ -1,5 +1,8 @@
-<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
+<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
+<xsl:stylesheet version="1.0"
+xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
 	 Copyright 2011, Regina Obe
@@ -11,15 +14,18 @@
 	<xsl:include href="common_utils.xsl" />
 	<xsl:include href="common_cheatsheet.xsl" />
-	<xsl:output method="text" />
+  <xsl:variable name="chapter_id" select='"RT_reference"' />
+	<xsl:output method="html" />
 <xsl:template match="/">
-	<xsl:text><![CDATA[<html>
-<head>
-<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
-<title>PostGIS SFCGAL Cheat Sheet</title>
-	<style type="text/css">
+	<html>
+		<head>
+			<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
+			<title>PostGIS SFCGAL Cheatsheet</title>
+<!-- TODO: share a parametrizable stylecheet -->
+			<style type="text/css">
 table { page-break-inside:avoid; page-break-after:auto }
 tr    { page-break-inside:avoid; page-break-after:avoid }
 thead { display:table-header-group }
@@ -50,9 +56,9 @@ body {
 .section {
 	border: 1px solid #000; float:left;
-	margin: 4px;]]></xsl:text>
-	<xsl:choose><xsl:when test="$output_purpose = 'false'"><![CDATA[width: 45%;]]></xsl:when><xsl:otherwise><![CDATA[width: 100%;]]></xsl:otherwise></xsl:choose>
-<xsl:text><![CDATA[	}
+	margin: 4px;
+	<xsl:choose><xsl:when test="$output_purpose = 'false'">width: 100%</xsl:when><xsl:otherwise>width: 100%;</xsl:otherwise></xsl:choose>
 .section th {
 	color: #fff;
@@ -86,90 +92,35 @@ h1 {
 	padding: 0px;
 	font-size: 14pt;
+			</style>
+		</head>
+		<body><h1 style='text-align:center'>PostGIS <xsl:value-of select="$postgis_version" /> SFCGAL Cheatsheet</h1>
+			<span class='notes'>
+				<!-- TODO: make text equally distributed horizontally ? -->
+				<xsl:value-of select="$cheatsheets_config/para[@role='new_in_release']" />
+					<sup>1</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='enhanced_in_release']" />
+					<sup>2</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='aggregate']" />
+					<sup>agg</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='window_function']" />
+					<sup>W</sup>
-</style>
-	</head><body><h1 style='text-align:center'>PostGIS ]]></xsl:text> <xsl:value-of select="$postgis_version" /><xsl:text><![CDATA[ PostGIS SFCGAL Cheatsheet</h1>]]></xsl:text>
-		<xsl:text><![CDATA[<table class="section"><tr><th colspan="2">]]></xsl:text>
-			<xsl:value-of select="title" />
-			<xsl:text><![CDATA[</th></tr>]]></xsl:text>
-			<xsl:apply-templates select="/book/chapter/sect1[@id='reference_sfcgal']" name="function_list" />
-	 	<![CDATA[</table>]]>
-			<xsl:text><![CDATA[</div>]]></xsl:text>
-			<xsl:text><![CDATA[<div id="content_examples">]]></xsl:text>
-			<!-- examples go here -->
-			<xsl:if test="$include_examples='true'">
-				<xsl:apply-templates select="/book/chapter/sect1[@id='reference_sfcgal']/refentry[count(//refsection//programlisting) > 0]" />
-			</xsl:if>
-			<xsl:text><![CDATA[</body></html>]]></xsl:text>
+				<xsl:value-of select="$cheatsheets_config/para[@role='requires_geos_3.9_or_higher']" />
+					<sup>g3.9</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='z_support']" />
+					<sup>3d</sup>
+				SQL-MM<sup>mm</sup>
+				<xsl:value-of select="$cheatsheets_config/para[@role='geography_support']" />
+					<sup>G</sup>
+			</span>
+			<div id="content_functions">
+				<xsl:apply-templates select="/book/chapter/sect1[@id='reference_sfcgal']" />
+			</div>
+		</body>
+	</html>
 </xsl:template>
-    <xsl:template match="refentry" name="function_list">
- 		<![CDATA[<tr]]> class="<xsl:choose><xsl:when test="position() mod 2 = 0">evenrow</xsl:when><xsl:otherwise>oddrow</xsl:otherwise></xsl:choose>" <![CDATA[><td colspan='2'><span class='func'>]]><xsl:text><![CDATA[<a href="]]></xsl:text><xsl:value-of select="$linkstub" /><xsl:value-of select="@id" />.html<xsl:text><![CDATA[" target="_blank">]]></xsl:text><xsl:value-of select="refnamediv/refname" /><xsl:text><![CDATA[</a>]]></xsl:text><![CDATA[</span>]]><xsl:if test="contains(.,$new_tag)"><![CDATA[<sup>1</sup> ]]></xsl:if>
- 		<xsl:if test="contains(.,$enhanced_tag)"><![CDATA[<sup>2</sup> ]]></xsl:if>
- 		<xsl:if test="contains(.,'implements the SQL/MM')"><![CDATA[<sup>mm</sup> ]]></xsl:if>
- 		<xsl:if test="contains(refsynopsisdiv/funcsynopsis,'geography') or contains(refsynopsisdiv/funcsynopsis/funcprototype/funcdef,'geography')"><![CDATA[<sup>G</sup>  ]]></xsl:if>
- 		<xsl:if test="contains(.,'GEOS >= 3.4')"><![CDATA[<sup>g3.4</sup> ]]></xsl:if>
- 		<xsl:if test="contains(.,'This function supports 3d')"><![CDATA[<sup>3D</sup> ]]></xsl:if>
-		</xsl:if>
- 		<![CDATA[  ]]>
- 		<xsl:if test="count(refsynopsisdiv/funcsynopsis/funcprototype) > 1"><![CDATA[<span class='func_args'><ol>]]><xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype"><![CDATA[<li>]]><xsl:call-template name="list_in_params"><xsl:with-param name="func" select="." /></xsl:call-template><![CDATA[</li>]]></xsl:for-each>
- 		<![CDATA[</ol></span>]]></xsl:if>
- 		<![CDATA[</td></tr>]]>
-	</xsl:template>
-	 <xsl:template match="//refentry//refsection[contains(title,'Example')]">
-	 		<!-- less than needed for converting html tags in listings so they are printable -->
-	 		<xsl:variable name="lt"><xsl:text><![CDATA[<]]></xsl:text></xsl:variable>
-	 		<!-- only print section header if it has examples - not sure why this is necessary -->
-	 		<xsl:if test="contains(., 'Example')">
-				<xsl:text><![CDATA[<table><tr><th colspan="2" class="example_heading">]]></xsl:text>
-				<xsl:value-of select="title" /> Examples
-				<!--only pull the first example section of each function -->
-			<xsl:for-each select="refentry//refsection[contains(title,'Example')][1]/programlisting[1]">
-				 <xsl:variable name='plainlisting'>
-					<xsl:call-template name="globalReplace">
-						<xsl:with-param name="outputString" select="."/>
-						<xsl:with-param name="target" select="$lt"/>
-						<xsl:with-param name="replacement" select="'&lt;'"/>
-					</xsl:call-template>
-				</xsl:variable>
-				<xsl:variable name='listing'>
-					<xsl:call-template name="break">
-						<xsl:with-param name="text" select="$plainlisting" />
-				</xsl:variable>
-		 		<![CDATA[<tr]]> class="<xsl:choose><xsl:when test="position() mod 2 = 0">evenrow</xsl:when><xsl:otherwise>oddrow</xsl:otherwise></xsl:choose>"<![CDATA[>]]>
-		 		<![CDATA[<td><b>]]><xsl:value-of select="ancestor::refentry/refnamediv/refname" /><![CDATA[</b><br /><code>]]><xsl:value-of select="$listing"  disable-output-escaping="no"/><![CDATA[</code></td></tr>]]>
-		 	</xsl:for-each>
-		 	</xsl:if>
-	</xsl:template>
 </xsl:stylesheet>
commit f8adda875cdf101423ce340308ad96b43121ee93
Date:   Wed Jul 12 12:30:20 2023 +0200
    Encode dependency on common stylesheets for cheatsheets
diff --git a/doc/Makefile.in b/doc/Makefile.in
index efa1a400f..545d5d40e 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -304,7 +304,7 @@ endif
 $(GENERATED_COMMENT_FILES): %.sql: xsl/%.sql.xsl $(XML_INPUTS) postgis-out.xml
 	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) -o $@ $< postgis-out.xml
-$(GENERATED_CHEATSHEET_FILES): html/%$(DOCSUFFIX).html: xsl/%.html.xsl $(XML_INPUTS) postgis-out.xml
+$(GENERATED_CHEATSHEET_FILES): html/%$(DOCSUFFIX).html: xsl/%.html.xsl $(XML_INPUTS) postgis-out.xml xsl/common_cheatsheet.xsl xsl/common_utils.xsl
 	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) $(XSLTPROC_CUSTOM_VARS) -o $@ $< postgis-out.xml
 # TODO: use a postgis_release_version variable passed via --stringparam
Summary of changes:
 doc/Makefile.in                    |   2 +-
 doc/xsl/common_cheatsheet.xsl      | 121 ++++++++++++++++++--------------
 doc/xsl/sfcgal_cheatsheet.html.xsl | 137 ++++++++++++-------------------------
 3 files changed, 114 insertions(+), 146 deletions(-)
hooks/post-receive
