[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1217-g77dc645cf
Wed Jul 12 06:10:03 PDT 2023
the project "PostGIS".
       via  77dc645cfc9b252f768fdf14499a421b92b20f0f (commit)
      from  d92ef780d2183eb70fd831125657ffa01bea6edb (commit)
revisions in full, below.
commit 77dc645cfc9b252f768fdf14499a421b92b20f0f
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 12 15:09:40 2023 +0200
    Share example_list template and fix tiger_geocoder sheet
diff --git a/doc/xsl/common_cheatsheet.xsl b/doc/xsl/common_cheatsheet.xsl
index 782ac582d..bf17b37aa 100644
--- a/doc/xsl/common_cheatsheet.xsl
+++ b/doc/xsl/common_cheatsheet.xsl
@@ -131,5 +131,45 @@
 		<!--close section -->
 </xsl:template>
+<xsl:template name="examples_list">
+	<!--Beginning of section -->
+	<xsl:variable name="lt"><xsl:text><![CDATA[<]]></xsl:text></xsl:variable>
+	<xsl:if test="contains(., 'Example')">
+	<table>
+		<tr>
+			<th colspan="2" class="example_heading">
+				<xsl:value-of select="title" /> Examples
+			</th>
+		</tr>
+		<!--only pull the first example section of each function -->
+		<xsl:for-each select="refentry//refsection[contains(title,'Example')][1]/programlisting[1]">
+			<!-- add row for each function and alternate colors of rows -->
+			<tr>
+				<xsl:attribute name="class">
+					<xsl:choose>
+						<xsl:when test="position() mod 2 = 0">evenrow</xsl:when>
+						<xsl:otherwise>oddrow</xsl:otherwise>
+					</xsl:choose>
+				</xsl:attribute>
+				<td>
+					<b>
+						<xsl:value-of select="ancestor::refentry/refnamediv/refname" />
+					</b>
+					<br />
+					<pre>
+						<xsl:value-of select="."  disable-output-escaping="no"/>
+					</pre>
+				</td>
+			</tr>
+			</xsl:for-each>
+	<!--close section -->
+	</table>
+	</xsl:if>
+</xsl:template>
 </xsl:stylesheet>
diff --git a/doc/xsl/tiger_geocoder_cheatsheet.html.xsl b/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
index e09d9497e..44ef45031 100644
--- a/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
+++ b/doc/xsl/tiger_geocoder_cheatsheet.html.xsl
@@ -117,55 +117,17 @@ h1 {
 			</span>
 			<div id="content_functions">
 				<xsl:apply-templates select="/book/chapter[@id=$chapter_id]" />
-				<!-- examples go here -->
-				<xsl:apply-templates select="/book/chapter[@id=$chapter_id]/sect1[count(//refentry//refsection//programlisting) > 0]"  />
+				<!-- examples go here | TODO: move this logic to the chapter template ?-->
+				<xsl:for-each select="/book/chapter[@id=$chapter_id]/sect1[count(//refentry//refsection//programlisting) > 0]" >
+					<xsl:call-template name="examples_list" />
+				</xsl:for-each>
 			</div>
 		</body>
 	</html>
 </xsl:template>
-<!-- TODO: move in common_cheatsheet.xsl -->
-<xsl:template match="sect1[count(//refentry//refsection//programlisting) > 0]" name="examples_list">
-	<!--Beginning of section -->
-	<xsl:variable name="lt"><xsl:text><![CDATA[<]]></xsl:text></xsl:variable>
-	<xsl:if test="contains(., 'Example')">
-	<table>
-		<tr>
-			<th colspan="2" class="example_heading">
-				<xsl:value-of select="title" /> Examples
-			</th>
-		</tr>
-		<!--only pull the first example section of each function -->
-		<xsl:for-each select="refentry//refsection[contains(title,'Example')][1]/programlisting[1]">
-			<!-- add row for each function and alternate colors of rows -->
-			<tr>
-				<xsl:attribute name="class">
-					<xsl:choose>
-						<xsl:when test="position() mod 2 = 0">evenrow</xsl:when>
-						<xsl:otherwise>oddrow</xsl:otherwise>
-					</xsl:choose>
-				</xsl:attribute>
-				<td>
-					<b>
-						<xsl:value-of select="ancestor::refentry/refnamediv/refname" />
-					</b>
-					<br />
-					<pre>
-						<xsl:value-of select="."  disable-output-escaping="no"/>
-					</pre>
-				</td>
-			</tr>
-			</xsl:for-each>
-	<!--close section -->
-	</table>
-	</xsl:if>
-</xsl:template>
 </xsl:stylesheet>
Summary of changes:
 doc/xsl/common_cheatsheet.xsl              | 40 ++++++++++++++++++++++++
 doc/xsl/tiger_geocoder_cheatsheet.html.xsl | 50 ++++--------------------------
 2 files changed, 46 insertions(+), 44 deletions(-)
hooks/post-receive
