[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1218-g2c159bc11
Wed Jul 12 06:49:17 PDT 2023
the project "PostGIS".
       via  2c159bc11da0a5e62c4f8a68f07dbf3815e39dbc (commit)
      from  77dc645cfc9b252f768fdf14499a421b92b20f0f (commit)
revisions in full, below.
commit 2c159bc11da0a5e62c4f8a68f07dbf3815e39dbc
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 12 15:48:39 2023 +0200
    Fix cheatsheet conformance labeling for translated versions
    References #5435
diff --git a/doc/xsl/common_cheatsheet.xsl b/doc/xsl/common_cheatsheet.xsl
index bf17b37aa..85f757841 100644
--- a/doc/xsl/common_cheatsheet.xsl
+++ b/doc/xsl/common_cheatsheet.xsl
@@ -3,8 +3,12 @@
 <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
-<xsl:variable name='new_tag'>Availability: <xsl:value-of select="$postgis_version" /></xsl:variable>
-<xsl:variable name='enhanced_tag'>Enhanced: <xsl:value-of select="$postgis_version" /></xsl:variable>
+<xsl:variable name='new_tag' select='"availability"' />
+<xsl:variable name='enhanced_tag' select='"enhanced"' />
+<xsl:variable name='sqlmm_conformance_tag' select='"sqlmm"' />
+<xsl:variable name='Z_conformance_tag' select='"3d"' />
+<xsl:variable name='geography_tag' select='"geography_support"' />
 <xsl:variable name='include_examples'>false</xsl:variable>
 <xsl:variable name='output_purpose'>true</xsl:variable>
 <xsl:variable name='linkstub'>https://postgis.net/docs/manual-<xsl:value-of select="$postgis_version" />/<xsl:value-of select="$postgis_language" /></xsl:variable>
@@ -76,6 +80,9 @@
 		<!-- end of section header beginning of function list -->
 		</th></tr>
 	<xsl:for-each select="current()//refentry">
+		<xsl:variable name="ref" select="." />
 		<!-- add row for each function and alternate colors of rows -->
 		<!-- , hyperlink to online manual -->
 		<tr>
@@ -95,22 +102,23 @@
 					<xsl:value-of select="refnamediv/refname" />
 				</a>
 			</span>
-		<xsl:if test="contains(.,$new_tag)">
+		<xsl:if test="$ref//para[@role=$new_tag and starts-with(./@conformance, $postgis_version)]">
 			 <sup>1</sup>
 		</xsl:if>
-		<xsl:if test="contains(.,$enhanced_tag)">
+		<xsl:if test="$ref//para[@role=$enhanced_tag and starts-with(./@conformance, $postgis_version)]">
 			 <sup>2</sup>
 		</xsl:if>
-		<xsl:if test="contains(.,'implements the SQL/MM')">
+		<xsl:if test="$ref/descendant::*[@conformance=$sqlmm_conformance_tag]">
 			 <sup>mm</sup>
 		</xsl:if>
 		<xsl:if test="contains(refsynopsisdiv/funcsynopsis,'geography') or contains(refsynopsisdiv/funcsynopsis/funcprototype/funcdef,'geography')">
 			 <sup>G</sup>
 		</xsl:if>
+		<!-- TODO: make language-agnostic -->
 		<xsl:if test="contains(.,'GEOS >= 3.9')">
 			 <sup>g3.9</sup>
 		</xsl:if>
-		<xsl:if test="contains(.,'This function supports 3d')">
+		<xsl:if test="$ref/descendant::*[@conformance=$Z_conformance_tag]">
 			 <sup>3d</sup>
 		</xsl:if>
@@ -140,6 +148,7 @@
 	<table>
 		<tr>
 			<th colspan="2" class="example_heading">
+				<!-- TODO: make Examples translatable -->
 				<xsl:value-of select="title" /> Examples
 			</th>
 		</tr>
Summary of changes:
 doc/xsl/common_cheatsheet.xsl | 21 +++++++++++++++------
 1 file changed, 15 insertions(+), 6 deletions(-)
hooks/post-receive
