[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1219-g20745e10c
Wed Jul 12 07:39:34 PDT 2023
the project "PostGIS".
       via  20745e10c4d31db3677160ac4fd7d3d981ef8db8 (commit)
      from  2c159bc11da0a5e62c4f8a68f07dbf3815e39dbc (commit)
revisions in full, below.
commit 20745e10c4d31db3677160ac4fd7d3d981ef8db8
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 12 16:39:22 2023 +0200
    Add script to check localized cheatsheets
diff --git a/utils/check_localized_cheatsheets.sh b/utils/check_localized_cheatsheets.sh
new file mode 100755
index 000000000..2a99aa3f0
--- /dev/null
+++ b/utils/check_localized_cheatsheets.sh
@@ -0,0 +1,36 @@
+#!/bin/sh
+test -n "$3" || {
+  echo "Usage: $0 <source_file> <source_lang> [<target_lang>, ...]" >&2
+  exit 1
+SOURCE_FILE="$1"
+shift
+SOURCE_LANG="$1"
+shift
+TARGET_LANGS="$@"
+test -e "${SOURCE_FILE}" || {
+  echo "No such file or directory: ${SOURCE_FILE}" >&2
+  exit 1
+# Read sup tags from source language cheatsheet
+for tag in $(xmllint --html --xpath '/html/body/span/sup/text()' "${SOURCE_FILE}"); do
+  count=$(grep -c "<sup> *$tag *</sup>" "${SOURCE_FILE}")
+  echo "Occurrences of tag $tag in source file: $count"
+  for lang in ${TARGET_LANGS}; do
+    TR_FILE=$(echo "${SOURCE_FILE}" | sed "s/-${SOURCE_LANG}/-${lang}/");
+    test -e "${TR_FILE}" || {
+      echo "No such file or directory: ${TR_FILE}" >&2
+      exit 1
+    count_lang=$(grep -c "<sup> *$tag *</sup>" "${TR_FILE}")
+    echo "Occurrences of tag $tag in $lang file: $count_lang"
+    if [ $count_lang != $count ]; then
+      echo "Tag tag $tag occurs $count times in ${SOURCE_FILE} and $count_lang times in ${TR_FILE}" >&2
+      exit 1
+    fi
+  done
+done
Summary of changes:
 utils/check_localized_cheatsheets.sh | 36 ++++++++++++++++++++++++++++++++++++
 1 file changed, 36 insertions(+)
 create mode 100755 utils/check_localized_cheatsheets.sh
hooks/post-receive
