[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1220-gaec39bee6
Wed Jul 12 07:51:04 PDT 2023
the project "PostGIS".
       via  aec39bee6ba399085179e2d1f21cabea4b000ce0 (commit)
      from  20745e10c4d31db3677160ac4fd7d3d981ef8db8 (commit)
revisions in full, below.
commit aec39bee6ba399085179e2d1f21cabea4b000ce0
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 12 16:49:12 2023 +0200
    Add check-cheatsheets-localized Makefile target in doc/
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 545d5d40e..e18c08f81 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -28,10 +28,12 @@ PACKAGE_TARNAME = @PACKAGE_TARNAME@
 prefix = @prefix@
 srcdir = @srcdir@
 top_srcdir = @top_srcdir@
+abs_top_srcdir = @abs_top_srcdir@
 datarootdir = @datarootdir@
 datadir = @datadir@
 builddir = @builddir@
 top_builddir = @top_builddir@
+abs_top_builddir = @abs_top_builddir@
 mandir = @mandir@
 abs_srcdir = @abs_srcdir@
 abs_builddir = @abs_builddir@
@@ -549,13 +551,23 @@ endif
 check: check-unit
 check-regress:
+check-unit: check-xml
 ifeq ($(XMLLINT),)
-check-unit: requirements_not_met_xmllint
+check-xml: requirements_not_met_xmllint
+check-cheatsheets: requirements_not_met_xmllint
 else
-check-unit: $(XML_INPUTS)
+check-xml: $(XML_INPUTS)
 	$(XMLLINT) --loaddtd $(XSLTPROC_PATH_OPT) --xinclude --valid postgis-out.xml --noout
+check-cheatsheets: cheatsheets
+	for f in $(abs_builddir)/html/*_cheatsheet-en.html; do \
+		$(abs_top_srcdir)/utils/check_localized_cheatsheets.sh $${f} en $(patsubst -%,%,$(DOCSUFFIX)); \
+	done
 endif
 requirements_not_met_xsltproc:
 	@echo
 	@echo "configure was unable to find 'xsltproc' which is required"
Summary of changes:
 doc/Makefile.in | 16 ++++++++++++++--
 1 file changed, 14 insertions(+), 2 deletions(-)
hooks/post-receive
