[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1229-g67d038ba3
Wed Jul 12 23:02:42 PDT 2023
the project "PostGIS".
       via  67d038ba3882c182f2b9cec8a1cf6518843c80ec (commit)
       via  185df0cb382cbf344326d2ebfe28029c2ed1d743 (commit)
      from  28b15243639da0bce2f761aa195f80dccf0229a9 (commit)
revisions in full, below.
commit 67d038ba3882c182f2b9cec8a1cf6518843c80ec
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 13 08:02:07 2023 +0200
    [woodie] Add localized check-cheatsheets steps
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 4ab19dbcd..2f3665785 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -2,10 +2,11 @@
     image: *test_image
     commands:
       - make -C build-docs/doc/po/@LANG@ local- at TARGET@
-    group: localized- at TARGET@
+    group: @GROUP@
     when:
       path:
         include:
           # Localized assets
           - "doc/po/@LANG@/Makefile.in"
           - "doc/po/@LANG@/*.po"
+          - "utils/check_localized_cheatsheets.sh"
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index a5524a7c5..550e81b0d 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -12,6 +12,7 @@ variables:
         - "doc/*.xml"
         # Internationalization Makefiles
         - "doc/po/Makefile.local"
+        # END OF COMMON PATHS
 pipeline:
   prepare:
@@ -73,186 +74,215 @@ pipeline:
       path: *when_path
   # DO NOT EDIT PAST THIS LINE, use update-docs-localized.sh to update #
-  check-it_IT:
+### TARGET check-xml
+  check-xml-it_IT:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/it_IT local-check
-    group: localized-check
+      - make -C build-docs/doc/po/it_IT local-check-xml
+    group: localized-check-xml
     when:
       path:
         include:
           # Localized assets
           - "doc/po/it_IT/Makefile.in"
           - "doc/po/it_IT/*.po"
           # Common docs path
           # related config files
           - ".woodpecker/docs.yml"
           # Makefiles
           - "doc/Makefile.in"
+          - "doc/html/images/Makefile.in"
           # XML sources
           - "doc/*.xml"
-  check-pt_BR:
+  check-xml-pt_BR:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/pt_BR local-check
+      - make -C build-docs/doc/po/pt_BR local-check-xml
     when:
       path:
         include:
           # Localized assets
           - "doc/po/pt_BR/Makefile.in"
           - "doc/po/pt_BR/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
-  check-fr:
+  check-xml-fr:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/fr local-check
+      - make -C build-docs/doc/po/fr local-check-xml
     when:
       path:
         include:
           # Localized assets
           - "doc/po/fr/Makefile.in"
           - "doc/po/fr/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
-  check-es:
+  check-xml-es:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/es local-check
+      - make -C build-docs/doc/po/es local-check-xml
     when:
       path:
         include:
           # Localized assets
           - "doc/po/es/Makefile.in"
           - "doc/po/es/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
-  check-pl:
+  check-xml-pl:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/pl local-check
+      - make -C build-docs/doc/po/pl local-check-xml
     when:
       path:
         include:
           # Localized assets
           - "doc/po/pl/Makefile.in"
           - "doc/po/pl/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
-  check-ko_KR:
+  check-xml-ko_KR:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/ko_KR local-check
+      - make -C build-docs/doc/po/ko_KR local-check-xml
     when:
       path:
         include:
           # Localized assets
           - "doc/po/ko_KR/Makefile.in"
           - "doc/po/ko_KR/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
-  check-de:
+  check-xml-de:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/de local-check
+      - make -C build-docs/doc/po/de local-check-xml
     when:
       path:
         include:
           # Localized assets
           - "doc/po/de/Makefile.in"
           - "doc/po/de/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
-  check-ja:
+  check-xml-ja:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/ja local-check
+      - make -C build-docs/doc/po/ja local-check-xml
     when:
       path:
         include:
           # Localized assets
           - "doc/po/ja/Makefile.in"
           - "doc/po/ja/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
-  check-ru:
+  check-xml-ru:
     image: *test_image
     commands:
-      - make -C build-docs/doc/po/ru local-check
+      - make -C build-docs/doc/po/ru local-check-xml
     when:
       path:
         include:
           # Localized assets
           - "doc/po/ru/Makefile.in"
           - "doc/po/ru/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
+### TARGET html
   html-it_IT:
     image: *test_image
     commands:
@@ -264,15 +294,18 @@ pipeline:
           # Localized assets
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   html-pt_BR:
     image: *test_image
     commands:
@@ -284,15 +317,18 @@ pipeline:
           # Localized assets
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   html-fr:
     image: *test_image
     commands:
@@ -304,15 +340,18 @@ pipeline:
           # Localized assets
           - "doc/po/fr/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   html-es:
     image: *test_image
     commands:
@@ -324,15 +363,18 @@ pipeline:
           # Localized assets
           - "doc/po/es/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   html-pl:
     image: *test_image
     commands:
@@ -344,15 +386,18 @@ pipeline:
           # Localized assets
           - "doc/po/pl/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   html-ko_KR:
     image: *test_image
     commands:
@@ -364,15 +409,18 @@ pipeline:
           # Localized assets
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   html-de:
     image: *test_image
     commands:
@@ -384,15 +432,18 @@ pipeline:
           # Localized assets
           - "doc/po/de/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   html-ja:
     image: *test_image
     commands:
@@ -404,15 +455,18 @@ pipeline:
           # Localized assets
           - "doc/po/ja/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   html-ru:
     image: *test_image
     commands:
@@ -424,15 +478,19 @@ pipeline:
           # Localized assets
           - "doc/po/ru/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
+### TARGET cheatsheets
   cheatsheets-it_IT:
     image: *test_image
     commands:
@@ -444,15 +502,18 @@ pipeline:
           # Localized assets
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   cheatsheets-pt_BR:
     image: *test_image
     commands:
@@ -464,15 +525,18 @@ pipeline:
           # Localized assets
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   cheatsheets-fr:
     image: *test_image
     commands:
@@ -484,15 +548,18 @@ pipeline:
           # Localized assets
           - "doc/po/fr/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   cheatsheets-es:
     image: *test_image
     commands:
@@ -504,15 +571,18 @@ pipeline:
           # Localized assets
           - "doc/po/es/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   cheatsheets-pl:
     image: *test_image
     commands:
@@ -524,15 +594,18 @@ pipeline:
           # Localized assets
           - "doc/po/pl/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   cheatsheets-ko_KR:
     image: *test_image
     commands:
@@ -544,15 +617,18 @@ pipeline:
           # Localized assets
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   cheatsheets-de:
     image: *test_image
     commands:
@@ -564,15 +640,18 @@ pipeline:
           # Localized assets
           - "doc/po/de/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   cheatsheets-ja:
     image: *test_image
     commands:
@@ -584,15 +663,18 @@ pipeline:
           # Localized assets
           - "doc/po/ja/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   cheatsheets-ru:
     image: *test_image
     commands:
@@ -604,15 +686,227 @@ pipeline:
           # Localized assets
           - "doc/po/ru/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
+### TARGET check-cheatsheets
+  check-cheatsheets-it_IT:
+    image: *test_image
+    commands:
+      - make -C build-docs/doc/po/it_IT local-check-cheatsheets
+    group: localized-check-cheatsheets
+    when:
+      path:
+        include:
+          # Localized assets
+          - "doc/po/it_IT/Makefile.in"
+          - "doc/po/it_IT/*.po"
+          # Common docs path
+          # related config files
+          - ".woodpecker/docs.yml"
+          # Makefiles
+          - "doc/Makefile.in"
+          # XML sources
+          - "doc/*.xml"
+          # Internationalization Makefiles
+          - "doc/po/Makefile.local"
+  check-cheatsheets-pt_BR:
+    commands:
+      - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
+    when:
+      path:
+        include:
+          - "doc/po/pt_BR/Makefile.in"
+          - "doc/po/pt_BR/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-cheatsheets-fr:
+    commands:
+      - make -C build-docs/doc/po/fr local-check-cheatsheets
+    when:
+      path:
+        include:
+          - "doc/po/fr/Makefile.in"
+          - "doc/po/fr/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-cheatsheets-es:
+    commands:
+      - make -C build-docs/doc/po/es local-check-cheatsheets
+    when:
+      path:
+        include:
+          - "doc/po/es/Makefile.in"
+          - "doc/po/es/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-cheatsheets-pl:
+    commands:
+      - make -C build-docs/doc/po/pl local-check-cheatsheets
+    when:
+      path:
+        include:
+          - "doc/po/pl/Makefile.in"
+          - "doc/po/pl/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-cheatsheets-ko_KR:
+    commands:
+      - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
+    when:
+      path:
+        include:
+          - "doc/po/ko_KR/Makefile.in"
+          - "doc/po/ko_KR/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-cheatsheets-de:
+    commands:
+      - make -C build-docs/doc/po/de local-check-cheatsheets
+    when:
+      path:
+        include:
+          - "doc/po/de/Makefile.in"
+          - "doc/po/de/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-cheatsheets-ja:
+    commands:
+      - make -C build-docs/doc/po/ja local-check-cheatsheets
+    when:
+      path:
+        include:
+          - "doc/po/ja/Makefile.in"
+          - "doc/po/ja/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+  check-cheatsheets-ru:
+    commands:
+      - make -C build-docs/doc/po/ru local-check-cheatsheets
+    when:
+      path:
+        include:
+          - "doc/po/ru/Makefile.in"
+          - "doc/po/ru/*.po"
+          # Makefiles
+          # XML sources
+          - "doc/*.xml"
+### TARGET pdf
   pdf-it_IT:
     image: *test_image
     commands:
@@ -624,15 +918,18 @@ pipeline:
           # Localized assets
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   pdf-pt_BR:
     image: *test_image
     commands:
@@ -644,15 +941,18 @@ pipeline:
           # Localized assets
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   pdf-fr:
     image: *test_image
     commands:
@@ -664,15 +964,18 @@ pipeline:
           # Localized assets
           - "doc/po/fr/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   pdf-es:
     image: *test_image
     commands:
@@ -684,15 +987,18 @@ pipeline:
           # Localized assets
           - "doc/po/es/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   pdf-pl:
     image: *test_image
     commands:
@@ -704,15 +1010,18 @@ pipeline:
           # Localized assets
           - "doc/po/pl/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   pdf-ko_KR:
     image: *test_image
     commands:
@@ -724,15 +1033,18 @@ pipeline:
           # Localized assets
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   pdf-de:
     image: *test_image
     commands:
@@ -744,15 +1056,18 @@ pipeline:
           # Localized assets
           - "doc/po/de/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   pdf-ja:
     image: *test_image
     commands:
@@ -764,15 +1079,18 @@ pipeline:
           # Localized assets
           - "doc/po/ja/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
   pdf-ru:
     image: *test_image
     commands:
@@ -784,12 +1102,15 @@ pipeline:
           # Localized assets
           - "doc/po/ru/*.po"
           # Common docs path
           # Makefiles
           - "doc/Makefile.in"
           # XML sources
           - "doc/*.xml"
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index 973790bf9..ad9d2a172 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -4,18 +4,22 @@ cd $(dirname $0)
 SUPPORTED_LANGUAGES=$(grep ^translations ../doc/Makefile.in | cut -d= -f2)
-TARGETS="check html cheatsheets pdf"
+TARGETS="check-xml html cheatsheets check-cheatsheets pdf"
 cat docs.yml | sed '/DO NOT EDIT/q' > docs.yml.new
-cat docs.yml.new | sed -n '/# Common docs path/,/^$/p' | grep -v '^$' | sed 's/^/  /' > docs.yml.common_paths
+cat docs.yml.new |
+  sed '/# Common docs path/,/# END OF COMMON/!d;/# END OF COMMON/q' |
+  sed 's/^/  /' > docs.yml.common_paths
 exec >> docs.yml.new
 for target in ${TARGETS}
 do
+  echo "### TARGET ${target}"
   for lang in ${SUPPORTED_LANGUAGES};
   do
-    sed "s/@LANG@/${lang}/;s/@TARGET@/${target}/" docs-localized.yml.in
+    group=localized-${target}
+    sed "s/@LANG@/${lang}/;s/@TARGET@/${target}/;s/@GROUP@/${group}/" docs-localized.yml.in
     # Add common docs paths
     cat docs.yml.common_paths
   done
commit 185df0cb382cbf344326d2ebfe28029c2ed1d743
Date:   Wed Jul 12 17:41:01 2023 +0200
    Add -v switch, fix typo
diff --git a/utils/check_localized_cheatsheets.sh b/utils/check_localized_cheatsheets.sh
index 2a99aa3f0..fcebbdb11 100755
--- a/utils/check_localized_cheatsheets.sh
+++ b/utils/check_localized_cheatsheets.sh
@@ -1,7 +1,13 @@
 #!/bin/sh
+VERBOSE=0
+if [ "$1" = "-v" ]; then
+  VERBOSE=1
+  shift
+fi
 test -n "$3" || {
-  echo "Usage: $0 <source_file> <source_lang> [<target_lang>, ...]" >&2
+  echo "Usage: $0 [-v] <source_file> <source_lang> <target_lang> [<target_lang> ...]" >&2
   exit 1
@@ -19,7 +25,7 @@ test -e "${SOURCE_FILE}" || {
 # Read sup tags from source language cheatsheet
 for tag in $(xmllint --html --xpath '/html/body/span/sup/text()' "${SOURCE_FILE}"); do
   count=$(grep -c "<sup> *$tag *</sup>" "${SOURCE_FILE}")
-  echo "Occurrences of tag $tag in source file: $count"
+  [ "$VERBOSE" = 1 ] && echo "Occurrences of tag $tag in source file: $count"
   for lang in ${TARGET_LANGS}; do
     TR_FILE=$(echo "${SOURCE_FILE}" | sed "s/-${SOURCE_LANG}/-${lang}/");
     test -e "${TR_FILE}" || {
@@ -27,9 +33,9 @@ for tag in $(xmllint --html --xpath '/html/body/span/sup/text()' "${SOURCE_FILE}
       exit 1
     count_lang=$(grep -c "<sup> *$tag *</sup>" "${TR_FILE}")
-    echo "Occurrences of tag $tag in $lang file: $count_lang"
+    [ "$VERBOSE" = 1 ] && echo "Occurrences of tag $tag in $lang file: $count_lang"
     if [ $count_lang != $count ]; then
-      echo "Tag tag $tag occurs $count times in ${SOURCE_FILE} and $count_lang times in ${TR_FILE}" >&2
+      echo "Tag $tag occurs $count times in ${SOURCE_FILE} and $count_lang times in ${TR_FILE}" >&2
       exit 1
     fi
   done
Summary of changes:
 .woodpecker/docs-localized.yml.in    |   3 +-
 .woodpecker/docs.yml                 | 375 ++++++++++++++++++++++++++++++++---
 .woodpecker/update-docs-localized.sh |  10 +-
 utils/check_localized_cheatsheets.sh |  14 +-
 4 files changed, 367 insertions(+), 35 deletions(-)
hooks/post-receive
