[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1230-g7357e187c
git at osgeo.org
git at osgeo.org
Wed Jul 12 23:18:00 PDT 2023
the project "PostGIS".
via 7357e187c6d6b59b01e696b9e9a2e7ed9885e14b (commit)
from 67d038ba3882c182f2b9cec8a1cf6518843c80ec (commit)
revisions in full, below.
commit 7357e187c6d6b59b01e696b9e9a2e7ed9885e14b
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jul 13 08:17:16 2023 +0200
[woodie] Always build images once
Avoids race condition between localized pdf targets
See https://woodie.osgeo.org/postgis/postgis/build/643/15
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 550e81b0d..fba0cd798 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -13,6 +13,22 @@ variables:
# Internationalization Makefiles
- "doc/po/Makefile.local"
# END OF COMMON PATHS
+ - &when_path_full
+ include:
+ # Common docs path
+ # related config files
+ - ".woodpecker/docs.yml"
+ # Makefiles
+ - "doc/Makefile.in"
+ - "doc/html/images/Makefile.in"
+ # XML sources
+ - "doc/*.xml"
+ # Internationalization Makefiles
+ - "doc/po/Makefile.local"
+ # END OF COMMON PATHS
+ # Localized assets
+ - "doc/po/*/Makefile.in"
+ - "doc/po/*/*.po"
pipeline:
prepare:
@@ -24,26 +40,19 @@ pipeline:
- ../configure --without-pg
- make postgis_revision.h
when:
- path:
- include:
- # Common docs path
- # related config files
- - ".woodpecker/docs.yml"
- # Makefiles
- - "doc/Makefile.in"
- # XML sources
- - "doc/*.xml"
- # Internationalization Makefiles
- - "doc/po/Makefile.local"
- # Localized assets
- - "doc/po/*/Makefile.in"
- - "doc/po/*/*.po"
+ path: *when_path_full
check-xml:
image: *test_image
commands:
- make -C build-docs/doc check
when:
path: *when_path
+ build-images:
+ image: *test_image
+ commands:
+ - make -C build-docs/doc images
+ when:
+ path: *when_path
build-html:
image: *test_image
group: output
Summary of changes:
.woodpecker/docs.yml | 37 +++++++++++++++++++++++--------------
1 file changed, 23 insertions(+), 14 deletions(-)
hooks/post-receive
