[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1243-g92c5d42c6
Thu Jul 13 19:08:37 PDT 2023
the project "PostGIS".
       via  92c5d42c616abd845a8425ae5341a260d60273e8 (commit)
       via  3ffc81d9dd2a02e971ad6437a88674929efb073d (commit)
       via  edd38994d95268bc7bf989270d7e36b6026c8255 (commit)
       via  887b5502a884e1278ea9b79e071c3517cb90fe21 (commit)
      from  e00f658e35688b27c2c9d86021046167ba35a37b (commit)
revisions in full, below.
commit 92c5d42c616abd845a8425ae5341a260d60273e8
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Fri Jul 14 00:57:18 2023 +0000
    Translated xsl-config using Weblate (Japanese)
    Currently translated at 100.0% (24 of 24 strings)
    Translation: postgis/xsl-config
    Translate-URL: https://weblate.osgeo.org/projects/postgis/xsl-config/ja/
diff --git a/doc/po/ja/xsl-config.xml.po b/doc/po/ja/xsl-config.xml.po
index 8fc0dcd6d..9b71ab248 100644
--- a/doc/po/ja/xsl-config.xml.po
+++ b/doc/po/ja/xsl-config.xml.po
@@ -56,10 +56,10 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-12 08:31+0000\n"
-"PO-Revision-Date: 2023-07-05 04:08+0000\n"
+"PO-Revision-Date: 2023-07-14 02:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/xsl-"
-"config/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"xsl-config/ja/>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -186,43 +186,43 @@ msgstr "この関数は3次元に対応し、Z値を削除しません。"
 #: xsl-config.xml:169
 #, no-c-format
 msgid "New in this release"
-msgstr ""
+msgstr "このリリースの新機能"
 #. Tag: para
 #: xsl-config.xml:172
 #, no-c-format
 msgid "Enhanced in this release"
-msgstr ""
+msgstr "このリリースで強化"
 #. Tag: para
 #: xsl-config.xml:175
 #, no-c-format
 msgid "Aggregate"
-msgstr ""
+msgstr "集約関数"
 #. Tag: para
 #: xsl-config.xml:178
 #, no-c-format
 msgid "Window function"
-msgstr ""
+msgstr "ウィンドウ関数"
 #. Tag: para
 #: xsl-config.xml:181
 #, no-c-format
 msgid "Requires GEOS 3.9 or higher"
-msgstr ""
+msgstr "GEOS 3.9以上が必要"
 #. Tag: para
 #: xsl-config.xml:184
 #, no-c-format
 msgid "2.5/3D support"
-msgstr ""
+msgstr "2.5次元/3次元対応"
 #. Tag: para
 #: xsl-config.xml:187
 #, no-c-format
 msgid "Supports geography"
-msgstr ""
+msgstr "ジオグラフィ対応"
 #, no-c-format
 #~ msgid ""
commit 3ffc81d9dd2a02e971ad6437a88674929efb073d
Date:   Fri Jul 14 00:53:15 2023 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (400 of 400 strings)
    Translation: postgis/reference_accessor.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_accessorxml/ja/
diff --git a/doc/po/ja/reference_accessor.xml.po b/doc/po/ja/reference_accessor.xml.po
index e9cc91bb3..f1bd6f745 100644
--- a/doc/po/ja/reference_accessor.xml.po
+++ b/doc/po/ja/reference_accessor.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "POT-Creation-Date: 2023-07-09 16:49+0000\n"
-"PO-Revision-Date: 2023-05-15 11:08+0000\n"
 "reference_accessorxml/ja/>\n"
@@ -421,6 +421,10 @@ msgid ""
 "</lineannotation>\n"
 "MULTIPOINT((100 150),(160 170))"
 msgstr ""
+"<lineannotation>\n"
+"ST_AsText output\n"
+"</lineannotation>\n"
+"MULTIPOINT((100 150),(160 170))"
 #. Tag: para
 #: reference_accessor.xml:124
@@ -456,6 +460,11 @@ msgid ""
 "MULTILINESTRING((10 130,50 190,110 190,140 150,150 80,100 10,20 40,10 130),\n"
 "        (70 40,100 50,120 80,80 110,50 90,70 40))"
 msgstr ""
+"MULTILINESTRING((10 130,50 190,110 190,140 150,150 80,100 10,20 40,10 130),\n"
+"        (70 40,100 50,120 80,80 110,50 90,70 40))"
 #. Tag: programlisting
 #: reference_accessor.xml:136
commit edd38994d95268bc7bf989270d7e36b6026c8255
Date:   Fri Jul 14 01:03:22 2023 +0000
    Currently translated at 100.0% (315 of 315 strings)
    Translation: postgis/reference_relationship.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_relationshipxml/ja/
diff --git a/doc/po/ja/reference_relationship.xml.po b/doc/po/ja/reference_relationship.xml.po
index 7de28a3e4..a87726d6f 100644
--- a/doc/po/ja/reference_relationship.xml.po
+++ b/doc/po/ja/reference_relationship.xml.po
@@ -11,7 +11,7 @@ msgstr ""
-"PO-Revision-Date: 2023-07-11 05:08+0000\n"
 "reference_relationshipxml/ja/>\n"
@@ -258,6 +258,8 @@ msgid ""
 "In mathematical terms: <emphasis>ST_Contains(A, B) ⇔ (A ⋂ B = B) ∧ (Int(A) ⋂ "
 "Int(B) ≠ ∅) </emphasis>"
 msgstr ""
+"数学用語では: <emphasis>ST_Contains(A, B) ⇔ (A ⋂ B = B) ∧ (Int(A) ⋂ Int(B) ≠ "
+"∅) </emphasis>"
 #. Tag: para
 #: reference_relationship.xml:100
@@ -588,6 +590,8 @@ msgid ""
 "Returns <varname>true</varname> if every point of B lies in the interior of "
 "A (or equivalently, no point of B lies in the the boundary or exterior of A)."
 msgstr ""
+"Bの全てのポイントがAの内部にある (もしくはBのポイントでAの外部にあるポイント"
+"が無い)場合に<varname>TRUE</varname>を返します。"
 #. Tag: para
 #: reference_relationship.xml:290
@@ -596,6 +600,8 @@ msgid ""
 "In mathematical terms: <emphasis>ST_ContainsProperly(A, B) ⇔ Int(A) ⋂ B = B "
 "</emphasis>"
 msgstr ""
+"数学用語では: <emphasis>ST_ContainsProperly(A, B) ⇔ Int(A) ⋂ B = B "
+"</emphasis>"
 #. Tag: para
 #: reference_relationship.xml:293
@@ -603,7 +609,8 @@ msgstr ""
 msgid ""
 "A contains B properly if the DE-9IM Intersection Matrix for the two "
 "geometries matches [T**FF*FF*]"
-msgstr ""
+msgstr "二つのジオメトリのDE-"
+"9IM交差行列が[T**FF*FF*]に合致する場合には、AがBを完全に含みます。"
 #. Tag: para
 #: reference_relationship.xml:296
commit 887b5502a884e1278ea9b79e071c3517cb90fe21
Date:   Fri Jul 14 00:54:12 2023 +0000
    Currently translated at 100.0% (304 of 304 strings)
    Translation: postgis/reference_measure.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_measurexml/ja/
diff --git a/doc/po/ja/reference_measure.xml.po b/doc/po/ja/reference_measure.xml.po
index 3529691ec..cb017b0fa 100644
--- a/doc/po/ja/reference_measure.xml.po
+++ b/doc/po/ja/reference_measure.xml.po
@@ -3,12 +3,13 @@
 # Translators:
 # Kayama Yoichi <yoichi.kayama at gmail.com>, 2016
 # TERAMOTO Ikuhiro <yellow at affrc.go.jp>, 2016
+# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2023.
 msgid ""
 msgstr ""
 "POT-Creation-Date: 2023-07-12 18:27+0000\n"
-"PO-Revision-Date: 2023-07-03 03:08+0000\n"
 "reference_measurexml/ja/>\n"
@@ -718,6 +719,15 @@ msgid ""
 "choice=\"opt\"><type>boolean </type> <parameter>repeat = true</parameter></"
 "paramdef> </funcprototype>"
 msgstr ""
+"<funcprototype> <funcdef>geometry <function>ST_ClosestPoint</function></"
+"funcdef> <paramdef><type>geometry </type> <parameter>geom1</parameter></"
+"paramdef> <paramdef><type>geometry </type> <parameter>geom2</parameter></"
+"paramdef> </funcprototype> <funcprototype> <funcdef>geography "
+"<function>ST_ClosestPoint</function></funcdef> <paramdef><type>geography </"
+"type> <parameter>geom1</parameter></paramdef> <paramdef><type>geography </"
+"type> <parameter>geom2</parameter></paramdef> <paramdef choice=\"opt\""
+"><type>boolean </type> <parameter>repeat = true</parameter></paramdef> "
+"</funcprototype>"
 #. Tag: para
 #: reference_measure.xml:254
@@ -3558,6 +3568,15 @@ msgid ""
 "choice=\"opt\"><type>boolean </type><parameter>use_spheroid = true</"
 "parameter></paramdef> </funcprototype>"
 msgstr ""
+"<funcprototype> <funcdef>geometry <function>ST_ShortestLine</function></"
+"<function>ST_ShortestLine</function></funcdef> <paramdef><type>geography </"
+"><type>boolean </type><parameter>use_spheroid = true</parameter></paramdef> "
+"</funcprototype>"
 #. Tag: para
 #: reference_measure.xml:1486
Summary of changes:
 doc/po/ja/reference_accessor.xml.po     | 11 ++++++++++-
 doc/po/ja/reference_measure.xml.po      | 21 ++++++++++++++++++++-
 doc/po/ja/reference_relationship.xml.po | 11 +++++++++--
 doc/po/ja/xsl-config.xml.po             | 20 ++++++++++----------
 4 files changed, 49 insertions(+), 14 deletions(-)
hooks/post-receive
