[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1244-g4a9b1312d
Thu Jul 13 23:44:19 PDT 2023
the project "PostGIS".
       via  4a9b1312df60a14acc0d4813076ea26a9113a674 (commit)
      from  92c5d42c616abd845a8425ae5341a260d60273e8 (commit)
revisions in full, below.
commit 4a9b1312df60a14acc0d4813076ea26a9113a674
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 14 08:43:09 2023 +0200
    Do remove and re-create symlinks
    Works around mingw lack of symlinks support.
    Should fix #5441
diff --git a/doc/po/Makefile.local b/doc/po/Makefile.local
index 5b7065339..8f47b085d 100644
--- a/doc/po/Makefile.local
+++ b/doc/po/Makefile.local
@@ -1,9 +1,9 @@
-# This file should be installed in each
-# language directory
+# This file should be included by the Makefile
+# of each language directory
 local-all: local-html comments
-# We do not want to recurse in parent dir here
+# We do not want to recurse in parent dir for the "clean" rule
 local-clean: local-html-clean local-pdf-clean local-epub-clean local-cheatsheet-clean
 	rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
 	rm -f $(XML_INPUTS)
@@ -18,8 +18,8 @@ local-%: symlinks
 	$(MAKE) $(patsubst local-%,%,$@) DOCSUFFIX=$(DOCSUFFIX)
 symlinks:
-	ln -sf ../../html .
-	ln -sf $(srcdir)/../../xsl .
+	test -e html || ln -sf ../../html .
+	test -e xsl || ln -sf $(srcdir)/../../xsl .
 # for XML_SOURCES
 include ../../Makefile
Summary of changes:
 doc/po/Makefile.local | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
