[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1254-geb0549cd9
Fri Jul 14 06:34:06 PDT 2023
the project "PostGIS".
       via  eb0549cd9b00ceabb5e807f35db0435891f3b237 (commit)
      from  aa5466846937c8d8c84966b0ea914857c572ee2e (commit)
revisions in full, below.
commit eb0549cd9b00ceabb5e807f35db0435891f3b237
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 14 15:33:30 2023 +0200
    Prepare input for generated xml only once
diff --git a/.gitignore b/.gitignore
index 956cc57e7..4d852102f 100644
--- a/.gitignore
+++ b/.gitignore
@@ -39,6 +39,7 @@ doc/Makefile
 doc/Makefile.comments
 doc/**.xsl.xml
 *.tag
+doc/postgis-nospecial.xml
 doc/po/*/*.xml
 doc/po/*/html
 doc/po/*/Makefile
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 0d3625322..a87f56576 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -291,11 +291,14 @@ update-po: $(XML_INPUTS_POT)
   done
 endif
+postgis-nospecial.xml: postgis-out.xml
+	grep -v '\&postgis_special;' $< > $@
 ifeq ($(XSLTPROC),)
 $(XSL_GENERATED_SOURCES): requirements_not_met_xsltproc
 else
-$(XSL_GENERATED_SOURCES): %.xsl.xml: xsl/%.xml.xsl postgis-out.xml xsl-config.xml $(TAG_GENERATED_SOURCES) $(XML_SOURCES)
-	grep -v '\&postgis_special;' postgis-out.xml | $(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) -o $@ $< -
+$(XSL_GENERATED_SOURCES): %.xsl.xml: xsl/%.xml.xsl postgis-nospecial.xml xsl-config.xml $(TAG_GENERATED_SOURCES) $(XML_SOURCES)
+	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) -o $@ $< postgis-nospecial.xml
 endif
 ifeq ($(XMLLINT),)
@@ -449,6 +452,7 @@ cheatsheet-clean:
 clean: images-clean html-clean pdf-clean epub-clean cheatsheet-clean
 	rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
 	rm -f $(XML_GENERATED_SOURCES)
+	rm -f postgis-nospecial.xml
 	rm -f $(TAG_GENERATED_SOURCES)
 	$(MAKE) -C $(images_builddir) clean
 	rm -f postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
Summary of changes:
 .gitignore      | 1 +
 doc/Makefile.in | 8 ++++++--
 2 files changed, 7 insertions(+), 2 deletions(-)
hooks/post-receive
