[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1256-g4077f518c
Fri Jul 14 13:37:06 PDT 2023
the project "PostGIS".
       via  4077f518c888f08cd187096d68f6c019187dae93 (commit)
      from  78a4dd2fb38eb3e7be55d850a4302658ff3ccad8 (commit)
revisions in full, below.
commit 4077f518c888f08cd187096d68f6c019187dae93
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Jul 14 13:37:02 2023 -0700
    Fix documentation of parameter
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 21d5c9811..0bb73fda1 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -310,7 +310,7 @@ SELECT degrees( ST_Angle('LINESTRING(0 0, 0.3 0.7, 1 1)', 'LINESTRING(0 0, 0.2 0
             <paramdef><type>geography </type>
               <parameter>geom2</parameter></paramdef>
             <paramdef choice="opt"><type>boolean </type>
-              <parameter>repeat = true</parameter></paramdef>
+              <parameter>use_spheroid = true</parameter></paramdef>
           </funcprototype>
 		</funcsynopsis>
Summary of changes:
 doc/reference_measure.xml | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
