[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1257-gc78b7201d
Fri Jul 14 14:39:26 PDT 2023
the project "PostGIS".
       via  c78b7201d2a8a13cef3d0f7f030cee19654df80b (commit)
      from  4077f518c888f08cd187096d68f6c019187dae93 (commit)
revisions in full, below.
commit c78b7201d2a8a13cef3d0f7f030cee19654df80b
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jul 14 16:42:17 2023 -0400
    More Prep for release
     - Add in missing NEWS about ST_ClosesPoint and ST_ShortestLine
       for geography (credit MobilityDB)
       References #5266 for PostGIS 3.4.0
     - Add in missing docs and notes about ST_Project and ST_LineExtend
     - Disable PDF local translated building for now
       only build de and fr until we resolve other issues
diff --git a/NEWS b/NEWS
index 17adccca9..d73aa1d4d 100644
--- a/NEWS
+++ b/NEWS
@@ -20,8 +20,10 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
   - Allow singleton geometry to be inserted into Geometry(Multi*) columns (Paul Ramsey)
   - GH721, New window-based ST_ClusterWithinWin and ST_ClusterIntersectingWin (Paul Ramsey)
   - #5397, [address_standardizer] debug_standardize_address function (Regina Obe)
-  - ST_LargestEmptyCircle, exposes extra semantics on circle finding (Martin Davis)
-  - ST_Project signature for geometry, and two-point signature (Paul Ramsey)
+  - #5373, ST_LargestEmptyCircle, exposes extra semantics on circle finding
+    Requires GEOS 3.9+ (Martin Davis)
+  - #5267, ST_Project signature for geometry, and two-point signature (Paul Ramsey)
+  - #5267, ST_LineExtend for extending linestrings (Paul Ramsey)
 * Enhancements *
   - #5194, do not update system catalogs from postgis_extensions_upgrade (Sandro Santilli)
@@ -39,6 +41,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
   - #4913, ST_AsSVG support for curve types CircularString, CompoundCurve, MultiCurve,
            and MultiSurface (Regina Obe)
+  - #5266, ST_ClosestPoint, ST_ShortestLine support for geography type
+           (MobilityDB, Paul Ramsey)
 * Breaking Changes *
   - #5229, Drop support for Proj < 6.1 and PG 11 (Regina Obe)
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index 4fd622334..200b44ff5 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -109,9 +109,13 @@ done
 make pdf-install # || : survive failure
 make epub-install # || : survive failure
+# build german and french pdf
+make -C doc/po/fr local-pdf-install
+make -C doc/po/de local-pdf-install
+# TODO put back after resolve issue with japan build
 # Build and install localized pdf and epub
-make pdf-install-localized # || : survive failures
-make epub-install-localized # || : survive failures
+#make pdf-install-localized # || : survive failures
+#make epub-install-localized # || : survive failures
 if [[ "$POSTGIS_MICRO_VERSION" == *"dev"* ]]; then
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 0bb73fda1..a6d3168fd 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -324,6 +324,7 @@ SELECT degrees( ST_Angle('LINESTRING(0 0, 0.3 0.7, 1 1)', 'LINESTRING(0 0, 0.2 0
         (as computed by <xref linkend="ST_ShortestLine"/>).
 		</para>
 		<note><para>If you have a 3D Geometry, you may prefer to use <xref linkend="ST_3DClosestPoint" />.</para></note>
+        <para role="enhanced" conformance="3.4.0">Enhanced: 3.4.0 -  Support for geography added</para>
 		<para role="availability" conformance="1.5.0">Availability: 1.5.0</para>
 	  </refsection>
@@ -1917,6 +1918,7 @@ FROM ST_GeogFromText('MULTIPOLYGON(((-71.1044543107478 42.340674480411,-71.10445
 		The length of the line is the same as <xref linkend="ST_Distance"/> returns for g1 and g2.
 		</para>
+        <para role="enhanced" conformance="3.4.0">Enhanced: 3.4.0 - support for geography</para>
 	  </refsection>
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 3ff36793e..a504c60dd 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -26,8 +26,9 @@
                 <para>Allow singleton geometry to be inserted into Geometry(Multi*) columns (Paul Ramsey)</para>
                 <para><ulink url="https://github.com/postgis/postgis/pull/721">721</ulink>, New window-based ST_ClusterWithinWin and ST_ClusterIntersectingWin (Paul Ramsey)</para>
                 <para><ulink url="https://trac.osgeo.org/postgis/ticket/5397">5397</ulink>, [address_standardizer] debug_standardize_address function (Regina Obe)</para>
-                <para>ST_LargestEmptyCircle, exposes extra semantics on circle finding. Geos 3.9+ required(Martin Davis)</para>
-                <para>ST_Project signature for geometry, and two-point signature (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5373">5373</ulink>ST_LargestEmptyCircle, exposes extra semantics on circle finding. Geos 3.9+ required(Martin Davis)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5267">5267</ulink>, ST_Project signature for geometry, and two-point signature (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5267">5267</ulink>, ST_LineExtend for extending linestrings (Paul Ramsey)</para>
             </simplesect>
             <simplesect>
@@ -47,6 +48,7 @@
                 <para><ulink url="https://trac.osgeo.org/postgis/ticket/4913">4913</ulink>, ST_AsSVG support for curve types CircularString, CompoundCurve, MultiCurve,
                         and MultiSurface (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5266">5266</ulink>, ST_ClosestPoint, ST_ShortestLine support for geography type (MobilityDB, Paul Ramsey)</para>
             </simplesect>
             <simplesect>
Summary of changes:
 NEWS                              | 8 ++++++--
 ci/debbie/postgis_release_docs.sh | 8 ++++++--
 doc/reference_measure.xml         | 2 ++
 doc/release_notes.xml             | 6 ++++--
 4 files changed, 18 insertions(+), 6 deletions(-)
hooks/post-receive
